Question about Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard
Problem motherboard no power
How motherboard get power? what will i do?
  • 1 more comment
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Do you still need help with this problem?
  • Dave Rojas
    Dave Rojas May 11, 2010
    Is this a motherboard you received without any other hardware or is it your computer won't turn on?
  • Glenn Rogers
    Is everything corrected properly and was working ok, but now it doesn't?
  • 3 Answers
Make sure you have the proper power rating and ATX connection, your power supply may not have enough wattage to power your board, be sure its at least 300W
hope this helps
Posted on Nov 02, 2008
What is the maximum power rating of this motherboard?
What do you mean, "maximum power rating"? Motherboards have no power of their own, they are powered by a power supply which can vary in watts produced. Motherboards have no "power rating". Your question cannot be answered because it is incorrect.
Jul 22, 2014 | HP Boston-gl6 Motherboard Msi Ms-7525...
Power supply diagram for ht 2000 motherboard
1) Uses one 24-pin ATX main power cable.
Motherboard installed in computer case, the motherboard connector for the 24-pin ATX main power cable; is to the Right of the Blue IDE (PATA) connector.
(Right side of motherboard)
General example. Note that color does NOT matter of connector,
2) Uses one 4-pin ATX +12 Volt power cable,
Motherboard installed in computer case, the whitish square 4-socket hole connector, to the Bottom/Left corner of the Processor socket; is the 4-pin ATX +12 Volt power cable's motherboard connector.
General example. Note color does NOT matter of connector,
THAT, would be considered a Power Supply diagram of the motherboard.
They are the only two power cables that plug into the motherboard.
The front of your desktop computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
Power On switch, Power On LED, (Light Emitting Diode), Harddrive activity LED, and a Reset switch IF used.
Apr 15, 2013 | ECS HP MCP61PM-HM Nettle3-GL8E 6150SE AM2...
Intel desktop d845epi in the motherboard is not powering on.plz send a solve procedure.urgent
computer not power on can be caused by 2 thing, first is your power supply was dead, and the second is your motherboard was broken
try to connect another power supply, if your motherboard can power on it mean your power supply was dead if still not power on it mean your motherboard was dead, change the motherboard with new one
Mar 18, 2011 | Intel Desktop Board D845EPI Motherboard
Bought a new power supply and still my biostar p4tca pro motherboard isnt letting it to power up? all wires are hooked up right. now thinking the motherboard is bad? anything i can do to prove that this is...
Make sure that the 20-pin ATX connector and the 4-pin aux. power connector are securely plugged into the motherboard and that the power supply's switch is in the "On" position. If the problem persists, you can try testing the power supply with a different motherboard and computer. If the power supply powers the other computer, it is likely the motheboard that is bad and not the power supply.
Hope this has been helpful. Good luck.
Mar 01, 2011 | Biostar p4tca pro Motherboard
Powr supply checks out with tester, but when plugged into a BRANDNEW motherboard. Flashes green, Power switch is in and fans are in. Is it possible for P/S to be bad only when drawing from board?
There are many possibilities here. The motherboard could be installed incorrectly causing a short. The motherboard may not support the processor. A hardware device plugged into the motherboard may be shorted. The power supply may be defective under load ( when plugged into everything). No memory is installed on the motherboard. The power supply is too small for the motherboard that was installed. The first thing to check, is to plug in the motherboard connectors only with memory installed then try to power up. If at this point it will not power up, then you have a problem with the power supply or motherboard. If it powers up at this point, then plug in one device at a time starting with the hard drive and try to power up. If it continues to power up, plug in another device. If this process continues work, then you will find that either you have a shorted device or your power supply will not support the motherboard and all of the installed devices. It is also possible at this point that the motherboard is defective, by using more power than it should causing an overload on the power supply with all devices plugged in.
Dec 27, 2009 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Will not power up
This is a common problem with Emachine motherboards, the problem is the power supply is a best tech and allows voltage surges to the motherboard which fries it too. If available you usually have to replace both the power supply and motherboard. I do not know what exactly goes bad on the motherboard but I have replaced many emachine power supplies and motherboards. The motherboard kit which used to be available from Emachines included a power supply and no warranty if you didn't change the power supply. They knew they had a problem.
Dec 27, 2009 | E-Machines (308714) Motherboard
AOpen AX4BS motherboard front panel connections & power on.
That model motherboard does not support on/off control of the power supply. Refer to the output diagram on the power supply, and there should be pins in the connector (not used on your board) that may refer to the on/off control. Those pins should be tied together. Then the PC will turn on via the main power switch, and will require a manual turn off when the display says its ok.
Oct 24, 2009 | Acer AOpen AX4BS-V (91.89J11.001)...
Motherboard was generated by power supply to running it.. If there is no power when you click the power on, it may caused by the power supply unit problem
Sep 21, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard Logo
37 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
