Question about Microsoft EXCEL 2004 for Mac
Knowledge of vb
Sir,
i want to take knowledge abt vb use in excel
vivek
To knowledge of Excel short cut keys
Posted on Jul 14, 2008
How to connect excel file with html form .
You will need a backend program in VB or Java to connect your form to an Excel File. Vb beign the first reccommendation
Mar 17, 2010 | Microsoft Office Standard for PC
How to know abt code
sir how can i know abt code for unlock my sch-w339 to accept rim , virgin sim
Apr 07, 2009 | Samsung Cell Phones
Delete blank rows in excel using visual basic
have you tried to read in one file and write back in excel format only the non-blank rows?
Mar 11, 2009 | Sony Playstation 3 (PS3) Console
Vb variable error
Change the code:
strdbname = "d:\vivek\company.mdb"
Set DB = DBEngine.OpenDatabase("D:\VIVEK\COMPANY.MDB")
strrsname = "company"
Set RS = DB.OpenRecordset("COMPANY")
comp.Text = RS!COM_CODE
compnm.Text = RS!COMPANY
isinno.Text = RS!ISIN
AD1.Text = RS!ADD1
'AD2.Text = RS!ADD2
'AD3.Text = RS!ADD3
AD4.Text = RS!ADD4
BK.Text = RS!BOOK
'PG.Text = RS!Page
to become:
Set DB = DBEngine.OpenDatabase(strdbname )
Set RS = DB.OpenRecordset(strrsname )
AD1.Text = RS!ADD1
AD2.Text = RS!ADD2
AD3.Text = RS!ADD3
AD4.Text = RS!ADD4
BK.Text = RS!BOOK
PG.Text = RS!Page
mostly to eliminate the extra "quote" (') characters,
and to use the values you set.
Dec 10, 2008 | Computers & Internet
STOCK REGISTER
Ur answer is simple.
Just keep a common database on internet for all stores & create website (ASP or PHP) or web based application(like Vb.Net or VB) much preferred.
so any sales occurs, it would be reflected across all stores,
so you can calculate total sales & remaining stock any any time and sort it or aggregiate it daily, weekly & montly..
Nov 27, 2008 | Computers & Internet
Excel
VBA is an integral part of Excel. Search help for VBA, and you should be guided to the proper place. Please post back if you need more help, otherwise thank you for using and rating FixYa!
Jul 08, 2008 | Microsoft Computers & Internet
Pls hepl me wit Excel VB integration
you can use a OLE object that is available in VB as standard object. Drag the tools to your form that your creating and it will ask for create or link existing object. so now browse to the excel sheet and embed it into the VB form or use run time for manuplating the cells and other info in excel.
Mar 25, 2008 | Computers & Internet
Mirosoft excel
Hello, Excel is only available with Microsoft Office. You'll need to purchase disk or download from Microsoft.com. If it is already installed and there is not a short cut in programs, Click start-search-(search for Excel). If installed it will show file to use. Hope this helps, Thanks
Mar 04, 2008 | Computers & Internet
Export data in excel shld yoeet through VB
When i first figured out how to pull data from SQL and put the results in an excel file i referenced these two articles....
Reading and writing excel file using VB.NET (http://www.codeproject.com/KB/vb/Work_with_Excel__VBNET_.aspx)
Get the Values From DataBase and Stored into excell Sheet (http://www.codeproject.com/KB/vb/Getvaluesfromdatabase.aspx)
This is the code i ended up using.... (check out those links to see how you need to import the ms office excel reference file with visual basic)
Const stcon As String = "Provider=SQLNCLI;server=xxxxx;database=xxxxx;uid=xxxxx;pwd=xxxxx;DataTypeCompatibility=80"
Dim stSQL As String = "select * from scs_rate_class_money where irate_book = 124 and snew_used = 'U' and sclass = '2' and splan = 'T4' and sopt_code = 'F1'"
Dim cnt As New ADODB.Connection
Dim rst As New ADODB.Recordset
Dim fld As ADODB.Field
'Open the connection.
cnt.Open(stcon)
'Open the recordset.
With rst
.CursorLocation = ADODB.CursorLocationEnum.adUseClient
.Open(stSQL, cnt, ADODB.CursorTypeEnum.adOpenForwardOnly, _
ADODB.LockTypeEnum.adLockReadOnly , _
ADODB.CommandTypeEnum.adCmdText)
.ActiveConnection = Nothing 'Disconnect the Recordset.
End With
'Close the connection
cnt.Close ()
Dim exp As Export = New Export()
Dim xlApp As New Microsoft.Office.Interop.Excel.Application
Dim xlWBook As Microsoft.Office.Interop.Excel.Workbook = xlApp.Workbooks.Add(Microsoft.Office.Interop.Excel.XlWBATemplate.xlWBATWorksheet )
Dim xlWSheet As Microsoft.Office.Interop.Excel.Worksheet = CType(xlWBook.Worksheets(1), Microsoft.Office.Interop.Excel.Worksheet)
Dim xlRange As Microsoft.Office.Interop.Excel.Range = CType(xlWSheet, Microsoft.Office.Interop.Excel.Worksheet).Range("A2")
Dim xlCalc As Microsoft.Office.Interop.Excel.XlCalculation
Dim i As Short
'Turn off Excel's calculation.
With xlApp
xlCalc = .Calculation
.Calculation = Microsoft.Office.Interop.Excel.XlCalculation.xlCalculationManual
End With
'Write the fieldnames.
For Each fld In rst.Fields
xlRange.Offset(0, i).Value = fld.Name
i = i + 1
Next
'Populate the range.
xlRange.Offset(1, 0).CopyFromRecordset(rst)
'Close the recordset.
rst.Close()
'Make Excel available to the user.
With xlApp
.Visible = True
.UserControl = True
'Restore the calculation mode.
.Calculation = xlCalc
End With
'Release variables from memory.
fld = Nothing
rst = Nothing
cnt = Nothing
xlRange = Nothing
xlWSheet = Nothing
xlWBook = Nothing
xlApp = Nothing
Jan 03, 2008 | Computers & Internet
Import excel sheet in vb.net 5
you have to make link in you vb then you can save the xls files on same format
Oct 08, 2007 | Microsoft Office Standard for PC
Microsoft EXCEL 2004 for Mac Logo
73 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
