Question about Lands Phones
Connection Hi, i do not know how to connect it!!! I have no idea what goes where?
    Sergeant:
  • 154 Answers
Sir can u briefly explain ur problem... do u have problem with connectin mobile with computer or wat??/
Posted on Jun 26, 2008
Hi - just fitted my beko washing machine after moving .Disaster!! When the water began to fill it come straight out of the bottom through a disconnected 10mm black hose about 300mm long .One end was...
a 10mm pipe is not the main drain pipe. The 10mm black pipe is for manual emptying and should have a blue stopper to plug the end, pull off the front bottom panel, and there should be a small opening, inside this opening is the manual drain pipe. Check to see that the blue stopper is still connected. If not, then you can buy these for less than a fiver online.
Oct 06, 2012 | Beko WME7247W Washing Machine
Camera is not working properly when i go on skype, it's flickering and i dont know what to do
Hi and good day '''be curious , try to check your wire connection to PC first but sir/ma'am as we observed Skype owns or consumes a big amount of internet connection when used, so i conclude that it is just on the flow of your internet connection that makes your cam flickers, i hope you have a find day read and understand our simplest ideas in a way when days past and still the same thing goes defective of your cam ''' better to re-install driver again . . . . . thanks
Jul 16, 2011 | Computers & Internet
When you push the power button on the monitor the green light comes on for a few seconds then goes to yellow. Any ideas? It is a Dell e773c connected to a HP Pavillon 700
Please check the vga connection cable. It may not connected to the computer. If you have dual monitor support (2 monitor connection on the PC) try other vga port.
Aug 19, 2010 | Dell E773C 17" CRT Monitor
Samsung PPR2200
Change 4 capacitors (10uF) in sound session
Feb 28, 2010 | Televison & Video
I discovered a fuel line hanging and don't know where to connect it. My bike know does not start although it would turn over. I got it to start yesterday not knowing that the line is disconnected, but...
Hi and welcome to FixYa,
If I may share a couple of ideas:
  • if it were a fuel line, then fuel would be leaking either at the end of the hose or at wherever it is to be connected;
  • it is possible to be an overflow hose;
  • it is possible to be a discharge line for the drain;
  • it could be a vacuum line that connects from the carb or rubber coupling or intake manifold that goes to the fuel shutoff valve;
  • it could be a vacuum balancer that goes to the other carb or rubber coupling or intake manifold;
  • if it were fuel line either for inflow or overflow, hose would be relatively big;
  • if it were vacuum or drain, hose would be relatively small.
For a service manual, pls try here for starters.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 14, 2008 | 2000 Harley Davidson FLSTC Heritage...
ENTERTAINMENT COMPONENT CONNECTIONS TO TV
Hi Elvistheking,
Yes, Best Buy™ offers home theater installation and set-up services. You can request a consultation with a Geek Squad® professional either by visiting your local store or at our website.
Thank you,
Jason,
Go Ahead. Use Us.
Jun 20, 2008 | Televison & Video
Can I fix this???
if that is the case, then there is indeed a short on the ac port (thats where you plug in the charger.) that's the reason why the charger light goes off as soon as you plug it in to the back of the computer. I know its gonna cost you a lot since the only way if fixing this is to replace the motherboard. if its gonna cost you $500 + then better buy a new one. they're gonna replace it with a refurbished motherboard anyways.
Hope this helps.
thanks.
Nov 12, 2007 | Dell Latitude D600 Notebook
How do I connect the receiver and television together
Try to connect AUDIO OUT from your TV to AUDIO IN to your receiver.
Oct 05, 2007 | RCA RT2600 System
Connecting hdd led lead and power led lead,where do they go ?
Hi, There are 3 versions of this motherboard; 1.0, 2.0 & 3.3, but the layout is identical. The general layout is shown in pins.jpg. For the power led, the white wire goes to the (-) terminal either pin 2 or 3, both are MPD- while the green goes to the ( ) or pin 1 (MPD ) as shown in powerled.jpg HDDpins.jpg shows the connection of HDD led, the white goes to pin 3 or HD- while the red goes to pin 1 or the HDD . I cropped these images from the manual which is also available at the gigabyte website. Hope this gives you some ideas and workout of you. Good luck and pls post again how things turn up. Kind regards.
Aug 15, 2007 | Gigabyte GA-965G-DS3 Motherboard
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
