Question about Philips DVP620VR DVD Player/VCR
Supervideo? how do i get to the "supervideo" option?
  • 63 Answers
Not sure for that exact model, but it'll be in the set up menu under picture or AV settings.
Posted on Jun 26, 2008
Signal board
There is a lot to consider here. First, does this TV have an input for HDMI? If not...the best picture is for supervideo. If you do have an HDMI port and you are trying to fix this....you may have to replace the signal board. It is extremely difficult to replace the HDMI on an existing board. You will have to be experienced in surface mount removal and replacement. Feel feel to visit me. Thanks for asking.
May 25, 2013 | Hitachi Televison & Video
How do i connect the pc to the lg tv to watch a movie
Hello......Let's talk video....Your Tv has an S-video input and a VGA input....Chances are your computer's video card hay not have S-video output...It's small ,round...looks similar to a PS2 mouse or keyboard port.If it does...you can use the S-video(SuperVideo).If you computer is not equipped with this...You can use the VGA typacally used to connect the monitor to the pc...Depending how far apart the TV and the PC are..this can be easy...this determines the length of the cables you are to use...If you go with the S-video cable..It may be less expensive...if you go with the VGA cable..be sure to get one long enough...as far as the sound...since your tv has a VGA input...I may also have the sound input for your pc connection..This requires a cable with a 1/8" stereo plug on either end...You can connect one end to you tv and the other to the headphone jack on your pc....or you could just listen to the sound thru the pc fpr now....Let me know how this works out....I hope this was helpful....PEACE....
Jan 26, 2012 | LG 42PG20 42 in. Plasma HDTV
I can't get a picture on my tv from my laptop
I know for my dell laptop, you need to hold 'Fn' and 'F8' or CRT/LCD. It varies with model. It's one of those F buttons
May 06, 2011 | Computers & Internet
How i conected to my laptop? i have supervideo cable and sound but i dont see nothing......
Have you pressed "fn+(the button with monitor drawing in the keys)" ? Once you connected the cable in of the LCD to the laptop, you must press that first.
May I know the brand and model of you laptop so that i can assist you further?
Thanks.
regards,
longgee
Dec 27, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I want to hook up a Toshiba laptop to a Panosonic rear projection
VGA, and supervideo only carry the visual signal, so if you use one of this cables, (both the computer and the tv have to have the same output/input) then you have to have a cable attached to the computers audio output to carry audio to the TV. If your computer has HDMI output and the tv has an HDMI input, then that carries both visual and audio. When you attach the video cable to the tv, put the tv on that input source and the computer will sense the device and if the drivers are updated will fire the signal up automatically and give you the choice of using only the tv, or using both the tv and laptop monitor.
Sep 27, 2009 | Computers & Internet
Can you record back to the camera via the supervideo cable, if you can how do you do it?
only hardware support we can done that ex... pinnacle av dv ,snazi av dv
that two pci card r support s video composit dv also
Jul 31, 2009 | Panasonic NV-DS38 Mini DV Digital...
Vcr only plays in black and white
Hi Ryana,
Check if the recorder is set to output in 'S-Video' or 'SuperVideo' mode, if your TV doesn't understand S-Video you'll get a grainy B&W picture. The VCR should be set to output in PAL for the UK and most of Europe.
Hope this helps
Andy
Jun 26, 2008 | Philips DVP620VR DVD Player/VCR
How can I reset the Code Options Listed on Service Technicians Menu?
Option 1: f2
Option 2: 15
Option 3: 93
Option 4: cf
Option 5: 94
Option 6: c0
Option 7: 04
Option 8: 15
Apr 10, 2008 | LG RC797T
Can't get to the home screen
I've just solved that problem in the VSX 7000 of my girlfriend's Job.
Your VSX7000 has at least 4 video outputs, 1 for VGA and Supervideo 1 and Supervideo 2.
Firstly you should try VGA connector, because the main menu may be there, so you could change the configuracion.
If you can't see main screen in any of the output connectors you'll have to use the http tool.
In your internet browser enter the camera IP address, and you'll get the Web Interface of the VSX7000.
It will prompt you for user & password, the default options are "Admin" and your VSX7000 serial number (14 digits) you can find this number under the camera.
Once you're in the Web Main Menu, click on Site Map. There you can choose what you want to see in the screen of Monitor1 (My menus are in Spanish, maybe your menu says something like "screens" but I'm sure you'll find it)
If you choose Monitor/Screen 1 as Svideo, and select it as output for Local, Remote and Content you should see the Main Menu after the VSX7000 Reboots.
I hope it would be useful for you, if you have any problem with this let me know... This VSX7000 is working fine now, so yours should work!
Sep 19, 2007 | Polycom VSX 7000 Video Conference
System requirement
Windows 98 SE, "Millennium", 2000, XP (XP recommended) Intel Pentium or AMD Athlon 800 MHz or higher (1.5 GHz or higher recommended) 256 MB RAM (512 MB recommended) Direct X-compatible graphics card (ATI Radeon or Nvidia Geforce 2 or higher recommended) Direct X-compatible sound card Mouse CD-ROM drive Optional CD burner for creating Video CDs or SuperVideo CDs Optional DVD burner drive for creating DVDs
Aug 05, 2007 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
Philips DVP620VR DVD Player/VCR Logo
48 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
