Question about HP Pavilion tx1000z Notebook
ARCHIE I buy a HP Pavilion tx2115nr notebook few days a go in Best Buy, this was the last, so it was the only one in the stock. That's mean that it was already used. Now I want to uninstall the sofware ARCHIE, but I dont know how to do it, a try a couple times, but the sofware ask me for the original CD, and obviously I don't have it, can you help me?
  • 5 more comments
  • jzapata Jun 26, 2008
    I don´t know for what is the ARCHIE sofware, it was installed for Best Buy, kind of demostrate sofware, but every time when I turn on the computer or restart, the sofware run again and take to long to let me work. besides that, doesn´t let me change the user, and this is very annoying.
    The solution that you gave me, doesn't work, because, just like I told you, when I try in your way, the sofware start to unistall, but after a couple seconds, a box appears with the next text: ARCHIE uninstall, Please insert an Original ARCHIE disc now, so, i can´t uninstall this program.
    If you have other solution, please help me out.
    Thanks
  • Anonymous Jul 06, 2008
    Same problem. Bought an open box
  • PEXERO Jul 09, 2008
    SAME PROBLEM!
    Thanks.
  • henry V Jul 12, 2008
    Yes, I'm having the same problem on an open box model running Windows Vista.
    ARCHIE is really annoying, and (I think) the software is blocking my network access among other things.
    I've tried every uninstall method I can, but I get the same "insert original CD" message.
  • Victorjain Jul 14, 2008
    I have a very similar problem. Brought a Tosiba notebook from BestBuy and since I was travelling next day outside USA, did not had much time to check my purchase. Now I am unable to Uninstall the software and am not even near a Bestbuy store, where I can go through. I had clearly told the BestBuy salesperson that I would be travelling next day. Never in my dreams I had imagined would be stuck like this.
  • jzapata Jul 22, 2008
    Hey buddies.., I just format the computer and re-install everything again, it was the easier and quicker solution that I found. Now I am enjoying my new laptop. Does somebody have another solution?
  • Anonymous Mar 13, 2009
    I have the exact same problem but none of the fixes work, formatting the hdd and reloading doesn't work because I cant make a rescue or restore disk until i get rid of this software if I have to pay Best Buy for this I will never spend another $1 there ever
A.R.C.H.I.E. is the demonstration software used on all Windows-based PCs sold at Best Buy that are used as demonstration units. The software is not designed to be installed on any PC other than those being used within the store.
Unfortunately, the removal of A.R.C.H.I.E. without the original disc (which is provided monthly to the stores from the corporate offices) is going to be nearly impossible. You have two solutions in this case:
1. Utilize the PC's recovery methods (most likely recovery partition, however you might have a model that came with recovery discs as well. The A.R.C.H.I.E. software prohibits most recovery disc creators from working properly). Note that for this method to work, you must be able to start the recovery process outside of Windows.
2. Bring the computer (along with its AC adaptor, if it is a laptop) to any Geek Squad precinct (any Best Buy store or standalone Geek Squad) for uninstallation of the A.R.C.H.I.E. software (without damage to the underlying operating system). This should be a free service as it is THEIR software running that requires removal for normal operation of the computer, and per company SOP should have been removed prior to sale. This is the preferred method, however you might not have access to a Geek Squad precinct and need it done before you will have access to a precinct again.
Disclaimer: Answerer is currently employed by The Geek Squad. The opinions and statements in this answer may not reflect the views held by Best Buy or The Geek Squad. Official communications from these companies may be obtained from http://www.bestbuy.com/ or http://www.geeksquad.com/.
Posted on Apr 24, 2009
The software is loaded on all display model computers at BestBuy. The only way to remove it is with the original disc. Take the computer back to Best Buy Geek Squad and they will take it off at no charge. This should have been done prior to them allowing the computer to go home with you.
