Question about HP Computers & Internet
Motherboard hi need to no what pin dose what
Putting the ms-6577 board in a new atx case and i need to no what plugs on the new case plug where on the board things like the power /reset/h.d.d/and the mic in/out/groundand the ground r-out/l-out and r-ret/l-ret done the usb need help with the rest hope you can help me with this
Posted on Jun 26, 2008
  • 90 Answers
Clarification request:
be spcific problem like what pin and connected to the......
Installing an internal speaker on a Desk top pc mother board do you need to reconfigure your system.
Typically, the speaker is connected with 2 or 3 wires. The connector block should have a pin labled "SPKR" or "Speaker". From there, count three up and find a pin labeled "+5v". These two pins are typically separated by two ground pins.
So, the connection would be: spkr, gnd, gnd, +5v. The ground pins may, or may not be used depending on your design.
Nov 06, 2014 | Computers & Internet
What dose the smps 4pin socket used for
Power for the Intel processor.
It's a > 4-pin ATX +12 Volt
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Is there another problem I can help with regarding this?
Please post in a Comment.
Regards,
joecoolvette
Nov 24, 2010 | Intel D915GLVG Motherboard
Coffee drop into my laptop when turn on no display and dose not boot
HI, If your Dell computer is under an "Accidental Damage Warranty". you can call dell to request for a replacement. If not, you might need to replace the Motherboard on the computer.
Cheers!!!
Aug 23, 2010 | Dell Inspiron 1420 Motherboard - KN548
Need pin configuration for power switch, HDD LED, power LED, front USB, etc.
Hi, just like you I purchased two of these motherboards and I have very good news for you. Above the blue PRIMARY IDE ATA connector is a set of 18 pins labeled PB/LED P5 and pin 1 is labeled.
17 15 13 11 9 7 5 3 1
18 16 14 12 10 8 6 4 2
Pins 1 and 3 = HD LED
Pins 2 and 4 = POWER LED
Pins 6 and 8 = POWER SWITCH
pin 14 has no
pin
Feb 02, 2010 | Compaq (283983-001) Motherboard
Windows 98 but want to put usb into tower onto the mother bord but th wires witch order do they go in or dose it matter ie red/white/ black/blue/yellow/green hae to put them onto motherboard pins it is a...
You should have 4 joined pins and 1 black ground for each usb port.
The red wire is for Pin1
White wire is for Pin2
Green is for Pin3
Then you have the Ground wire (black)
The pins on the motherboard are all numbered.
Oct 11, 2009 | Computers & Internet
Need pin position for motherboard fsb1066 power, reset, frontal doors...
On the motherboard the pinouts on the front panel should be colour coded, and marked with letters like in this picture >>>>>
The connectors are also marked corresponding to where the connect on the motherboard, like in this picture >>>>>>
If the board is not colour coded then the motherboard will marked with the same letters, you may need a strong light to see the marks.
Regards.
Sep 15, 2009 | Gigabyte Computers & Internet
ASUS P5GD1-VM Motherboard Problems-ok i just got a new borad because my other ASUS P5GD1-VM Motherboard did not work. i put every thing back but it is not working, the green light come on the motherborad...
did you make sure that all the Correct power connectors were in the correct position Different processors and mother boards use different means to get power to the board. On this particular board there are only Two that i can see. there is one in the corner near the CPU that can easily be over looked it is 4 pin and only fits one way(keyed). only having the 20 pin ATX will show power to the board but may not have the juice to power it.
So double check the four pin axillary connector in the corner near the cpu ( upper left) let me know if you already have done this.
Jan 30, 2009 | ASUS P5GD1-VM Motherboard
ASUS P5Q3 LGA 775 Intel P45 ATX Intel Motherboard
ALTHOUGH THE PINS WERE SAME BUT THE MODULE ARE NOT COMPATIBLE WITH EACH OTHER.
Nov 22, 2008 | ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775...
Cant get to bios
Is it possible that your monitor is bad? or could the cable connection from the monitor to the computer case be in some fashion defective. Look at the cable end that hooks to the computer for bent pins due to improperly plugging the VGA cable into the computer case. If you find such a bent pin, very carefully try to straighten it out with a very small metal tube like some that come in ball point pins. You will need to be very careful doing this as the pins on the VGA connector are very sensitive to breakage if overly pressured. Make sure all power is turned off before attempting this fix. Also, is your Hard drive running, i.e. does the computer seem to be booting up all the way even tho you can't see any display. Normally during boot up, you will see the case Hard drive LED provide a series of displays, indicating that the hard drive is working and booting up. If these displays are occurring, then the next best guess is the monitor or monitor cable. Also you might be able to straighten the VGA cable pins with a very small set of tweezers or needlenose, but please be careful. It is normal to have what appears to be a missing pin when looking at the VGA connector, don't worry about that. What is wrong tho would be a bent pin.
Hope this has been of help
Aug 24, 2008 | Ld Asus P5LD2-VM LGA775/945G/DDR2/Dual...
Computers & Internet Logo
119 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
