I need tray 2 to be my default printing tray but someone has changed this setting and I don't know how to get it back. The printer in question is HP LASERJET P3005d.
  • timore Jul 29, 2008
    need tray 2 to be the default in hp laser jet 4350 dtn printer
  • ermstechp Mar 13, 2009
    I have a HP 4250 that was defaulting to Tray 1 - a bypass tray. The post that said try setting Tray 1 to Custom worked. It now prints directly from Tray 2.
    Thanks!
I don't know if this is an HP-approved solution but I fixed mine by setting the tray 1 paper size to "Custom" (instead of letter).
Posted on Sep 04, 2008
How do I change the default on my HP P30005dn to Tray 2?
Normal default on HP is tray 2, however if you do not have that tray set for plain paper letter size the printer will default to whichever tray has letter plain paper installed. You should also check your print driver default settings to ensure that tray 2 is set as default tray.
Aug 14, 2014 | HP LaserJet P3005dn Printer
Printer will only print from tray 1 and not tray 2
In your printer properties page you can change the default tray.
Nov 26, 2009 | HP LaserJet 2430dtn Printer
How to change the default tray on a HP 2430?
print config page of printer,see how trays are configured.
Jul 01, 2009 | HP LaserJet 2430n Printer
HP Laserjet 4700 Always Defaults to Tray 1
Your tray 1 might be open (even just partially) or your manual feed setting might be on. You can find this setting under > Configure device / Printing / Manual Feed
Jun 25, 2009 | HP LaserJet 4700 Printer
Hp laserjet must manually push button to print
Please print a configuration page from the control panel of the printer
- Menu > Information menu > print configuration.
- Check for paper handling details.
Following setting should reflect.
Tray 1: Any size / Any Type
Tray 2: A4 size / Plain Type
If the above settings are not reflecting in the configuration page, please change accordingly by browsing on the control panel of the printer to:
Paper Handling Menu >
Tray 1 Size: Any
Tray 1 Type: Any
Tray 2 Size: A4
Tray 2 Type: Plain
Let me know if that helps to solve the issue.
Regards,
Nikhil.
Jun 14, 2009 | HP LaserJet 2420 Printer
Keeps reseting to Tray 1
Printer Defaults button? what magical land is that found in?
Here is the real solution:
In Printers and Faxes, right-click the printer
Click Printing Preferences
In Paper Source drop down, select Tray 2.
Peace!!
d(-_-)b
May 14, 2009 | HP Office Equipment & Supplies
HP Laserjet 5000dn
if you using office go to page setup and select the tray(s) that you want to use for the first page and other pages ( both must be the same ) unless you only want the first page as letter head and the rest on plain paper or something along those lines ?
Also if you go into the properties of the printer and go to advanced and then click on the printing defaults button and see if the options in there are the same or different to whats in printing preferences.
If they are set to tray 1 then it will default to tray 1
Apr 13, 2009 | HP LaserJet 5000dn Printer
Paper tray?
Two possible solutions;
1) Check the settings in the printer driver for the default tray. The other user could very well have changed them and set tray 1 as the default tray.
2) Check the paper size settings in the paper tray. Pull tray 2 out and check the paper guides. Make sure the paper guide in the front and left of the paper tray are set for the correct media type (letter, legal, etc.)
The printer reads the tabs in the back of the papertray to identify the paper size. If someone moved it while loading paper the printer identifies another paper size and defaults into the tray that has the size of paper required to print.
Hope this solves your problem.
Nov 19, 2008 | HP LaserJet 4100n Printer
A3 size does not feed automatically from tray on HP5550
Try this::: The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
NOTE: If the issue is resolved and it is necessary to print on another type of paper, load the new paper type into the product and then repeat steps 2 through 7 for the new paper.These changes do not change the default print settings. The print settings return to the default the next time the program is opened. Let me know if it helps or I can research it some more.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 13, 2008 | HP DeskJet 5550 InkJet Printer
HP 4250 DN
Change the tray one behavior from the front panels paper handling menu. from there you can tell tray 1 to print first if paper is present or default to tray 2.
factory settings are to print from tray 2.
are you keeping paper in both trays??
Mar 28, 2008 | HP LaserJet 4250n Printer
3,542 people viewed this question
jasbo
jasbo
