Question about Goodman CLQ36AR49 Air Conditioner
Another Goodman compressor
I had that "liquid slugging" problem going on about two months ago, when the sequencer did not turn the fan on, but the compressor was running anyway.  It ran afor a few days like this before I discovered it.
Now I have the opposite problem- the fan works but the compressor tries t start... i guess it's every 60 seconds or so, but regardless, the compressor unit outside buzzes like it is trying to start, then nothing.
Is the whole comressor unit shot?
  • 182 Answers
Maybe,maybe not.Disconnect the power to the unit.Have a tech check the capacitor.
Posted on Jul 04, 2008
My Goodman condenser which was recently replaced is making a severe swashing noise when it stops. Like a back flush or something. Need to know if this standard.
Normally if it does not sound right, it is not right. By your discription it sounds like your compressor is having a problem with flood back caused by a txv not metering properly, or an overcharged system. You will need a tech who can determine superheat and subcool for your refrigerant system. Find a tech who can determine these values. Superheat and subcool is normally around 8 -12 degrees. Superheat is the amount of additional heat the refrigerant picks up in the evaporator once it is turned to gas and is needed to keep liquid refrigerant from flooding back to the compressor. Compressor are designed to compress gas not liquid. Subcool is the additional cooling refrigerant undergoes once the refrigerant turns back into into liquid in the conderser. Subcool ensures the refrigerant remains in liquid form until it reaches the metering device. Only liquid suppied metering devices will pass the required amount of refrigerant to achieve the rated cooing or heating rates. If it is liquid flood back, your compressor will be damaged and will need to be replaced. Hope this helps
Oct 07, 2014 | Goodman Manufacturing Goodman R410A 13...
Fan keeps running
the safety built in is when the sequencer goes bad it turns on the fan so it doesnt create a fire. replace sequencer. to make sure check amps if over 6 or7 amps sequencer is faulty
Jun 08, 2013 | Goodman Heating & Cooling
4 year old goodman 3 ton residential air conditioner is not working properly. Air handler is running, evap fan is running but compressor is not coming on. Had similar problem a month or so ago and it...
If the fan is running and the compressor is not running then you should be getting power to the compressor...
Often the dual capacitor will go bad and then the compressor will not start.
I usually change the cap to make sure that is not the problem.
If the compressor still does not start then check the start amps and you will find that you are probably getting locked rotor amps. or no amps... (open windings)
Either way you will have to replace the compressor...
heatman101
Jul 07, 2011 | Heating & Cooling
Our upright freezer is only freezing halfway up. have had the fan checked and it is ok. When i turn the freezer on, I hear the fan start up, but within five seconds, a click can be heard and it stops. I...
This is a reach here---it sounds like it could be low on refrigerant---but hold it---have you moved this unit from one spot to another--if so it needs set for 24hr before energizing it--also has mice made a nest in the compressor-condenser area---they may chewed on some wires--on some unit there a heater on bottom of compressor to keep the refer in gas so not to slug the compressor with refer liquid since liquid does not compress maybe locking up compressor. GL
Sep 18, 2017 | Freezers
Goodman fan running but no air coming out of vents and temp is now 85. Also, is there a restart button on the machine
you have to chaeck if the outdoor unit is running you the t-stat has to call for cooling in turning closing contacts between r and y the pulling in coil at condensor. your outdoor unit is not running
Aug 17, 2009 | Goodman CLQ36AR49 Air Conditioner
I had a new 2.5 ton condenser installed last year and the compressor burned out. I had it replaced. My unit stopped cooling well during the middle of the day and we added some gas to it. Then, the...
When 13+ SEER condensers are replaced without installing a inside coil with an expansion valve the compressor in the new unit will slug and go bad. Slug means that liquid refrigerant returns to the compressor. Liquid can not be compressed so it causes the compressor to fail.
Jun 23, 2009 | Ruud UAMB Air Conditioner
We got an a/c central unit goodman modle ckl60-1 and a month a go it broke and the technician said that it needed a new capacitor and freon and about a week ago the unit broke again and the technician said...
When a compressor is has to start. 1. HAs it been off longer than five minutes. As a service tech when I run on to this problem I install a hard start kit and a time delay. The start kit helps the compressor to start under heavy load condtions. The timer helps the compressor to balance out before tryng to start. Have tech set at 5 minutes. I install hard start kits and time delays on all my change outs. Replace problem will go away. Thanks Rus
Jun 15, 2009 | Goodman CKL60AR60 Air Conditioner
Cool turned down to 65 and it is still 81 in the house
to see if the compressor is running feel your line set the liquid line
(small line) should feel like there is fluid flowing though it, you can also disconnect the o/d fan briefly if you want to be certain the compressor is running, it best however to get a meter and amp clap to do a proper diagnosis, you are limited to your tools as well as your knowledge, call an NATE certified professional.
May 24, 2009 | Goodman GMS90703BXA Heater
Inside blower not starting every time
That's a weird problem. I wonder if the outside compressor is drawing down the voltage in the breaker box enuff to keep the blower from starting up. If you're set to cool but the thermostat is NOT calling for the AC, can you manually turn the blower on fathfully? If so, I would check all wiring connections in the breaker box to make sure they are tight and free from tarnish or corrosion. You may even need to contact your power company and have a higher amperage line installed outside. Do your house lights blink noticably when the compressor kicks on?
While you're resolving this, you could start the blower manually and just leave it on. The compressor cycling on/off shouldn't stop the blower once it's running and it won't draw much current... couple bucks a month maybe.
Hope that helps...
Geno
Apr 04, 2008 | Goodman CKL24AR24 Air Conditioner
Compressor run in fan mode only
on t-stat sounds like the G and Y wires are crosseed G on stat is for blower operation ,and Y is for A/C, W for heat, R for 24V and C for commom of 24V call back installer if under warranty
Apr 23, 2007 | Goodman CLJ42AR49 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
90 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
