Faulty wireless connection due to 2nd D-Link installation
    Novelist:
  • 148 Answers
If you are refering to a loss of signal this is ocurring more and more as we get into the wireless age. You need to play with it by switching the router channels. You can access the router by going to your internet explorer and in the address bar type the router url I/E 192.168.1.1 or whatever the manufacture recommends Most passwords are provided by them. You can onlu access the router through a wired machine generally in port one of your router You will find the channel settings in the advanced section of most WAN areas of your router. There is also a setting on some for increasing the signal strength. and one last trick if you have neighbors that are "jamming" you place your router on the floor intead of higher up . Good luck.. Be mucho Blessed...Mark
Posted on Jun 26, 2008
I have d-link dual band router dir-815 and i can connect on my vista laptop my other desktop xp and xbox360 wireless all no problem but on my hp desktop windows 7 it asked to enter my key twice ok the...
Since this is a desktop PC that has Windows 7 OS, there might be a possibility that the issue is on your wireless adapter. As we all know, desktop PC's has no built in wireless card on them, so you need to install a wireless USB adapter on your PC. Of course, 3rd party wireless USB adapters has their own wireless utility to manage the wireless connection and that is where you need to put in the infos about your wireless connection. You didn't mention if on the 2nd part, is it asking you to re-type your wireless passphrase or is it asking you for a WPS pin.
Sep 14, 2011 | D-Link DIR-815 Xtreme N Wireless 802.11N...
How to set up wireless network connection can't conect to the internet
1st If the wireless card driver is not installed then the driver.
2nd. Check Device Manager to see if the wireless card is working and enabled.
3rd. Configure the wireless card with the Wireless router's wireless settings, ie, SSID, WPA or WPA2 encryption etc.
4th Connect your DSL or Cable modem to the WAN/Inernet port with a LAN cable.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Mar 11, 2010 | IBM ThinkPad A31 Notebook
I have just got a 2nd computer in my home, and i am trying to set up the internet, but i do not know the security key/passphrase? how do i reset my router to get this information?
The router's SSID, passphrase (ie encryption) is configured in the router's wireless configuration. This information is needed to configure the wireless card in the 2nd computer so it can connect to the wireless router.
Please click on this link for my instructions on how to secure your wireless network, configure the wireless router and the wireless card in the 2nd computer ;-
Jan 31, 2010 | Arris SURFboard® SB5101 Cable Modem
Can't connect to internet- wired network -2nd computer works fine - OS XP
I have installed intex 8139D RTL lan card drivers are installed.in divice manager it will showing the device is enabled. And it will showing lan is connected. but when i change from workgroup to Domain it will showing an error message. to communicate with domain.How to solve this problem.
Jul 05, 2009 | D-Link DFE-530TXP Network Adapter
When I installed my Linksys WUSB54GSC Adapter my computer will not boot up. I have Windows Vista. The computer is new.
Disconnect the usb adapter and see if your computer still boots up. If it does, try connecting the adapter on another usb port and see what happens. If your PC will still not boot up using another usb port, try the adapter on a 2nd computer. If 2nd PC fails to boot up when the adapter is plugged in, most likely the adapter is faulty.
Jul 01, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Laptop wireless computer on 2nd floor. Modem and
To test it whether the signal is too weak or not, take your laptop closer to where the router is and try to connect that way. If it does connect then the wireless signal from the router is too weak in which case get a range expander or purchase a router with extended range.
Mar 23, 2009 | NetGear WGR614 Wireless Router
Stronger Wireless Signal with 2701HGB Router?
Netgear's web site has an excellent tutorial on how to do this. It involves turning off the DHCP on the Netgear, and linking the LAN prots of the two routers. There is no connection to the WAN port of the Netgear.
Here's the link http://kbserver.netgear.com/kb_web_files/n101236.asp
Carl
Jan 02, 2009 | 2wire 2700HG-B Router (2700HGB)
Can't connect 2 pc to 1 printer
Steps to fix your issue
  1. install printer driver on one computer
  2. Make sure both computers are connected in same network by ethernet cable or wireless connection.
  3. share the printer on 1st computer
  4. access the shared printer from 2nd computer through network
This way your can access one printer from 2 computers. This setup work only when the 1st computer is turned on because HP leaser jet don't have the capability to work as network printer as they cannot acquire IP address.
If u need further information on how to configure 2 computer please refer below link
http://www.ajcsoft.com/connect_computers_together.php
For information regarding how to share printer on windows XP refer below link
http://www.microsoft.com/windowsxp/using/networking/expert/honeycutt_july2.mspx
Dec 30, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Losing internet connection on d-link wbr 1310 every so often as like 10min-1hr on wireless
There could be a number of reasons as to why the connection is being lost.
1. You could be too far away from the router to pick up the wireless signal clearly - and atmospherics can effect this more. 2. The ADSL filter could be faulty or not installed. 3. The ISP could be dropping out.
You could try plugging in with a cable and seeing if the problem persists (in which case it probably isn't the wireless link)?
There are some LED indicators on the router to help with the diagnosis.
Dec 10, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Computers & Internet Logo
David Payne
David Payne