Posted on Jul 08, 2010
    Novelist:
  • 148 Answers
First off what software are you trying to uninstall and what os are you using. I f this is a new purchase and it was being used to demonstrate the computer it can be removed two ways (1) In vista the Icon is in controk panel and is marked programs applications, that is the normal way if this does not work go to start and directly above you will find search enter the name of the program and it will appear in the box above when you see the program you wish to remove right click the program name and delete it. It may be necessary to delete more than one application associated with that program. CAUTION!!! Do not remove any system application files as this may damage the O.S let me know how you did and good luck... Mark
Posted on Jun 26, 2008
  • Mark Doyle
    Mark Doyle Jun 28, 2008
    I am going to get together with best buy and see if I can come to a solution for you please stand by and i'll get back to you. Hang in there we'll get it...Mark
How to install bluetooth on hp pavilion dv6 laptop?
If you want the stock bluetooth module you will have to either call hp and buy it from their spare parts dept. or go to a site like ebay to buy it. after you have acquired the card (and cable), you will need to disassemble the laptop and install the card in it's designated spot(I think it's located near the right had corner closest to you as you look at the laptop in it's normal use orientation. The alternative to this is to get a usb bluetooth card.
Aug 14, 2014 | HEWLETT-PACKARD Pavilion dv6-3225dx...
My hp laptop won't come one....help! it is a HP Pavilion dv6000 laptop.
Some times its the power cord if you go to your local best buy you can buy one and test.. if its not just take it back ;) But I have seen lot of the these hp pavilion motherboards go out and the Bord cost so much its about the same price as buying a new laptop.
One other thing I would suggest check your warranty go to the link I provided you can check it there. http://h10025.www1.hp.com/ewfrf/wc/weInput?cc=us&lc=en .
Best of luck let me know if this helps.
Mar 07, 2011 | HP Pavilion dv6000z Notebook
Best buy left Archie on computer. when i try to delete it it ask for the disk wich I dont have. Is there another way of deleting it with out having to go back to Best buy
Have you tried removing it from the control panel, add/remove programs? If that does not work, it can be removed via the registry.
Jan 26, 2011 | HP Pavilion tx1000z Notebook
Can I upgrade the memory on a HP pavilion dv5020us PC Notebook?
everything is possible in luve n war and of course in computers :) u have to take your laptop to the HP customer care centre
Sep 13, 2010 | HP Pavilion dv5020us Notebook
ARCHIE
ARCHIE is a Best Buy program that must be uninstalled in the store.  Take the unit back to the store you bought it from and have the Geek Squad unistall it.
Nov 29, 2008 | HP TouchSmart IQ770 PC Desktop
Laptop upgrade
Hi there i worked for hp for a few years im pretty sure you cant upgrade the graphics but ram is no probs you need to know what type of ram is currently installed ie.ddr1 or 2 i dont think that unit has sdr ram on board hope this is a help to you
Jul 30, 2008 | HP Pavilion dv6000z Notebook
UNINSTALL DE A.R.C.H.I.E. Program
Though Best Buy should of removed that for you, Sony has a hidden recovery partition that will restore everything to factory settings wiping your hard drive of anything you have now. When you boot up your computer press F12 to enter the recovery manager....If it's not F12 try F11, They are different for each manufacture.
Hope this helps.
Jul 09, 2008 | Sony VAIO VGN-S460 Notebook
ARCHIE Removal
It should have been taken off at time of purchase.
Go to Best Buy Geek Squad with your receipt proving you bought it and they'll remove it (it should be for free, otherwise complain cause you should be notified by the salesperson that you need it removed).
Only best buy can remove it with their disks, if you try uninstalling it it'll reinstall itself.
Source: i work there.
May 12, 2008 | Dell Inspiron B130 Notebook
HP Pavilion A6130N setup error
Did you buy the computer new? It should have come with recovery disks, also called operations disks. I have had to do this with my hp pavilion lap top a few time over the past few years so that it would run faster. If the recovery disks aren't in there, call the company. They are always supposed to be included. I've always had good luck with hp, you might even go to hp's website. It's really good as well.
Dec 27, 2007 | HP Pavilion DV4015cl Notebook
Computers & Internet Logo
6,157 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
