Question about Panasonic PT-51G41 51 in. Rear Projection Television
Blue line trouble
I have a panasonic 51 in' tv ( pt-51g41) n there is a blueish rainbow line that from the bottom left corner-heading left to right - goes up like a rainbow and then back down. It seems to mirror the images on the bottom of the screen--kind duplicating it. any idea's on how I can fix this???
  • 63 Answers
Hi Kracka,
Are you able to post a picture of the problem?
It sounds from your description that it might be a 'convergence' problem which is when the red, green and blue parts of the image aren't alligned properly.
Check in your menu to see if there is a convergence setting.
Hope this helps
Andy
Posted on Jun 26, 2008
Panasonic 51" projection tv, green/purple rainbow across the bottom and the words at top of screen are bent up
Convergence it dead.Convergence ICS and all of it resistors must replaced to solved this problems.Know how to solders?Buy a convergence kit at Tv repair World.com,Tvrepairkits.com.Shop well cost u $300 for parts and labors.
Jan 19, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Convergence line will not move to match cross hairs
the green line will not move. it is stationery and red and blue have to adjusted to it
Jul 20, 2009 | Panasonic PT-51HX42 51" Rear Projection...
I have a rear projection panasonic 51" tv with blue curved lines
This can be repaired by a Degaussing coil from most TV repair places. If you haven't already you should shut down the TV and wait till it cools maybe 1 hour or so and then when you turn it on there should be a degaussing circut that might clear this up for you build into the set. Its not that strong a signal and usually takes care of minor discolorations. If it doesn't have that then a shop can come and take care of it pretty fast usually.
Mar 29, 2009 | Panasonic PT-51G36 51" Rear Projection...
Bluish tint that starts in lower left corner and goes across scre
i have blueish on right lower corner of screen.... what causes this
Mar 05, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Red and Blue slightly out of alignment
If constant all over the screen it is the static convergence that needs adjusting.
The green is not adjustable!
Move the red magnets with the blue covered with a piece of card to align with the green and then move the blue with the red covered to align with the green.
May 13, 2017 | Panasonic PT-51G41 51 in. Rear Projection...
Rainbow on the screen
Do you have any larger speakers close to you tv. Or any magnets been neer it. If you unplug it for a while the tv should have remove the rainbow
Aug 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT 47WX53 CinemaVision TV
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Problems with a Panasonic PT-51DX80
Your convergence ICs are bad. You need 2 of them they cost about 10.00 each. If you can solder you can do the repair in about an hour. hey are located on a real huge aluminum heat sink and they will have a number that starts with STK such as STK392-110. Let me know if you need ay additional info.
Jan 23, 2008 | Panasonic PT-51DX80 51" Rear Projection...
No picture, just red-blue-green lines through the middle of the screen very faint.
The PT-53WX54 is a standard projection set and does not have a bulb. It has 3 separate picture tubes. If you have lost the picture completely, not even on-screen menu, then something has stopped working in your set. It could be a video processor, vertical deflection or possibly a convergence problem. The set should be serviced by a qualified tech familiar with the Panasonic projection sets.
Aug 22, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Televison & Video Logo
70 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
