Question about HP Office Equipment & Supplies
I get error code 346 on my HP Photosmart C6180 all-in-one printer when I try to send a fax. It happens at all times of the day with all faxes to anyone. I have tried new phone lines, a phone line filter, and it still happens. PLEASE HELP RIGHT AWAY!
  • Anonymous Aug 21, 2008
     I have the same problem and it drives me crazy
SOURCE: Fax Error Codes
Disconnect all phone lines and wait one minute. Plug in an analog telephone to reset the lines. Re-plug your original phones (and fax) and try faxing again.
Posted on Sep 26, 2007
Nitrotrike
  • 589 Answers
SOURCE: hp photosmart C6180 all-in one
Your manual can be viewd / downloaded / printed here, directly from HP:
http://h10032.www1.hp.com/ctg/Manual/c00753187.pdf
The fax setup section starts on page 33.
Posted on Apr 22, 2008
  • 111 Answers
SOURCE: FAX errors 345 346 and 350
HP.com has a web page for your product with all of the fax error codes listed and how to interpret them:
Fax Error Codes
Once the page opens, you'll have to scroll down until you find your error codes in the list. The codes in that section of the page don't seem to line up well. All of the codes have to do with the quality of service on the phone line. If the people you're faxing to are receiving all of their faxes except from you, I'd suspect your phone line may have a problem. Here's what I got from the list:
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power related problems.
OR
The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
OR
The remote user has pressed the Stop key while the reception was in progress.
OR
Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
Check with your phone company to see if their are any problems on your line. It looks like anything that even momentarily interrupts your phone connection will cause these errors. Good luck.
Posted on Nov 04, 2008
sagarjd
  • 95 Answers
SOURCE: HP C6180 ''Unable to scan, copy or send a fax''
Check the following steps:
Connect the printer directly to the wall outlet and
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold # and 6 while plugging in the power cord
Try to check the result.
Regards,
Sagarjd
Posted on Nov 21, 2008
  • 5 Answers
SOURCE: set up fax and dsl using one phone line
You can buy a splitter to put on your line so you can run both devices. They sell them at the dollar tree big lots and everywhere else usually, and range from .59 to $2. as far as another DSL filter ask a friend neighbor or co-worker if they have or had dsl and have an extra filter. If not then you can pick them up for a couple of bucks at radio shack
Posted on Feb 21, 2009
Unable to send or receive fax
Try uninstalling and reinstalling the drivers for this printer, you can get them from the HP website
Let me know how this goes and whether you need any help doing this or if you have any questions
If this doesn't work then I have a few other ideas for what it wrong.
You could also try a system restore if the drivers don't work
Jun 04, 2008 | HP Photosmart C6180 All-In-One InkJet...
Hello, I have an HP Photosmart C6180 All-in-One Printer, Fax, Scanner and Copier. It seems that as soon as I turn it on a message comes up: "Fax Failure" Unable to Send or Receive Faxes" This message has...
try ti perform steps as ---->Disconnect the power cable from the back of the printer and then press the power on button for 3- seconds and then at the same time connect the power cable at the back of the printer and then try to turn on the printer and then try to make copy from the printer
Aug 19, 2010 | HP Photosmart C6180 All-In-One InkJet...
Unable to scan, copy or fax message on HP C6180
Please follow the steps and then let me know the results:Click Here
May 23, 2010 | HP Photosmart C6180 All-In-One InkJet...
C6180 FAX UNABLE TO SEND OR RECEIVE
check the the phone line, The fax sinal need good clear. Surely,plug the phone-line is rigth line socket. If you do that all, the broblem is still happenning,need to change "relay" on moderm fax board.
Jul 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
Machine won't fax
The error code indicates a problem with either the phone line or the fax format that is not supported by HP Photosmart C6180. For more information go to the link below:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02549&lc=en&dlc=en&cc=us&lang=en&rule=25901&product=1153494#Error420
Apr 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
Unfamiliar with my friends FAX machine
Assuming that that the machine has a live telephone line plugged in and that it is functioning properly, then you can place your document either face down on the glass or face-up on the feeder (if multi-page). Simply use the numerical keypad on the printer to dial the fax number you wish to send to (don't forget a 1 if long distance) and then press the [Black] button under the START FAX heading. That's it.
You can also send through the software (fax from Word, etc.) by going to File --> Print and choosing the HP Photosmart C6100 Series Fax from the list of printers... but printing a hard copy may be the simplest way for you.
Dec 31, 2008 | HP Photosmart C6180 All-In-One InkJet...
How to send a fax
Load the fax in the scanner, Dial the number to be faxed to, and hit Either black&white or Color, and it SHOULD scan before it tries to scan... Thats how my HP works.
Nov 24, 2008 | HP Photosmart C6180 All-In-One InkJet...
Fax Error Codes
ERROR 346 The remote machine has failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area are old or if noise is present (static on the phone line). Other reasons could be power outages and other power-related problems.
Sep 11, 2007 | HP Officejet 7210 All-In-One InkJet...
447 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
