Question about Hotpoint WMA76 Front Load Washer
Hotpoint WMA76 Ultima 6kg
I set the machine going on a 40 cycle on Sunday and found the next morning that it wouldn't drain. Neither would it start up a new cycle.
I could still get it to spin (then avoided this as it fills the drum with more water) but it still wouldn't drain.
I have since switched off the machine and emptied it. Would the problem be something to do with the filter and whereabouts would I find it? I checked the front bottom panel and behind it all there was was a solid metal plate.
I look forward to your response.
Kate
  • kat_newt Jun 26, 2008
    Full product info:
    Hotpoint Ultima 6kg WMA76 1600 Spin
    That's all I know. We got the machine second hand without a manual. Any help would be hugely appreciated.
  • Anonymous Feb 08, 2009
    hi ive just brought a ultima 6kg wma76 with out any instuctions could u help.
  • 23 Answers
Either you got a clog behind the drum or a clog in the draining tube behind the washer i would call sears or where you got it to get someone out there to check it out or if you got the manual of the washer and specs to see maintenance tasks that it requires if you know the make and modal i could get that for you ..
djkb
Posted on Jun 26, 2008
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Dec 29, 2010 | Hotpoint WMA76 Front Load Washer
Hotpoint ultima wma76 water level switch loaction?
Should be located under the lid near the top edge, round shape with a tube going to the bottom of it and wires in the front. To remove from the frame turn the whole thing 90 degrees as fitted with with rectangular fitting on rear.
Jan 21, 2010 | Hotpoint WMA76 Front Load Washer
Hotpoint wma76 stops and displays ON
Could be rinse water valve ..Faulty Solonoid coil
Nov 10, 2009 | Hotpoint WMA76 Front Load Washer
Hotpoint ultima wma76 stopped spinning is the motor /brushes in top or bottom of casing had other hotpoints and the brushes seem to go evry 5 yrs or so? are they as easy to change as the older models?
it is as easy as the older modles but the motor is at the bottom and you have to take out the motor to replace the carbon brushes hope this helped.
Aug 29, 2009 | Hotpoint WMA76 Front Load Washer
Hotpoint ultima
The filter is located in the sump hose at the rear bottom of the m/c.
You need to remove the large clip that holds the hose on
Access is gained by removing the lower rear panel.
Oct 25, 2008 | Hotpoint WMA76 Front Load Washer
Hotpoint ultima wma75
sounds like the filter is blocked you can take the filter out and clean it and check the hole for lint a sock or a coin etc. if this helps please rate me joe
Aug 06, 2008 | Hotpoint First Edition WMA12 Front Load...
Washing Machine
Which symbol is illuminated? Red keyhole? Child safety? Red tap? End status?
Jun 27, 2007 | Hotpoint WMA76 Front Load Washer
Error E15 - MAchine not draining
drain is same wehatever the program. filter is likely blocked. access is not that easy. take off panel at bottom rear. filter is in pipe from bottom of tub to pump. undo this pipe, take out filter. you may have water everywhere so be carefull
Nov 10, 2006 | Hotpoint Ultima WD72 Front Load...
Hotpoint WMA76 Front Load Washer Logo
794 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
