Question about Bosch KGU32124 Bottom Freezer Refrigerator
Fan noisy How do I access the fan unit inside the freezer
Thank you for contacting me, the noisy fan unit was resolved when the freezer
was defrosted'
Posted on Jun 29, 2008
How to repair a noisy fan in GE GTS16GBSRWW
Remove the back panel to gain access to motor - look for screws back there.. Remove motor and clean and oil motor bearings - make sure fan blades are all even and not hitting anything.
Aug 26, 2017 | GE Refrigerators
Replace noisy freezer fan on samsung rf4287hars
fan is in the freezer behind back wall, and it needs to be removed to access the fan motor .
Aug 29, 2014 | Samsung RF4287HARS - 28 cu. ft. French...
Freezer fan dead?
Could be the defrosting that is not working. The fan starts touching the ice build up on the back that then causes the noise. A few days later the fan will get stuck on the ice as it keeps on building up due to no defrosting taking place. Unit will keep running as the set temperature inside the cabinet cant be reached because the air distribution will get blocked of due to the ice build up and stuck fan.
Oct 06, 2017 | Northland 24" Built In Top Freezer...
I have a hotpoint refrigerator, model number HTS17GSERWW. It was a noisy appliance from very beginning. For last 2 weeks the noise has gotten very loud, it is inside the freezer compartment - when I open...
Good day,
The only moving part in the freezer is the fan motor. Unless the fan blade broke one of it's blades you will need to replace the motor with a new one. They are not repairable. At the same time buy a new blade as well, since an out of balance blade could have started this problem.
To access the motor, remove the ice maker, if it has one (3 screws and an electrical plug. The cube tray holder if not).
Remove the screws from the back panel, and remove the panel.
The motor change is a straight nuts and bolts job and fairly easy.
Any decent sized appliance parts house will carry the motor and blade. Take the model number with you.
Aug 05, 2010 | GE Hotpoint Top-Freezer Refrigerator
New model ET1CHEXYQ02 VERY NOISY, LIKE TO MAKE
Hello there
Please follow these steps first ok
It's noisy Noise can come from these areas: The inside of the freezer The outside back of the refrigerator The bottom of the refrigerator The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it. The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator it may make noise
Apr 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Noisy, Chattering fan with fisher & paykel fridge.
HI. Just so you know, Hissing and popping is normal on frost free refrigerators, it is the defrost heater, in this case. I would check these following areas to address any other abnormal noises.
If the level of the unit is not adjusted to proper specs, this will create an unstable operating condition, causing many noises to emit from the units structure. inspect the unit for proper level. adjust if needed. Next will be the drain pan. Once removed for cleaning, the pan must be replaced in position correctly. If not, the pan will rattle against the compressor, causing a ping or rattle.Simply reposition the tray if this is the case. The third possible issue will be the condenser fan. The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. This fan has a shroud, and if the fan blade becomes warped, it will rub against the shroud, causing noise. This fan blade is whole,and it can be removed and replaced if this is the case. Ok, the fourth problem spot will be the evaporator fan.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. if the blades are warped or mis-aligned, replace it. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged.
Last, i would move on to the compressor mounts. This is the most common spot for noise overtime. The compressor sits on rubber mountings. Those rubber mountings are designed to absorb vibration from the compressor. As the mountings age, they can become hard or disintegrate. When this happens, the compressor vibration is transmitted to the refrigerator structure and it can cause noise.
The compressor is located in the rear. It may be necessary to remove an access panel to get to the compressor.
Locate the compressor and remove the screw or retaining clip of just one of the compressor mounts.Using a pry bar, lift up the compressor enough to slip out the rubber mount. Inspect the mount for deterioration. The rubber should be firm but not rigid. If the mount is crumbling or hard, it should be replaced.
This concludes the inspection procedure. Follow carefully, and replace any failed or damaged device.....
Dec 20, 2009 | Fisher Refrigerators
Noisy Motor?
Hi, It is the evaporator fan motor/blade hitting something. Remove the rear panel inside the freezer section and see what the fan blade is hitting.
Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Jul 27, 2009 | LG LSC26905TT Side by Side Refrigerator
Access to the circulation fan Kenmore upright freezer
There is a panel on the lower back wall inside the freezer.
Remove it to access the fan motor.
Mar 21, 2009 | Kenmore Freezers
Freezer fan noise
fulout the plastic cover inside tha freezer, put oil on the bosing, front and back,
Nov 16, 2007 | Sub-Zero 690 Side by Side Refrigerator
Bosch KGU32124 Bottom Freezer Refrigerator Logo
264 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
