Question about Samsung Cameras
As soon as I switch the camera on it turns itself off again and makes 3 beeping sounds. I have charged the battery though so it has charge thanks
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
Which kind of camera is it? whats the battery type? maybe it's broken. see if there is a damage in the battery touch place.
Posted on Jun 26, 2008
When headlights turned on the dashboard lights dim and after 5 minutes a warning sound comes on.
Sounds like your charging system needs some attention.
1st check battery for voltage should be 12.50 or better with car off
2nd, start car check battery for voltage again should be 14.0 to 14.75 volts.
3 with running turn on headlamps and check charging voltage again if your voltage dropped to battery voltage your charging system is not working.
Oct 30, 2017 | 2006 Jeep Wrangler
2 beeps
Always first check the battery. Switch off the camera, remove the battery and charge the battery. Then try again. Sometimes, even when the charger indicates the battery is charged, it can be the battery does not have enough power. If the camera does not work, even after charging the battery, contact the service centre closest to you.
Feb 10, 2014 | Samsung Digimax S500 Digital Camera
I have an LG 8700. It is only 8 months old. When I charge the phone, it will beep. Sometimes it will do it every so many seconds, sometimes continually. It will also turns itself back on, and as this...
That batt is almost dead, had a similar problem. No tricks just replace it. Or try charging using a universal charge where you remove the batt and charge it seperately
Jun 04, 2010 | LG VX-8700 Cellular Phone
SHUTS OFF BY ITSELF
yes,, when we charge the battery for a longtime. the battery's will automatically decrease, this is the reason the camera is getting turned off by itself, change your battery to make it work well.,, thank you.. plzzz rate me,,,
Jun 29, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
On start-up, Samsung S860 beeps 3 times then turns itself off
first off,never use rechargable batteries in this camera or most digital cameras for that matter.2 use only lithium batteries,enegizer preffered.,also yes you can view all your pictures when connecting the usb,meke sure you turn the power on,and highlight the word computer,push ok.you should be fine.good luck .i hope i helped
Apr 30, 2009 | Samsung S860 Digital Camera
Can't get the power on...
I would try a new battery. How old is the battery? Your probably right about the battery not holding a charge.
Feb 17, 2009 | Samsung Cameras
Installing camera
run software again reattach camera after you restart computer
Feb 21, 2008 | Cameras
Digimax A7: When I turn it on it turns off.
It seems i have the same problem...although my batteries do charge, and i can take pictures. But when I play them back It does this beep beep beep and shuts off and the lens doesnt always close. It's really pissing me off
Dec 20, 2007 | Samsung Digimax A7 Digital Camera
Camera not switching on
Sounds like the battery has failed. if you can, then if you can try and borrow a working battery from someone else with the same camera, and try your battery on their camera just to confirm this is the problem. If you can't, then just try a new battery - please post again if you are having trouble finding one. Other possibility is that there is a fault with the charger - again if you can borrow one, you can soon see of this is the problem. Most camera repair shops will have a selection of chargers they can use, so you should be able to check this quite easily. Hope this helps :)
Mar 28, 2007 | Samsung Digimax i6 PMP Digital Camera
Cameras Logo
112 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
