Question about Sony PlayStation Portable (PSP) Console
Problem with psp
After replacing the pins does the problem persist again with the same problem or it tends to some other problems in the unit
  • Raghav Raju Jun 26, 2008
    my psp battery is not getting charged but the psp can be used by connecting the adapter. what is the problem in it ?
    can it is solved?
  • eagle338
    eagle338 May 11, 2010
    Which problem are you talking about..?
  • 4,889 Answers
Hi raghav! If its working on the adapter that means the pin is not damaged. Its you battery that needs to be replaced. Just do it and it will be alright..
Posted on Jun 27, 2008
Error 917
917 Error in the Transfer Unit Belt. The Belt Rotation Sensor indicates an error.
Code 917: The Transfer Belt Rotation Sensor indicates a belt error.
Initial Actions:
? Check the condition of the Transfer Unit drive gear.
? Cycle the printer's power.
? If the problem persists follow the procedure below.
Troubleshooting Procedure Table
1 Test the Belt Rotation Sensor.
Run the Service Diagnostics Belt Hole IC test.
Does the sensor function correctly?
Yes) Go to Step 2.
No)Replace the sensor. If the error persists, go to Step 3.
2 Test the Transfer Unit Motor.
a. Close the Interlock Switches for test.
b. Run the Service Diagnostics Transfer
Belt Motor test.
Does the motor operate?
Yes)Replace the Transfer Unit. If the error persists, go to Step 3.
No)Replace the motor. If the error persists, go to Step 3.
3 Check all pins on the HALL1 Harness for continuity.
Disconnect HALL1 and P/J310
Is the harness conductive?
Yes)Replace the Motor Driver Board.If the error persists, go to Step 4.
No)Replace the HALL1 Harness.
4 Check all pins of the DRV0 harness for continuity.
Disconnect the DRV0 ribbon cable.
Is the cable conductive?
Yes)Replace the Engine Control Board.
No)Replace the DRV0 Harness.
Aug 18, 2011 | Xerox Phaser 7400/DT Laser Printer
When i turn my psp on the greene light turns on but nothing comes on the screen and after 20 seconds it turns of .can you help?
Pull the battery out and place it back in. Try switching the psp on again. This should solve the problem. If it persist get a new psp battery.
This would do.
Nov 06, 2009 | Sony PlayStation Portable (PSP) Slim...
My new psp go turns on for a few seconds then shuts off. I've charged it all night long and still it does nothing but turn right back off again. When i turn it on all it shows is the time and battery level...
my psp green light comes on i can hear when the psp loads up my game starts to play my screen is black i can't see nothing i can hear my game playing wat can i do to fix the problem someone can u help me my email
Oct 18, 2009 | Sony PlayStation Portable (PSP) Console
Psp not reading disks
One of two things:
1.Your UMDs are scratched or broken
2.Your PSP lens are malfunctioning
I suggest getting a different UMD, or, if the problem persists, replace the lens on your PSP.
Oct 05, 2009 | Sony PlayStation Portable (PSP) Console
My psp is 1000 and play game it goes left and down and when i turn it off and turn it on again it stops for some min but then again do that any please
recalibrate your joystick go to system settings and to the system info, there, move the joystick around all 4 directions and then exit the screen, if the problem persists, open the PSP and clean & screw your joystick
Sep 11, 2009 | Sony PlayStation Portable (PSP) Console
Cannot connect psp slim into the internet (continuation)2
do the configuration correctly and then if problem persists try to reset the unit
Feb 08, 2009 | Sony PlayStation Portable (PSP) Slim...
PSP Slim, picture problems
If he bought it from best buy, ask for a two year reeplacment plan. after that, you tell them what happend to your psp. by the way, the replacment plan is only $29.99. They will either try to fix it, or they will give you a new psp, the same exact type as you said psp slim, for free. But heres a catch. after you use the replacment plan once, you may not be able to use it again. good luck. P.S. what happend to your nephew, is what happend to me.
Jul 07, 2008 | Sony PlayStation Portable (PSP) Console
Psp battery won't charge
Its a problem with the unit's charging will have to get it replaced it shouldn't cost you more than 10$..
Oct 27, 2007 | Sony PlayStation Portable (PSP) Console
Sony PSP wont play umd
Same with my PSP. My son accidentally broken a spring sensor for the UMD when you close the UMD cover of the PSP. That's why the drive doesn't recognize if there's a UMD. Sony Service Center here in the Philippines doesn't have a replacement part for this.
Aug 19, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
16 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
