Question about Sony PlayStation Portable (PSP) Console
My psp only turns on for 15 seconds and power button turns black.also screen is black when the power is on for that time.can you help me
My sons psp has a black screen
Without a functional screen, the PSP doesn't have much of a purpose. If the power light next to your screen is off as well, all your PSP needs is a good long battery charge. But if the power light is on and the screen is still dark, a few quick troubleshooting steps can help you get to the root of the problem. If troubleshooting doesn't work, you will need to contact Sony eService through its support site, particularly if your PSP has recently been dropped or had liquid spilled on it.
Step 1Turn off your PSP. Remove the battery pack. Replace the battery pack, making sure that it is securely inserted. Turn the PSP back on. If the screen is still black, continue to Step 2.
Step 2Press any system button. If the backlight is turned off, pressing a system button should reactivate it. If the screen has turned back on, go to the PSP settings menu. Select "Power Save Settings." Select "Backlight Auto-Off." This option automatically turns off the screen if the PSP has been idle. If you do not wish to have this feature active, select "Off." If this step did not solve the problem, continue to Step 3.
Step 3Press the screen brightness button below the screen. This button is marked with a small donut-like icon. Pressing the button will incrementally increase the brightness of the screen. Holding down the button will turn off the backlight. It is possible that this button was accidentally pressed down after placing the PSP in a pocket or a backpack. If the screen remains black after the brightness has been increased to full, continue to Step 4 if your model of PSP is any but the PSP Go.
Step 4Open the top hatch on the PSP. This will eject the UMD disc. Only touch the UMD at the edges, as fingerprints can interfere with the disc's functionality. Clean the surface of the UMD with a clean, dry cloth. Do not clean the UMD with water or any other chemicals. If the disc looks scratched or damaged, this is likely the cause of the screen issue. Additionally, moisture can condense on the UMD if the PSP has undergone a recent temperature change, such as being brought into a warm house from a cold car. If the UMD looks wet, turn off the PSP and allow the UMD to air dry. Wait several hours before trying to restart your PSP.
Dec 27, 2011 | Sony PSP (Piano Black)
Need Some Help, My Psp 3001, Turns Off On It's Own, While I'm Playing A Game Or Listning To Music, What can i do???
Here are some instruction to help fix your problem.
Put the PSP down on a table with the LCD screen facing up.
  • 2 Plug the power cord of the PSP power supply into the PSP's power outlet. Plug the AC plug of the PSP power supply into an AC socket.
  • 3 Perform a hard reset on the PSP by pushing up on the power switch at the lower-right corner with your index finger.
  • 4 Count to 15. Release the PSP's power switch. Count to 30.
  • 5 Flick the PSP's power switch up with your index finger and release it. Repeat this procedure a second time.
  • 6 Wait as the PSP reboots, starts up and stays on.
  • 7 Remove the PSP power supply's power cord from the PSP's power outlet. Remove the PSP power supply's AC plug from the AC socket.
  • 8 Flick the power switch up with your index finger to turn off the PSP.
  • May 04, 2011 | Video Game Consoles & Games
    I am trying to upgrade my psp from 5.00 m33 to 5.03 m33 .and I was formatting my psp, my psp just shut down, when i turned it on, the power button turrned green but the screen does not change
    regarding with this issue
    - try to perform a power drain
    - remove the battery
    - unplug the ac adapter
    - try to hold the power switch for 15 seconds
    - reconnect the battery and ac adapter try to turn on the psp
    - if this does not work
    - try to load the default settings or downgrade the psp back to factory firmware
    Hope this help you in resolving the issue
    thanks for choosing FixYa
    Feb 19, 2011 | Sony PlayStation Portable (PSP) Console
    Hey, i have a problem with my sony PSP when i start my PSP the green power light is on but there is nothing to display and the memory stick light keeps flickering too , please help ???
    Hello there
    You'll need to hard reset your PSP and restore it to its factory settings. Once this is done, your PSP should work perfectly.
    Hold the power button on the right side of your PSP down until the device completely powers off. Wait at least five seconds after the power is off before proceeding to the next step.
    Press and hold the Select and Start buttons located in the bottom right corner of the PSP.
    Press and hold the Square and Triangle buttons (located on the directional pad) while continuing to hold the Select and Start buttons.
    Press the power button while holding these four buttons. When the flash (logo) screen appears, you can release the four buttons and your PSP will be reset to its factory settings and the screen will no longer be blank.
    Oct 10, 2010 | Sony PSP (Piano Black)
    Reset psp,once turned on doesnt work?.
    Looks like you might of run an update of some sort from the UMD disc or memory card. Take the battery out and then put it back after 15 mins.
    If it still doesnt work im afraid you may of bricked it by forcing shutdown on the PSP.
    There are people on ebay who might be able to help if you cant get the PSP to work.
    Just type 'bricked psp' into search and tell the person what happened. It shouldnt cost more than £15 to sort the PSP out.
    Jul 10, 2009 | Sony PlayStation Portable (PSP) Console
    Itouch black screen and wont turn on
    I had the same problem. I pressed the power button and the home button at the same time for about 10 seconds and then the home page showed up.
    Aug 05, 2008 | Audio Players & Recorders
    PSP comes on and plays fine then the screen goes black?
    I am having the same problem.  The screen will intermittently come on as blurry.  Like all the text and graphics are doubled, but off by a few pixels.  Doing a sleep and turning it back on usually fixes it.  But I can not operate my PSP for more than like 10 seconds to a minute (varying) until the screen freezes and fades to black from right to left.  This usually occurs by pressing any of the buttons on the front panel.  If I am reading the news in the browser for instance and it is just sitting there, it is fine, then the second I hit a button, fades to black.  After it fades to black, sound and buttons continue to work.  I figured it was a bad LCD, so I purchased a brand new OEM LCD screen and installed it, however, the problem still persists with the new LCD screen, so it is not the screen itself.
    Jul 21, 2008 | Sony PlayStation Portable (PSP) Console
    Psp has black screen
    its been bricked and needs to be rescued with service mode
    May 05, 2008 | Sony PlayStation Portable (PSP) Console
    Psp screen is black
    Can you go to "Recovery Mode"..? >> Hold R(right) button while turn on ur psp. if yes, You need the Pandora's battery to downgrade psp back to 1.50, its will clear a bug in flash1 on psp.
    Oct 21, 2007 | Sony PlayStation Portable (PSP) Console
    Psp black screen
    Hi Azeem123,
    Your PSP is Bricked.  You need to send it to Sony to get your problem resolved. The contact information is listed below.
    I know this is terrible news for you.  When you were downloading the Flash0, something disturbed the download and corrupted the PSP. This is what Bricked you PSP.  Brick refers to your psp and it is dead until Sony fixes it, no more worth than a brick.
    SCEA Consumer Services
    1-800-345-SONY (7669)
    Oct 13, 2007 | Sony PlayStation Portable (PSP) Console
    Sony PlayStation Portable (PSP) Console Logo
    Top Sony Video Game Consoles & Games Experts
    Iron
    Iron
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
