Question about Sony Televison & Video
Sony KV29C3A 100Hz
Hi! I have problem with my Sony 8 years old .The screen is much bright(almost gray) and are visible some horizontal line (almost like a spring).Going to the center of-the screen those line are shorter in lenght.
Any ideas
  • 63 Answers
This will almost certainly be a problem with the Line output transformer, sometimes known as the flyback transformer. It will need to be repaired by a qualified technician I'm affraid as there are dangerous voltages on this part even with the set unplugged from the mains.
Sorry for the bad news.
Andy
Posted on Jun 26, 2008
Hi, I had a problem with my Sony CRT television.
The faint background lines are vertical flyback lines. Start your diagnosis by turning the brightness and contrast controls to minimum and view the screen in a darkened room. If you can now see a raster with horizontal lines visible then it is likely that the tubes A1 screen voltage is excessive. The screen voltage is usually within the range of 400v to 600v. Adjustment for this is often part of the flyback transformer. Check all high value resistors
in the screen and focus circuitry. Some of these reistors may be
built into the flyback transformer. As the picture gets brighter the beam current increases, this will eventually cause the X ray protection circuits to trigger shuting off the set. A fault in the video drive circuits to the cathodes of the tube will cause similar symptoms but usualy results in a predominance of one colour, ie
bright red, blue or green raster with flyback lines.
Oct 20, 2013 | Sony KP-53HS10 TV
I have a Sony vio model PCG-3E2L laptop computer, the problem I have is my laptop screen is getting a horizontal fine line at the bottom one inch above the line is of red color but color changes from...
  1. It smees your LCD is faulty.
  2. connect your laptop to a external monitor. Check if lines are visible or not.
  3. if no line are visible then need to change your LCD.
  4. for changing better to contact service centre.
  5. you can look for used LCD, which will be cheap.
Aug 21, 2010 | Sony VAIO PCG-TR3AP1 Notebook
I have a sony 50 in rear projection. 9 years old
Sounds like the CRT tubes are going out which is fairly common on Sony. Inside the back of the TV there are 6 knobs - 2 for each color...one is for focus - dont touch - the other for brightness...turn down the brightness just a hair untill the lines go away.
Dec 01, 2009 | Sony KP-51WS510 51" Rear Projection...
Gray screen with horizontal lines accross it
sounds like you may have a bad ic it probley is a surface mount on the bottom of the board it could couse this problem would need to take to a shop to repair. The ic probley is numbered ic101 on board.
Mar 01, 2009 | Sanyo DS32224 TV
Sony KV29C3A 100Hz
It's almost certainly the transformer itself but with the fault you are getting it wouldn't be something that can be measured with a meter.
Regards
Andy
Jun 27, 2008 | Televison & Video
Tube TV - one thin horizontal line of bright light
Vertical defection failure. Common failure. Pretty easy to repair ($50-75?). However, my general rule of thumb is not to waste any more money on TVs over 10 years old. Too much other stuff in there ready to fail as well.
Jan 24, 2008 | Televison & Video
White horizontal, zig-zagging lines
It sounds to me like you're describing the re-trace of the unit. It is repairable, and more so the sooner you get it to the repair facility.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Images with white horizontal lines
Send it back to sony, It has recall for this problem, Ck web site.( Sensor chip is bad )
Jun 11, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Grey line horizontally across screen
yOU ARE HAVING A PROBLEM IN HORIZONTAL CIRCUIT OR IN YOUR POWER SUPPLY kindlyu take your T.V tO A QUALIFIED TECH to repair it.ypur problem could be a faulty capacitor ,flyback or horizontal output transistor.
Feb 16, 2007 | Sony WEGA KLV-26HG2 26 in. HD-Ready LCD...
Televison & Video Logo
83 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
