Question about Acer AL1717 17" LCD Monitor
LCD problems I have an Acer LCD monitor, i plag on my computer and it shows me white holizontal lines from up to down..wht might be wrong with it?
  • Anonymous Mar 09, 2009
    HELP ME SAME PROBLEM T_T
Try turning the brightness all the way up to 100. That seemed to solve the problem for now. I believe neilneves is right that the power inverter is not supplying enough power, but in my case at least, by increasing the brightness the LCD is now receiving enough power to not flicker.
Posted on May 12, 2009
    Scholar:
  • 39 Answers
Unfortunately guys the LCD is damaged and the internal power inverter is not supplying the necessity to the lcd to display , This is usually a very expensive repair and not worth fixing. I would recommend you guys just get a new one but if you want you can always send it to the manufacturer for an Estimate but they are just gonna charge you close to what you paid for this hardware fix its a physically part that is needed. Hope my answer gets you closer to a solution. Please Help rate me if I helped you out or not I am new but a very good tech.
Posted on Aug 11, 2008
Me also I have an Acer LCD monitor my proplem it shows me full screen white can i fix it plz help
Posted on Jul 19, 2008
Acer monitor screen showing partial screen only. rest of screen showing black & white dots.
Hello there.
Try the monitor with ANOTHER computer,
This will prove whether it is the Monitor at fault or not.
Sep 25, 2014 | Computers & Internet
Acer AL1711 17" LCD Monitor showing white screen
A white screen indicates the power supply board is not putting out the correct voltages to properly power the monitor, just the back light. This type of issue is caused by a failure of the filter capacitors on the power board. You can rebuild your power supply board and bring the monitor back to life by just replacing the the bad capacitors. The problem is that model the Acer AL1711 could come with 1 of 4 different power supply boards install depending and the date manufacturer and supply on hand. If you want to repair the monitor if you could open the unit and get either the model number of the power supply board or send a picture of the board to me I will be glad to help you repair the unit and get it back up and running. You can contact me to send the information at tech@ccl-la.com
Nov 30, 2012 | Acer AL1711 17" LCD Monitor
Vertical Red Line down the screen of my Acer Al1717.
Try hooking an external monitor. If it will still show on the other display, possibly it is a video card problem. But I highly doubt it. Usually for this issue, it will have a good display on an external monitor. Try if it will still appear n the BIOS page. Press F2 several times immediately after turning the computer on. If problem still shows there, then it is the LCD that is causing it to happen. You need to replace the LCD.
Sep 21, 2010 | Acer 17" AL1717 Flat Panel Color LCD...
Vetical lines on monitor
The LCD panel if failing, you will get more line as time goes by due to bad LCD t-con board (part of LCD panel). Nothing you can do but replacing the LCD panel.
http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1916W%20Abd/
http://s807.photobucket.com/home/budm/allalbums
Apr 17, 2010 | Acer AL1916W 19" LCD Monitor
Very horizontal faint white lines running down the screen
hi,
check if the line appears in BIOS...dont worry when i say BIOS...not sure how to check...turn the system off...restart the system and keep tapping the F2 key...you would get a Blue screen...check if the lines appear on this screen...if it appears...it could either be b'cause the display driver has gone wrong or the system might have a physical damage.....if the lines does not occur on this screen....it is a manufacturing defect...please contact the manufacturer and report the issue for solution.......
regards
Rocky
Jan 12, 2010 | Acer AL1717 17" LCD Monitor
Rolling Horizontal Lines across the screen
ground loop is problem. Many answers available via Google.
Jul 07, 2009 | Acer AL1916W 19" LCD Monitor
Compaq TFT 8020 Display Problim
have you tried going to menu and setting back to factory defaults? also, disconnect power cable and leave unplugged for 1 minute. Plug back in then see if problem is still there. Otherwise, something is wrong with the monitor that will need serviced or exchanged.
Jun 24, 2009 | Compaq TFT8020 (White) 18" LCD Monitor
Red Vertical lines on 15" Acer LCD Monitor
I think this is most likely a monitor problem. Can you try a different monitor of computer to the monitor? That would help pinpoint the problem. Is it under warranty?
Sep 17, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
LCD Problem
The symptom of your LCD screen when it wanted to "die". I suggest you to send it to a workshop and get it repaired.
Jun 05, 2007 | Acer AL1511 15" LCD Monitor
Acer AL1717 17" LCD Monitor Logo
271 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
