Question about Dishwashers
I have a 10 year old Electrolux Dishlex Global 300. It doesn't complete a cycle, beeps many times then all lights go off and it stops. Then you cannot select a program to restart. It then beeps consistently throughout the day when not even in use. A repairman has tried adjusting electric wire connections, the door handle and checked for motherboard diagnostic faults (which shows nothing). Any ideas?
    Problem Solver:
  • 9 Answers
Hi mndl, it sounds like what happened to mine, it was the flood switch F1good luck slappa
Posted on Jun 26, 2008
Hi, I have a Dishlex Global 300 which has just stopped powering. The power supply is fine ( I plugged in other appliances and they work) but the machine is just dead, no lights, no sounds, nothing. The...
hello it,ll will be the on/off switch easy to replace and costs about 10-15 bucks youll probally see a char mark on the connector, where it over heated and shorted out.
May 11, 2010 | Electrolux Dishwashers
Dishlex Global 300 starts to fill with water, then
ok this sounds like your water has stopped coming in or timed out b4 the pressure switch is activated. hold eco button down, u will hear a beep then a light will come up, keep pushing the button until u see the light.reply and tell me which light has come up, and i can help u fix the problem.
Apr 24, 2010 | Dishwashers
Dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Feb 07, 2010 | Electrolux Dishwashers
Hi, My Dishlex dishwasher DX 302WB ia showing 10
check this
1)blockage in boiler tank.(cleaned)
2)water pressure is less.(check solenoid filter)
if it's programmed in timer mode within the period it must reach the water level in the tank due to this also it may happen.
Jan 06, 2010 | Electrolux Dishwashers
Not disolving powder thru cycle
This may be a problem with the powder that you are using. It may also be a problem with the temperature of the water that is coming into your machine (not hot enough).
You may want to try a gel type detergent.
If you need more help, post a comment.
Thanks,
Tim
May 29, 2009 | Electrolux Dishwashers
Pump motor runs continuously, ''Eco'' flashes continuously
Hi
soyunds like it flooded the base
You need to dry out the base of the machine thoroughly and it should re set
Feb 14, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Hi. I have a Dishlex global 300 series and it starts going through the cycle ok but after about 5 minutes it starts to fill up again and the eco light starts to flash and it won't stop filling up and...
The operating manual says under problem solver thatin such a situation it has an incorrect fill level or fill time and recommends then the need for a service agent.
Try holding the start and programme buttons down at the same time until the machine beeps. This will reset it in case it is just a computer problem.
Apr 30, 2008 | Dishwashers
Dishlex global 300
try holding the start and program buttons simultaneously for a few seconds, it seemed to reset itself for me-i have done this a few times now.
Feb 04, 2008 | Dishwashers
Tank is leaking
Is it the tank or just the door seals? Ours was leaking recently, there was an obvious tear in the door seal. Once fixed no probs.
Nov 02, 2007 | Electrolux 23 in. ESL624 Built-in...
Dishwashers Logo
238 people viewed this question
Top Dishwashers Experts
