Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
How to change belt on bissell proheat powersteamer
The water supply stopped while shampooing. I removed the cover to access the belt and the belt was broken. I bought a new belt at a vacuum shop, but can't figure out how to put it on the roller.
  • saboulis Jul 09, 2008
    I have a teal color brissel pro heat steam vacuum. My belt broke on the roller and I wonder if I can go to a store nearby and get a new one and what side belt or number do I get.
    Thank You
  • Anonymous Jul 13, 2008
    same problem
There is a video on the Bissell website on how to do this, click here for the link:
Video
Posted on Jun 07, 2009
I spent about 30 minutes trying to figure this out, and another 15 minutes putting the top face plate back on before I realized how to actually fix this, but the fix in itself is easy once you know what to do. Once you remove the face plate that hides the belt and water pump assembly you should see a red plastic cradle that is what needs to be removed, flip the vacuum up so you can see the brushes you should see that same red piece look closely hidden is a screw that holds that piece in place remove it and now you can move a black swiveling cover that hides the brush belt as well as the water pump belt. It should be pretty straight forward from here, you will have to take the brush belt off to put the water pump belt on, after both belts are on swivel the black cover back in place, replace the red plastic cradle piece and the belt face plate cover and your good to go. Good Luck
-XxSiRiuSxBuRnxX
Greg
Posted on Mar 31, 2009
    Problem Solver:
  • 17 Answers
Following in a link to the owners manual. This covers some information regarding the belt. From the manual it says instructions should of came with the belt. Hope this helps.
http://www.bissell.com/images/UserGuides/7901_207.pdf
Posted on Jun 27, 2008
I have the 8920 model how do you replace belt on right side if your sitting in front of your machine
Posted on Aug 01, 2010
Using the bissell proheat upright carpet cleaner and no shampoo is being dispursed.
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Jul 03, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Basic how to use instructions.
1. Step on the handle releae pedal and lay the handle back.
2. Remove the tank and take it to thesink.
3. Remove the top cover cover and fill the plastic bladder with water only.
4. Replace the tank.
5. Your 'Smart Mix' (shampoo) bottle is on the operator's right in front of the machine. Remove it and fill it with Bissell shampoo.
6. Shampoo is automatically mixed with the water as you dispense it depending on how your 'Smart Mix' Knob is adjusted.
You can download your complete maual here:
http://www.bissell.com/searchresults.aspx?searchtext=1698&mode=userguides
May 20, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissel shampooer
yes there is a belt on the side that will need to be changed
Jan 13, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
1698 bissell cleaner
Check to see if you get water from the hand held nozzle if so you have a clogged heater.If you get nothing at neither the floor or hose check the belt on the right side of the machine there is a cover that you need to remove it runs the pump and may be stretched out or broken. Also check the solution tank if it is not sealed properly you won't get any water either. For parts cleaning solution or questions visit www.stevessewandvac.com.
Jul 17, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissle will not let water out if Bladder
Check the vale at the bottom of the tank. Push it in and see if water comes out ok, also check to make sure the seal is on the valve asm. Check the pump belt to see if it broke. Could have a bad pump. Is the top cover seated against the base in the back, if it is raised up, then it also raises the tank so it can't work.
Apr 12, 2008 | Bissell 1699 ProHeat Clear View Upright...
Belt removal Bissel PowerSteam ProHeat
First take off the cover on the left side oif the top cover, then turn it over, remove the screw holding the red lock and pull the cap and brush roll out, remove the cap, remove the cogged belt, then you can put the new pump belt thru that slot, put over the pulley on the pump and then stretch it to go over the motor shaft. Then put back together.
Jan 18, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
How to use bissell carpet cleaner
On the 1698 modle thier is a large clean water tank and a smaller shampoo bottle which seats on the side of the machine.
the shampoo goes in the smaller bottle fo the two.
Jan 02, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
12,031 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
