-   two weeks ago i could no longer use my hp ipaq6515c for texting out or receiving txt and also when using it to call someone they cannot hear me but i can hear them. this is now my dilemna. so somebody please help me. romsky-   romsky
Mine sometimes refuses to send text messages as well. When I hit the 'send' icon it flickers but nothing happens. The message remains on the screen as if I am still writing it.
When this happens I reset it. Usually one reset is enough but sometimes I have to reset it two or three times for it to work. (By reset I mean sliding off the battery cover and putting it back)
About the other person not hearing you I had this problem also but found it was a very simple thing - something greasy (perhaps food or something) had gotten into the tiny hole at the bottom of the IPAQ (near the connector) and was totally blocking out the sound. I just cleaned out the opening and it then worked fine.
Also be careful not to cover it with your finger. That happens often to me. I have now learned to move my finger when someone tells me they cannot hear me.
If that doesn't solve the problem for you then I'm afraid it is a faulty microphone and will need to be repaired.
Comments:
Sep 25, 2009
- Recenly I started having another problem with the mic - found it to be some problem with the connector for the headset. Plugging and unplugging the headset a few times seems to fix the proble.
(I answered in another post also because I forgot that I had already commented here about such a problem)
my pda charging port on the phone is damaged.The charging stems are bent and some are broken , is...
(More)
my pda charging port on the phone is damaged.The charging stems are bent and some are broken , is there an optional charging method i can use? Can i charge the phone through the ear phone port? if not where can i take my phone for repair ? I live in miami , fl
