Question about Casio EXILIM ZOOM EX-Z70 Digital Camera
The moving lens Stuck
When my COUSIN was recording my next door neighbor,he just blocked the camera from not geting recorded and somehow when he blocked the lens,he pushed it and it fell.
Now the zooming thing is stuck.One side is fatter than the bottom one. It was small.Now please message me and applesrockk@yahoo.com if you have a solution.
Thank you
  • 4,472 Answers
You will need to have the camera serviced. You can use FixYa's home page just enter your zip code to find a repair man. Call around your area and you can get an idea of what it will take.
Thanks,
Lee
Posted on Jun 26, 2008
The camera did not record voice of movie when I use the optical zoom
From page 80 of this manual: "Optical zoom blocks sound being recorded when zooming."
Many cameras do this as otherwise the recording will include the sound of the lens being zoomed. There are two possible workarounds for this: 1) Don't use the optical zoom while recording. 2) Use an external sound recorder to record the soundtrack and mix them together on the computer.
Mar 10, 2013 | Fujifilm Finepix T400
The camera takes pictures with flash, but then as you hit display the screen stays black and the picture was never taken. How can this get fixed?
Do you mean that no picture file was actually recorded, or do you really mean that the resulting picture file recorded a black picture?
If you mean that you're camera is taking black pictures, this sounds like a stuck shutter. A stuck shutter is a common failure mode for digital cameras, and it seems to be especially so for any of the Canon A6XX series (although these cameras are awesome otherwise). The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 28, 2010 | Canon PowerShot A620 Digital Camera
Seems to be o.k. with sounds and menu screens,but no image of pic shows in viewer,and no image is recorded when transferred to computer
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Oct 22, 2009 | Canon PowerShot A530 Digital Camera
A grinding sound coming from inside the camera (PanasonicHVX200A)
If noise occured during while OIS function is on,then must lubricate the axis inside lens underneath the ccd block.Due to friction of the movement of the coil used for moving lens for optical stabilizing function makes noise,but if this is not the problem, camera board must be next suspect,so first clean and lubricate and after ask service for cost.So generally speaking ,the problem is on the lens unit ,or the camera board which drives it...
Jul 15, 2009 | Panasonic AG-HVX200A Mini DV Camcorder
My Canon Ixus 75 will no longer take pictures.The screen remains blank and no image is recorded when the shutter is pressed. All other functions appear normal, including the display ing of previously...
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 12, 2009 | Canon Cameras
Lens stuck out, camera won't switch on, Canon G9
I have fixed my g9 twice with the lens problem. 1st time I dropped the camera on asphalt lens closed. Turned on, lens stuck and not forcusing or retracting. Solution was to press lens against a door frame and push as I turned off the camera...it worked. The next time,the lens was extended and would not retract I had to place the camera on its back on a book while I used a small block of wood and a small hammer. It worked camera is working fine. After both cases, it took about 5 shots to calibrate the auto focus.
Jul 07, 2009 | Canon PowerShot G10 Digital Camera
BLACK SCREEN WHEN RECORDING
SORRY FOR DELAY RE YOUR PROBLEM
WOULD THE CAMERA HAVE BEEN SET AT MANUAL EXPOSURE WITH THE EXPOSURE SET WRONG
TRY!!
ROBERT
May 04, 2008 | Sony Handycam DCR-TRV460E Digital...
Creating a DVD from digital tape
i took my unit back to electronic express a chain here in tennessee
the guy was baffled at first
then he got a firewire and plugged it into the ilink place on the front of the unit and it copies my old canon recorded tapes just fine
what happened??? who the heck knows --- somehow the chip that prevents the movie copying was reading my old canon recorded tape as copyright -- this somehow bypasses that
if i am not mistaken you can buy attachments to make sure they fit your type of camcorder - my new sony hi def camera came with one - so i had no problem
here is the other kicker --- WHEN I CALLED SONY AND ASKED IF THE ILINK HOOK UP WOULD MAKE THE DUBBING WORK -- THE IDIOT SAID NO he was dead wrong
i will never buy another sony in my life
i stil have not tried to tape movies to dvd and or vhs --- but i already have the machine so i'm stuck with it
what i'd like to know is which combo units do NOT have the blocking chip
could somebody update on the law about this
thanks
i hope this helps
please let me know
Sep 29, 2007 | Sony RDR-VX555
My camera - frozen?
Charging the batteries was the first move. Charge for at least 14 hours, and never shoot on low batteries. If the battery gives out while you are recording to memory, it can corrupt the storage media. The lens should work normally with a fully charged battery.
Nov 23, 2006 | Nikon Coolpix 4600 Digital Camera
Camcorder will record but no image...
Its a stuck iris assy an iris cucuit fault or many small pana cpsm that go bad all the time in these unit. Mke sure the iris didnt het seitched to manual andif it is i auto try tappin the lens a littlethe see if it opens Good luck
Apr 16, 2006 | Quasar VM-L152 Camcorder
Open Questions:
See all Casio EXILIM ZOOM EX-Z70 Digital Camera Questions
Casio EXILIM ZOOM EX-Z70 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
