Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
TV turns on randomly
I have a Sony Wega Trinitron 27". This is actually my second. My first had all the issues with the TV not turning on and I recycled it. A friend of the family had the same TV, but was upgrading and offered it to me. I know this is going to sound odd, but it turns on at various times of the day. I notice the morning times mostly and the times so far range from 4:20-9:30am, no consistency, different every day including weekends. I also have come home to find it on. I have checked the "timer set" function multiple times and it is not on to the best of my knowledge and just in case it is, I have changed both timers to 2pm which has not affected the random turning on times. The previous owner only used it for DVD's and CD playing and has reported no anomalies like this one. There are no pets, the remote is kept in it's holder at night. It is on a surge protector and on very even and solid furniture. Would a factory reset of the TV help? If so can I please have directions to do so? Any thoughts as to what could cause this? I'd prefer to not have to remember to unplug it whenever it is not in use. Thanks so much for any insight!
  • luv2ski752 Mar 02, 2009
    I have the same problem with a 60" Hitachi Ultravision.  I can't even find a timer in the menu or manual that says auto turn on or anything like that.
  • 23 Answers
Have you tried to put it on a different outlet i acutly had a problom one time with the outlet in my house i had a printer on a timer but the timer was defective and the printer would turn off and than on its crazy so i took it off the timer switched to a new outlet and worked fine.
try that and see good luck
djkb
Posted on Jun 26, 2008
Problem with the Sony FD Trinitron WEGA KV-27HS420 27" TV WHEN TV IS TURNED ON IT SHUTS itself off in a second or two and a light on front blinks 6 times.
Most of the time this is caused by two ic chips on the circuit board, ic8001 and ic8002. These are components that can be replaced fairly reasonably. If you call a repairman it should cost 95-165 us dollars. However, this is just an educated guess. Good luck, Russmann.
Apr 29, 2011 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Describe your Sony FD Trinitron WEGA This started
I have the exact same problem. If you get anywhere (I can't) please contact me at tbiasi@hotmail.com. If I figure it out, I'll get back to you.
Good Luck.
T
Sep 09, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony Wega 27in Randomly Has Block Box Appear On Screen
this means the TV having picture upper part of the screen. problem may be -15 V to vertical deflection ic suddenly gose off and system control gose to stand-by mode resolder vertical out ic , -15 v supply line from the fly back and system control .
Jan 15, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA..won't turn back on
Please post the blink count. The standby light should be blinking a repeated count. That will indicate the circuit where the problem resides.
Thanks,
Dan
May 19, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Trinitron TV takes multiple manual clicks to turn on.
If you mean the actual mains switch needs multiple cycles, it could be faulty.. does anything, say a power indicator, come on when the TV doesn't?
If the actual switch is OK, then you probably have a fault in the power supply section... often faulty electrolytic capacitors. U need service.
Mar 26, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Turn on problem
Hiii...
I hope you have experience with repir TV because you have common problem whit high voltage on tv board.....
What chassis of you TV set have ?
I hope hear from you soon....
[Vrya]
Feb 17, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony trinitron wega KV-XR TV
Activate / de-activate by pushing display button on any Sony
remote control........................T.
Jan 07, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Wega KV-27FS100 RANDOMLY Turns itself ON
You said around 4pm TV is switched on everyday. Check in menu options any on-timer and off-timer is changed. If it is not there is a problem in microprocessor section. EEPROM ic malfunction also shows these type of symptoms. But it can be done by Technical persons only. This is not a major problem. This is due to surge current and lightening like that.
Sep 06, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
90 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
