Question about Lexmark E342n Laser Printer
Lexmark E342n Laser Printer Fuser Error
Hi I got a lexmark E342n Laser printer im tray to print but they got a error messages message is: Fuser Error Error code is 920 can you help me to fix my printer what can i do for fix that problem. tenks for help
  • philbo79 Aug 26, 2008
    how do i do a fuser service check?
  • cristian martinez Jul 18, 2013
    im change the fuser in this moment but say error 936 service transport motor
  • Lexmark Master
  • 13,433 Answers
920 Fuser Error
Indicates that the fuser is below temperature when printing
Do a Fuser Service Check
Posted on Jun 26, 2008
  • marioviela Oct 18, 2010
    oi bomn dia eu mario gostaria muito de saber se o erro 920 pode ser o sensor que enconta no rolo de teflon
Lexmark T640 printer will not print- get message- media tray empty
Check if the paper tray has enough amount of paper in it. If it has, check if the paper guides are correctly placed and is set to the correct media size.
Aug 02, 2012 | Lexmark T640 Laser Printer
Load try1 plain letter error on display screen appears on lexmark e342n
If printer is connected to a network, type the printer IP address into the address field of your Web browser. Click on Configuration and select on paper menu and make you have the correct settings. Make sure you selected the correct paper source and paper type.
Make sure on your application, the print settings matches with the printer. Check the print settings of the application that you are using. For example if you are using Microsoft Word, you need to click on print and click the properties button and go to the paper tab.
From the Paper Tab window you can modify the Input options like paper size and the source (paper tray). You may click on the drop down and select "Automatically select" for paper tray and select "Use printer settings on paper type and then click OK.
For further assistance, please contact Lexmark Technical Support.
Jun 01, 2011 | Lexmark E342n Laser Printer
My printer lexmark e342n 201 jam error code, what the are problem, fuser or pick-up roller and how to soft that problem. tq
If you are getting 201 error code, it means a paper jam has occurred. To fix this problem please Open the front door. Remove the toner cartridge and remove the jammed print media.
Click on the link http://bit.ly/p1jJcd to see instructions on how to go about the procedure.
Jan 22, 2011 | Lexmark E342n Laser Printer
I have just bought a new Lexmark C543dn laser printer. When I powered it up it has 122.03 error code showing. I have switched it off and on again but still the same. It is plugged into a proper socket and...
Problem 122.03 error; 122 error; Fuser error Solution What the error means
The 122.03 Error indicates that the printer's fuser unit is heating up either too quickly or too slowly.
What to do
This error normally requires a service call. However, certain rare occurrences, such as a a power fluctuation or a stray static discharge in the vicinity of the printer, can cause a false 122.03 error message to appear. In these cases, the error is only temporary and can be easily resolved without service. Follow the steps in the table to test this.
If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Did the error message return?
Yes: Continue to Contacting Lexmark below.
No: Print a test page. If the page prints, the printer is functioning correctly.
http://support.lexmark.com/share/index_ca_en.html
Jan 02, 2011 | Lexmark C544dn Laser Printer
The printer message is 202 paper jam open rear door. There is not a paper jam in the printer.
These are the messages got stuck in print queue, you have to release the print queue, First got to Printer and Faxes, there would be your printer icon (Lexmark E342n) Laser printer icon, double click on that, you would see all the messages stuck in queue, release or delete from there. that has to work, please let me know if it works or not
Nov 01, 2010 | Lexmark E342n Laser Printer
Error 84 replace photoconductor
Here's a link to the Lexmark website to guide you on how to replace the photoconductor kit on your Lexmark E342n laser printer. Just click on this link: http://bit.ly/bh5TKi. Follow the instructions carefully. Don't ignore IMPORTANT! and NOTE messages. Hope this helps. If you need more assistance, leave a comment so I can get back to it. Thanks.
Apr 19, 2010 | Lexmark E342n Laser Printer
Lexmark E 342 n paper jam with error code 201
According to the LexMark support page, this is most often related to not getting the print cartridge assembly properly positioned. (Left and right sides not fully in place). Another possible source is paper in the output tray when using the double sided printing feature. (This leads to grabbing an extra sheet when it tries to retrieve the paper to print the second side. Paper stock thickness will change the number of pages printed before this happens.).
I hope this helps.
Sep 03, 2009 | Lexmark E342n Laser Printer
I have a Lexmark E450dn displaying a "935.15 Service Printhead" error message and will not print. Seeing as Laser Printers do not have printheads, instead they have Scanners and Fusers, which should I be...
a 935 printhead error is a fatal error which means the scanner motor has failed to initialize. the term printhead is short for printhead scanner. this error can be caused by either the engine board or the scanner % wise 40%engine board 60% scanner ive done 120 repairs on lexmark laser for the last 7 years trust me one of these is the problem
Jun 16, 2009 | Lexmark E450dn Laser Printer
PAPER JAM ERROR MESSAGE
your sensor flag in the back is broken or missing
Jun 05, 2008 | Lexmark E342n Laser Printer
31 missing or defective cart.
Try changing the photoconductor kit
Jun 02, 2008 | Lexmark E342n Laser Printer
Lexmark E342n Laser Printer Logo
1,573 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
