Question about Dryers
Dryer running cold
Have located the heater element on the back but cannot work out how to disconnect it - the cables run into the cabinet and there appears to be no way in !
Or, where is the thermostat? Can this be easily replaced?
  • clare-josh Dec 02, 2008
    I have a whirlpool tumble dryer model awz7813 service No. 857578115032. It is only running on cold. Is the problem the heater or the element? or something else?
    please help i have 3 kids and can only fit so much washing on the radiator to dry!!
    thanks
    President:
  • 1,462 Answers
You have to take side panel off to get at heater conections
Posted on Jun 26, 2008
My candy tumble dryer gov218-80 blows just cold
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or
overheating.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
OR you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposed to be if the motor does not run , the heater should not heat in order not to create fire but you said that even the motor is not running, the heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater.
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Oct 04, 2014 | Dryers
My LG dryer is blowing cold air and will not heat
Replace, High Limit Switch or Thermal Fuse.
Sep 19, 2014 | LG DLEX2550 Dryer
I HAVE A RED4340SQ1 ELECTRIC DRYER WHERE IS THE HEATING ELEMENT LOCATED
The heating element is located at the rear of the dryer behind the rear access panel. Disconnect power then remove the screws attaching the rear access panel to the cabinet and remove the panel.
Your dryer seems not heating but it doesn't mean the heating element is busted. The problem is obviously in the heating circuit which is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on the link below for the detailed procedures.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 27, 2011 | Whirlpool LER4634J Electric Dryer
Hello< My dryer is spinning no
The problem when the dryer runs but doesn't heat is usually caused by a failed high-limit thermostat and a blown thermal cut-off both located on the heater housing. Verify this by bypassing both parts for troubleshooting purposes then running the dryer.
Disconnect power then remove the screws attaching the bottom front panel to the bottom flange of the cabinet. Slide the panel down and off the cabinet to access the heater housing.
Remove the hex-head screw from the heater shield and remove the shield.
Disconnect the red wire from the thermal cut-off and the red/white stripe wire from the heater. Connect the red wire disconnected from the thermal cut-off to the heater terminal where the red/white stripe wire is disconnected from.
Reconnect power then start the dryer. The problem is indeed with the two bypassed components if the dryer heats up. Replace both the thermal cut-off and the high-limit thermostat and it should solve the heating problem. Do not use the dryer with those parts bypassed due to high risk of fire hazards. Let us know should you need further advice.
Jan 11, 2011 | Kenmore Dryers
My dryer won't turn on it works great but suddenly I can't turn it on. When I push the button to start there is nothing.
The dryer functions are all impaired if the motor doesn't run. The heating circuit is activated only when the motor runs because power to the heating element is routed through the motor centrifugal switch. The problem here is likely a blown thermal fuse because power to the motor is routed to it. The motor cannot therefore run if the thermal fuse is blown.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Dec 18, 2010 | Whirlpool WED5200T Electric Dryer
How do i change the heating element.
The heating element is accessible through the lower front access panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the two screws attaching the bottom of the lower front access panel to the cabinet then slide the panel down then off the cabinet. The heating element can now be accessed and repalced.
Remove the screws securing the heating element to the heater box then pull down the heating element to remove it from the heater box.
Disconnect and label the wires for the heating element and the components. Remove the components from the old heating element then transfer it to the new heating element.
Slide the new heating element up into the heater box and secure it in place. Align the slots on the top of the lower front access panel with the locating tabs on the front access panel then slide it into position and secure the bottom of the lower front access panel to the cabinet.
Apr 13, 2010 | Amana DLE330RAW Electric Dryer
No heat, but dryer turns.
There are three common causes of a dryer not heating. First is a busted heating element. Second, the thermal cut-off has blown. Third, the high limit thermostat is not working.
Disconnect power to the machine and remove the screws at the bottom of the lower front access panel (toe panel) holding it in place. Pull the panel down and off the cabinet. You now have access to the heating circuit.
Remove the heater shield by removing its mounting screw and pulling it off the heater housing.
The heater terminal block is located at the left opening of the heater housing. Disconnect the wire from one of the heater terminals and measure the resistance of the heating element using an ohmmeter set to X1. The resistance should read 7.8 -11.8 ohms. Replace the heating element if the resistance reads open.
Disconnect the wires from the terminals of the heating element and remove the screw securing it to the heater housing. Slide the busted heating element out of the housing and install the new heating element. Secure it with the screw and put the terminal block in place. Connect the heater wires and reinstall the heater shield.
Slide the lower front access panel up into the cabinet and secure it with the screws.
Feb 28, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer
hi Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
Step 1: Remove the back of the dryer. If necessary, also remove the cabinet top.
Step 2: Disconnect the leads and remove the screws that hold the duct in position. Then lift the entire heater unit out of the dryer.Step 3: Remove the screws that hold the heating element in the duct.
Step 4: Slip the new heating element into the heating duct the same way the old one came out. Be careful not to damage the resistance coils. Replace the screws that hold the heating element in the duct, reconnect the leads, and screw the unit back into position.
now see whether it is ok..............
Sep 12, 2008 | Dryers
Kenmore gas dryer 110.97566200 gas dryer is running throught the cycle but no heat.
Your Heating Elements could have problemA dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Troubleshooting the Gas Heater
In a gas dryer, heat is provided by a gas heater that is controlled by an air shutter. The gas heater is generally the source of no-heat or drying problems. You can often correct such problems by adjusting the air shutter on the gas burner, which is located along the bottom of the dryer.
To adjust the shutter, take out the screws and remove the panel that covers the gas flame. Turn on the dryer so the flame is burning. If the flame has a deep blue color and you hear air whistling around the burner, the air/gas mixture is receiving too much air. If the flame has a yellow tip, the mixture is not receiving enough air. Turn the thumbscrew or loosen the two screws slightly to increase or decrease the flow of air to the burner. Keep turning until the flame is a light blue color, without any yellow, and the whistling stops.
Gas dryers use an electric ignition device rather than a pilot light to light the gas heater: An element becomes hot and glows like the filament in a lightbulb. Electric ignition systems are always sealed; you can't adjust or repair them. If an electric ignition device fails, call a professional service person for replacement.
©2006 Publications International, Ltd.
In a gas dryer, heat is provided by a gas heater, controlled by an air shutter.
Electric dryers have self-contained electric heating elements.
Servicing the Electric Heating Elements
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher than 20 ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
The heater may also malfunction because it's grounded. To test for this, set the VOM to the RX1 scale and remove the leads to the heater. Clip one probe of the VOM to a heater terminal and touch the other probe to the heater housing. The meter needle should jump to a fairly high reading. If the needle flicks back and forth at a low reading, the heater is probably grounded and should be replaced. Here's how to replace the heater:
Aug 04, 2008 | Kenmore 63942 Dryer
Maytag electric dryer model DE410' Dryer motor runs normally and freely; N0 HEAT is produced by the dryer element. electric heat element presumably is not working. Cold air is emitted from the exhaust....
check all of those "relays", htey are thermostats, monitoring you temps, they should all have continuity through them if not its bad. (temp jump it out) just to see the element glow. TEMPORARIly.. you CANNOT leave any jumped out you will damaged something. HOUSE FIRE. just wanted to instill the importance of not leaving jumped out
Mar 23, 2008 | Dryers
Dryers Logo
Top Dryers Experts
Richard Roth
Richard Roth
