Question about HP LaserJet 2200dt Printer
My printer is wasteful
I'm using hp laser jet 2200 and its printing test paper many times but doesn't print what i commanded. will pliz help urgently!
    Genius:
  • 2,785 Answers
Plz try by reinstalling the drivers
Posted on Jun 26, 2008
Maths equations cannot print properly by my HP Laser Jet P2015, all equations are jumbling at the centre
if ur using pcl driver try with ps driver other wise make it pdf and try to print
Dec 09, 2012 | HP LaserJet 1200 Printer
HP LASER JET 2300 52.00 ERROR
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
4. Replace the engine board.
Tallon41
Sep 12, 2012 | HP LaserJet 2300 Printer
We want to purches a laser printer for printinhg legal size paper,which printer we use
Hello
You can any of HP laser Jet with your budget for legal size printing, all printer can print legal size printing, however there are some printers for quick reference.
HP 1008 Laser jet printer
HP 1505 Laser jet printer
HP 2035 high resolution printer
good luck
Dec 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
Wasting alot of paper printing out on Hp Designjet 500
Step 1
Inspect the paper trays to make sure they are not overloaded. To determine if this is the problem, do a test print with only one piece of paper loaded in the paper tray. (If this turns out to be the problem, keep the paper tray half-full in the future.)
Step 2
Check that the type of paper being used falls within the printer manufacturer's recommendations. For example, paper designed for ink-jet printers doesn't necessarily work well in laser printers. High-quality, bonded paper will cause paper jams in some printers; look for bonded paper that is "laser and ink-jet compatible."
Step 3
If someone has recently printed labels on this printer, check to see if a label has come unglued from a sheet and become stuck inside the printer.
Step 4
Check the gears and rollers for stuck shreds of torn paper from previous jams. Turn off the printer before you attempt to remove the bits of paper.
Step 5
If you have a laser printer, inspect the printer's paper rollers. They should be smooth but not shiny. Rollers that are cracked or glazed are a frequent cause of paper jams and should be replaced by a technician.
Step 6
If you have a laser printer, try cleaning the printer's paper rollers with a lint-free cloth and isopropyl alcohol (available at electronics shops or drugstores).
Step 7
Try changing the toner or ink cartridge.
Step 8
If you hear a clinking sound during printing, your printer probably has a broken gear and needs to be serviced by a technician.
Nov 19, 2009 | HP PRINTER,DESIGNJET 500 42'' InkJet
My HP Business Inkjet 1200 printer always prints
Some of print heads may be failed.First clean very well the contacts on the print heads and printer using piece of cotton and some alcohol.If not help look which color don't print and replace that print head.
Nov 16, 2009 | HP Inkjet 1200dn Printer
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
URGENT-- engine test problem in HP LaserJet 5000n
iam using hp5000n laser printer. It is giving 13.1 &13.3 error messages freequently. (This is paper jaming problem)
May 23, 2008 | HP LaserJet 5000n Printer
Hp laser jet 1010
Dr.M.subrahmanyam
1. This printer is not specifically a postript printer. It uses HP PCL printer control language, according to HP it does not support Postcript, see the table on page 15 of this pdf file: http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00442162/c00442162.pdf page
2 Screen prints are not directly sent to the printer. They are copied to the Clipboard - you must open up another application which can access graphics - WordPad , Word, Excel. E.G from wordpage paste the screen print (using Control + V or Edit-> Paste) and the contents of the clip board will appear in the document - use the print option from wordpad to print this graph to your HP 1010 printer.
Feb 21, 2008 | HP LaserJet 1010 Printer
HP Laser Jet 2200 dtn - Print Quality
For troubleshooting "ghost printing" use "LaserJet 2200 repetitive defect ruler". Measure the distance of 'ghost' figure from the 'original'
Try this link:
http://www.printertechs.com/tech/repdef/ruler2200.php
Jan 05, 2008 | HP LaserJet P2015dn Printer
HP LaserJet 2200dt Printer Logo
Ben Johnson
