Question about Fisher and Paykel Dishwashers
MY DISHWASHER IS NOT CLEANING PROPERLY - Fisher and Paykel Dishwashers
    Problem Solver:
  • 9 Answers
Hi bayan try removing the inside blades and stainless trays and clean them and check if there is any thing blocking it. this happened to mine. good luck. slappa
Posted on Jun 26, 2008
My dishwasher is not cleaning my dishes
Hi btoma313,
Find some info in the Tip below, on what to do if your dishwasher is not cleaning properly.
DISHWASHER NOT CLEANING PROPERLY...
Kind Regards :-)
JEDEMEYER1
* If this solution helped you, please rate it
Jul 19, 2011 | Maytag Dishwasher
My knemore dishwasher is not cleaning the dishes like it used to do and dishwasher is not cleaning itself also. I have this dishwasher for over a year and two months ago I had a pipe leak from dishwasher...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jul 12, 2011 | Kenmore 13599 / 13594 / 13592 Built-in...
I have a Whirlpool gold dishwasher. It may be 6-7 years old. It is cleaning properly. Any suggestions?
I think you want to mean it is not cleaning properly..
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes
Feb 02, 2011 | Whirlpool Dishwashers
The dishwasher is not cleaning the dishes properly, it has a build up all the time, such as hard water, or like the detergant is getting caked on the dirty dishes and it is not cleaning the dishes properly...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Jan 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Maytag eq plus, not cleaning properly, seems the
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
h
Feb 28, 2010 | Maytag MDB7100AWB Dishwasher
Dishwasher not cleaning properly
If I got the issue correct your dishwasher has stopped cleaning properly.
As advised by an Frigidaire engineer that there is not enough salt in the dishwasher & that is what causes the sand like residue on dishes. sometimes even when you use an all in 1 dishwasher tablet this may still not contain enough salt for the hardness of the water in your area. Using salt regular helps keep the dishwasher clean.
I am sure this would help you:
God Bless.
Jul 09, 2009 | Frigidaire Dishwashers
My dishwasher not cleaning properly
If your filter is dirty or "damaged beyond repair", dirt can be sent back to the dishes, glasses, flatware, etc.
Also, the water paths may have scale lining or blocking the pathways, which would reduce water pressure, prevent proper pressure, and / or block water spray.
The following link might give you some ideas... as for the filter, if you have the user's manual, the list of parts may be in the back with the index.
https://www.onegoodthingbyjillee.com/how-to-clean-your-dishwasher-in-3-easy-steps
Oct 17, 2017 | Bosch SHX46L15UC Dishwasher
The water is not draining after the rinse cycle
try cleaning your airgap. that's usually the problem when a dishwasher will not drain properly. if that doesn't do it, it's probably pump related. good luck :)
Jul 07, 2009 | Dishwashers
Not cleaning dishes
For starters run the dishwasher through its entire cycle empty and add only one cup of vinegar. This will clean and disinfect. Next run the dishwasher through a second full cycle with nothing but water. This may be all you need to do to get your dishwasher back up and running.
Apr 30, 2009 | Dishwashers
Kenmore dishwasher not cleaning properly
Look in the inside for any screen that would be easily removed, some dishwashers have a self cleaning filter so you may not find it. I have a lot of other tips for you if your dishwasher is not cleaning so check it out.
http://tclaundryrepair.com/dishwasher
Feb 17, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwashers Logo
129 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
