Question about Optoma EP719 XGA DLP PROJECTOR 2000L 2500:1 CONT DVI-D WITH HDCP Multimedia Projector
Optoma DLP EP719
I am in Delhi India.
I have this projector that stopped working. Lamp does not get on.
Changed the lamp replaced new one. Still it does not glow.
  • 5 Answers
Try this: There is a stuffed 10v 3300uf capacitor on the power board. You need to replace it.
Bellow you can check in the picture where the capacitor is located.
Notice that in this picture I have already took the bad capacitor out and replaced with two small cords to reach the bottom and test the new capacitor.
To reach this place is not fast, several layers of plastic and metal must be removed, but is not a hard task to take the capacitor out and replace it for another.
It works just great! Now it is back on track with awesome image.
Posted on Oct 03, 2009
I've replaced the correct lamp and filter to the projector but it will not do anything
Try replacing the lamp igniter that creates the high voltage to turn bulb on.
Mar 01, 2016 | NEC NP17LP Projector lamp
Canon lv-x4e lamp reset procedure
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Apr 22, 2014 | Canon LV-X4E Compatible Projector Lamp
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
Need to purchase lamp for my projector
Dear Nasser We can supply a replacement lamp for you at a cost of $US287. Please let me know if you wish to proceed and I can send you an invoice with payment details. The lamp code is 60.J8618.CG1. Regards Kevin Andresasend. ICE AV Technology Ltd, +64-9-414 2348 iceavtech@gmail.com http://www.iceav.co.nz
May 26, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Panasonic PT-AE900U Projector Lamp stops working (intermittent)
Could be a heat sensor, fan bearing issue..have you listened to the fan speed etc, But I think more along the lines of the lamp needs replacing..each time you resit it is thinking ah a new lamp and then realises hey someone is fooling me and shuts down...this scenario is doing you a favour as typically if it blew and shattered the glass it will inevitablly scratch the mirror and lcd block... and if it does that you might as well toss it in the rubbish or sell on ebay for $50 ..
Regards Kevin Andreassend, ICE AV Technology Ltd www.iceav.co.nz iceavtech@gmail.com
Apr 03, 2009 | Panasonic PT-LB10VU Multimedia Projector
Lamp does not glow
Sound pretty much like a dead lamp. Problem could be a fan problem or heat sensor or power ballast. We supply lamps internationally so can assist if required as we ship world wide. Regards Kevin Andreassend http://www.iceav.co.nz iceavtech@gmail.com
Mar 21, 2009 | Sanyo PLC SW15 Multimedia Projector
Replacement or buying a new one?.
Hi, this seems to be lamp only, go the menu setup and press service info : then you get the lamp hours used if it is more then 1500 hrs you must change the lamp if less, try cleaning filter then reset the lamp again. if problem persist. lamp has to be changed.
Jan 27, 2009 | InFocus IN72 Multimedia Projector
Sony ES4 Projector :
Hi Vinod
I would suggest you to take out the lamp and check for any damage or discolouration to it.
I'm sure that you'll find this to be the problem , in which case you will have to replace the lamp.
May 07, 2008 | Sony VPD MX10 Multimedia Projector
I want Top 262 K4, UHP 120 W , 50V lamp.
Go to this link. They have what you need.
http://www.shopbot.ca/p-46336-637756.html
And sorry I have no idea where you can get one that's in India.
Nov 24, 2007 | Optoma UHP 120W Replacement Lamp Projector...
Sharp projector XV Z90U
I also had this issue - followed the On, Input, Undo, Left, Enter, Right, On button sequence several times. Then I decided to push them in that sequence very quickly and it worked. The lamp LED on the front changed to green and the projector started up. So the button sequence they provide in the manual works, you just have to push them in rapid succession. Hope that helps.
Oct 31, 2007 | Sharp Projector lamp Projector Lamp
400 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
