posted by swimflyrun on Jun 26, 2008
Hi, The far left light on my magic delux has come on and this has never happened before. At the same time the water is not properly coming through the expresso section properly.... Thanks for your help
Comment by swimflyrun, posted on Jul 04, 2008
Thanks solved it the internal component of the machine wasn't inserted properly. A wiggle on the side and re closing the door fixed...
The instruction manual helped which was found in these comments thanks again
Suggest a new solution for this problem
Post a New problem for Saeco Magic De Luxe Espresso Machine
Email this problem
Email this problem
Can you Help with these Coffee and Espresso Makers problems?
my krups orchestro coffee...
my krups orchestro coffee... Answer This...
Water does not pump through
Water does not pump through... Answer This...
Wet Steam? Weak Espressos
I've always had drops of water... Answer This...
need replacement gasketor seal...
need replacement gasketor seal... Answer This...
Repair Service
Find Coffee and Esp. Repairman Near You:
