Back to:
Tags:
Sony VAIO PCG-K23 PC Notebook
Sony vaio on Standby with black screen
posted by ogbuefi77 on Jun 26, 2008
My laptop has been on standby with a black screen.
You hear noise inside without any thing.
Sometimes,it will just come on for only 3 seconds and
you could see the standby window and before you attempt to
click anything it goes black again.
Comment by ogbuefi77, posted on Jun 27, 2008
It was for only once and has refused to continue working with that solution.The trouble is still there.
I need to try something else that could provide a more permanent solution....SONY VAIO VGN FE 550
Thanks
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 26, 2008
Helpful (85)
dilipbagdi
Rank:Guru Guru
Rating: 86%, 495 votes
ya it happens sometime ,the only solution is that take out the battery completely and also disconnect the power cable from laptop.After 10 minutes put the battery in the laptop and connect it with the power cable ,now start the system and see ..........
if the problem persist let me know.just reply with a comment ..
i hope this works..
also don't forget to rank this solution .thanks
Comment by dilipbagdi, posted on Jun 29, 2008
You can go with recovery option..or take the back up of your laptoop to any other media and reinstall the operating system.
Bluescreen error are related to hardware ,but you are using laptop so this is not possible that hardware is attached wrongly.but sometimes due to wrong drivers installation also may cause this problem .see device manager if all the drivers are properly installed.
reply with a comment to me ,to know how you are doing
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Sony vaio on Standby with black screen:
I don't want to Accept this solution
Solution #2
posted on Jul 18, 2008
Not Rated (0)
neckutter1
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Take the battery out, unplug it and then remove and reseat the ramstick(s) that fixed the problem for me, and several others that I read about online. Goodluck!
Thank You!
Can you Help with these PC Laptops problems?
PC Laptops
bt freestyle 3200 phone i have a twin set and both...
PC Laptops
on my Medion Mim2120 laptop, I installed Vista onto it...
PC Laptops
Hi, I am trying to upgrade my bluetooth connection on my...
I am having problems when I send an email and then they...
Pioneer dvd-rw dvr17 ata disk player will not operate get...
Loading problems.
Repair Service
Find PC Laptop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
