Question about ViewSonic Computers & Internet
The image on the monitor is corrupted; it flockers, ghosts (3 images on the screen), and you can see the image 'rolling' around, icons jumping around - you don't know which image is 'the real one' and if you have pages open with more colour content - the image is broken up much more, so much so that all you see are the horizontal lines of independent colour across the screen; no words are discernable. Only started recently and I need help as I have a big project I'm working on? Can you help? Thanks
  • 43 Answers
To help you i need to know the video card config, your operating system, it can be with the video card drivers, virus/ or the monotor has gone bad. try receating the monitor cable.
Posted on Jun 26, 2008
Double image on screen
Usualy in these cases I check the VGA cable. If you can buy new one, but not cheap one will solve the problem. Just to be sure that this is your problem hold the small vga cable cylinders with your hands for 5-6 seconds. When you release them you shouldn't see the ghost image on your screen. It sounds weird but it works. By holding these cylinders you remove the static electricity of the cable. Try to understand what device around your monitor causes the problem. The cause also may be lot of power cables or power sources near the VGA cable.
Dec 18, 2011 | HP 2009M Monitor
I get ghost images. Is there a way to de-gaus an LCD monitor?
Sounds like it's either ghosting, or image persistance.
Ghosting on LCD monitors is usually caused by interference via the monitor cable. Try moving your monitor cable so that it doesn't pass near any other cables or electronic devices. If that helps, then position the cable away from the others perminantly or replace the cable with a "shielded" monitor cable.
Image persistance on an LCD can be caused by leaving it on with the same image for a very long time. The pixels don't exactly "burn-in" like on the old CRT monitors, but over time, they can develop a memory that causes them to change color slowly or incompletely. Prevention is best (turn the monitor off when not in use, or use a rotating screen saver.) But if it is already a problem, you do have a few options. You can turn it off for a long time, run a rotating screen saver for a long time, or display a solid white screen for a while. Another technique is to create a slideshow in the Windows screensaver with a solid white image and a solid black image (create them in MS Paint and save them where you can find them later.) Let it alternate between the white and black screens for a while and check to see improvements.
Jan 11, 2011 | Envision EN-7100e 17" Flat Panel LCD...
My screen develops some ghost images after powered up for a few hours. I can actually see some words that appear almost burnt into a screen. Similar to a monitor that has been left on too long if someone...
well you are correct and when it come's with the lcd monitors it is known that when a pixel is subjected to same amount of charge for a long time it might retain the residue of charge even after the amount is changed so this reason why you get this problem and in order tackle this just try to use some changing screen savers or just turn the monitor switch off while you are not around it.
good luck.
Jan 06, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
Ghost images and vertical lines on new FPD1775W monitor
You going to need a new logic board inside witch controls the signals from your video board on your computer. that is the only fix there is that i know of and I been around the block a few times with gateway.
thanks please do leave postive rating and feedback Thanks
Oct 09, 2009 | Gateway FPD1775W Monitor
Ghosting of images and buzzing when on mostly white screen X2gen 19" monitor (HP/Vista )
Please bring the unit to an authorized service center as there's an internal electronic part/s of your monitor that is cold soldered / defective. regards
May 27, 2009 | X2Gen MG19VT 19" LCD Monitor
Ghost images
Yes the images where left on the screen for a long period of time which burnt the images you see into the screen
Mar 10, 2009 | Samsung 2220WM-HAS Monitor
you need to replace both convergence ICs they are STK392-120 you can get replacement ICs and free instalation instructions at the following link.
Jun 05, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Good picture for 30 seconds then screen goes black with a faint ghost of the image
the 12V is for speakers.. the 245bw takes regular 120V AC (same cord as your computer)
the buzzing is annoying, though. i don't know if it's a "feature" or just a side effect.. ie, if i could take the case off and poke around, i would. 4 times out of 5 it's some dumb piece of tin reverberating from a transformer or something..
Dec 03, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Ghosting image after 3 years of perfect operation
ghosting is a memory problem, the monitor has a memory chip this helps with the video rendering to display the image, the chip can over time become damaged like any other memory chip, its its read use delete type but some times it can take longer to delete this then gives you the ghost shadow. it can sometimes be the software glitching, but there is no way to fix the firm wear on the monitor as the chip is pre programed before the monitor is assembled.
Aug 11, 2017 | Hyundai ImageQuest Q995 19" CRT Monitor
Computers & Internet Logo
88 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
