Question about Plantronics CS70 Wireless Headset
How much Temperature
Ear trip cs70 how much temperature uses to a store
  • 32 Answers
The temperature range for these units is not specified by the manufacturer.  As long as you're not using it above 40°C or under 5°C I'm sure you'll be fine.
Posted on May 22, 2009
The braun thermoscan giving inaccurrate temperature readings,how to revtify this problem
Pull the pinnacle of the ear up and back. The sensor must be closer to the tympanic membrane to read a more correct core temp. The sensor must be free of debis and if the ear is infected or the canal has wax present as well as other forms of debis, u will not get a correct temp . If the subject has chronic ear issues I would use an oral trmp or preferably a temporal scanner
Feb 05, 2013 | Braun Thermoscan Thermometer Probe Covers
4 year old braun thermoscan IRT4520 having some problems
is the drawer that its stored in, in the bathroom? the humidity or moisture could affect it. I have had mine for 8 yrs and works perfectly. Are you placing the probe covers on correctly and waiting for it to click or a pop before inserting into ur ear.?
Jul 03, 2012 | Braun IRT3020 Thermoscan Ear Thermometer
The Headset Lifter won't pick up the calls. Nothing happens when I push the ear button to lift it up. I thought maybe it wasn't fully charged when I tried it yesterday. At that point, I made...
If the CS70 headset has a charge and beeps when you press the call control button, you may just need to re-pair or re-subscribe the headset to the base unit. Here is a link for the pairing / subscription instructions:
Plantronics CS70 Pairing Instructions
If the headset is not charging, the internal battery may be worn out and the headset may need to be replaced (the battery is hard wired and is not replaceable). The replacement headset is model 72910-01. Below is a link where you can purchase the replacement headset.
Plantronics CS70 Replacement Headset
Good luck from Headsets Direct!
Jun 24, 2011 | Plantronics CS70 Wireless Headset
How do I change my Braun ear thermometer back to F from C
You did not provide a model number however the Instruction Manuals for the various Braun Thermometers can be found here:
http://braun.kaz.com/kaz/service/prodResult/
Not sure if this procedure is common to all but this may work otherwise find the manual specific to your model number.
Changing the temperature scale
This thermometer is shipped with the Celsius temperature scale activated. If you wish to switch to Fahrenheit ( °F), proceed as follows:
Turn on the thermometer. ( If it is already turned on, make sure it is not in memory mode.)
Press the /mem button and keep it pressed. Then press and release the activation button to switch over to the «change temperature scale» mode.
By pressing the activation button again, the Fahrenheit scale is activated, «°F» is displayed on the LCD. Each further pressing of the activation button toggles the scale between °C and °F.
Release the /mem button to return to the ready symbol . The temperature stored in memory will automatically be converted to the selected scale when displayed on the LCD.
Apr 24, 2011 | Braun Thermoscan Pro 4000 Ear Thermometer
Need to know how to change the earpiece to a smaller piece for the inner ear
Plantronics has a very nice of ear tips for the CS70 that includes several sizes, so you can find one to fit your ear. Here is a link where you can purchase the set of ear tips:
Plantronics Replacement Ear Tips
Mar 28, 2011 | Plantronics CS70 Wireless Headset
I don't have the directions how do I work it i have ThermoScan and want to use on 4month old
How to use Braun ThermoScan 1. Always make sure a new, clean lens filter is in place to help ensure an accurate reading. The thermometer will not function without a lens filter attached (see Changing the lens filter). 2. Press the /mem button. The LCD (liquid crystal display) is activated, showing all segments. When the ready symbol is displayed the thermometer is ready for use. 6 To help ensure an accurate temperature reading, use the following technique: If you are right handed, hold the thermometer in the right hand and take the temperature in the right ear. If you are left handed, hold it in the left hand and use the left ear. 3. Perform an ear tug to straighten the ear canal. This gives the thermometer a clear view of the eardrum. Children under 1 year: Pull the ear straight back. Children aged 1 year to adult: Pull the ear up and back. An ear tug is best performed by using your free hand to grasp the outer edge of the top half of the ear. To take your own temperature, wrap your free hand around the back of your head and grab your ear from behind. 4. While tugging the ear, fit the probe snugly into the ear canal as far as possible and press the activation button. Release it when you hear a beep. This is the Temp Beep that confirms the end of measurement. 5. Remove the thermometer from the ear canal. The LCD displays the temperature measured. 6. Replace the lens filter after each measurement: press the ejector button and put on a new, clean lens filter. 7. A new measurement can be taken as long as the ready symbol is shown. If no button is pressed within 2 minutes, the thermometer will turn off automatically. 7 Note: In the following situations, it is recommended that you take three temperatures in the same ear. If they differ, use the highest reading. · Infants in the first 90 days of life. · Children under three years of age who have a condition such as a compromised immune system and for whom the presence or absence of fever is critical. · When you are first learning to use the ear thermometer until you are comfortable with the technique and are obtaining consistent readings. Important: As with any type of thermometer, slight temperature variations ( ± 0.3 - 0.5 °F / ± 0.2 - 0.3 °C) can occur, if consecutive measurements are taken. Temperature taking hints · The right ear reading may differ from the reading taken at the left ear. Therefore, always take the temperature in the same ear. · The ear must be free from obstructions or excess earwax buildup to take an accurate reading. · External factors may influence ear temperatures, including when an individual has: - been lying on one ear or the other - had their ears covered - been exposed to very hot or very cold temperatures, or - been recently swimming or bathing. In these cases, remove the individual from the situation and wait 20 minutes prior to taking a temperature.
Mar 04, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
I need a instrution manual for a ear themoniter model no ET1200
Hi.
  • 1 Consider that most digital thermometers take a temperature in less than 30 seconds, quickening the temperature-taking process for squirmy children.
  • 2 Read the thermometer's instructions carefully. Never throw the instructions away. Keep them near your digital thermometer.
  • 3 Wipe the thermometer probe with a soapy washcloth or a tissue dabbed in isopropyl alcohol or put on a clean probe, depending on your brand of thermometer.
  • 4 Turn the thermometer on.
  • 5 Use a gentle rocking motion as you insert the thermometer into the ear canal or rectum. Never push or cram the probe into the body. Forcing it causes pain, especially if there is swelling in the ear canal or rectum.
  • 6 Listen for the beep.
  • 7 Remove the thermometer.
  • 8 Read the thermometer. If you see "ERR," you did not get good contact with the ear canal or rectum, and will need to take the temperature again.
  • 9 Use the chart insert that comes with your thermometer to see what your normal reading should be.
  • 10 Clean your thermometer probe with a soapy washcloth and/or isopropyl alcohol before storing.
  • Aug 26, 2010 | Health & Beauty
    Detecting calls onm Cisco 7961
    If the CS70 has a lifter attached to the cisco phone then it should be able to detect an incoming call by beeping in your ear.  If there is no lifter, it won't beep in your ear, but you will still be able to answer.
    Apr 26, 2009 | Lands Phones
    Cant hear phone ring at a distance
    Do you have a lifter installed?  You won't hear beeps in the ear unless a lifter is installed.  What type of phone system do you have this hooked up to?  Make sure it's a standard ring you're using and not a funky one.  The lifters tend to not recognize different sounding rings.
    Apr 16, 2009 | Plantronics CS70 Wireless Headset
    Plantronics CS70 Wireless Headset Logo
    37 people viewed this question
    Top Plantronics Radio Communications Experts
    LeAnna Mathews
    LeAnna Mathews
    Level 1 Expert
    shaun taylor
    Michael Vincent Cruz
    Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
