posted by eddleston64 on Jun 26, 2008
What do I have to do to get the attachment parts to actually work? In addition to that problem cfan you please tell me how to get the water to not drain out all at once.
1 Other User Has The Same Problem
Comment by jks4747, posted on Jul 12, 2008
I am using my sons billel pro heat. It works fine on the carpet, yet on the upolstery only water comes out. It just doesn't **** it up. Whats the problem. Since my son is out of town and I have no instruction book, help. He has tried to tell me what to do over the phone. Just won't **** up water??? Thanks. jks4747@yahoo.com
Solution #1
posted on Jun 26, 2008
For the attachments, turn the knob on the left to tool setting, that will open the valve at the top to allow suction thru the hose, then squeeze the trigger to spray. Close it when you are done or you won't have suction down below.
If the water is running out, either the valve at the bottom of the tank isn't working right or youy have a water line off, probably have to take off the top cover to check that out.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Bissell 1699 ProHeat Clear View
Email this problem
Email this problem
Can you Help with these Vacuums problems?
Bissell 1699 ProHeat Clear View Upright Steam...
directions for Bissell upright...
We have a Bissell power cleaner... Answer This...
Repair Service
Find Vacuum Repairman Near You:
