Question about Optoma MovieTime DV10 Multimedia Projector
Loud Fan Noise
I have a Optoma MovieTime DV10. Last night it was playing for about 3.5 hours. I got up to go to the kitchen for 5 minutes. When I returned, I noticed a loud noise coming from the unit and a small pillow near the exhaust vent. I turned it off immediately. The unit usually gets hot, but this time it was overheated. Since then, the unit works fine with the exception of a loud fan/motor-like noise coming from it. what should I do. the unit is over a year old and I bought it from it's previous owner. I don't think it is cover by a warranty.
-Carlos
  • pimbol Oct 26, 2008
    You resolved the problem of the DV10? Therefore I have the same problem.
  • 23 Answers
Review Date
Monday, 12th of September, 2005 --> What's Hot
User-friendly, built-in DVD player, high-throw ratio lens, fast power/cool down What's Not
Fan operation is quite audible, native resolution of just 480p The Final Word
A perfect coffee table companion Notes
# This product is no longer available directly from the manufacturer. It may be available in retail and distribution channels, or second hand. The price displayed is the price at review time and the last available recommended retail price.
The DV10 has a futuristic-looking outer casing and two internal speakers located behind a silver grille mesh at the rear. Heat is removed through its side ventilation and the internal fan has a noise level of 27dB, which is comparable to a loud computer and quite distracting when watching movies at low volume. At 368 x 117 x 273mm, the unit is small enough to permanently and inconspicuously reside on a coffee table.
this is from a review .
it sounds like that the fan needs to be cleaned the sound you hear is normal but if it sounds like its racein the moder might be on its way out if you have a can of air used to clean a key bored i would try to clean it out with that if not take it to a repair place to see if they could look at the moder
Posted on Jun 26, 2008
Why won't my Optoma DV10 projector won't turn on?
On an Optoma DV10 if its not the lamp timer, then it might be a cooling fan that needs replacing. Take out the old one, and look-up its part number online. If you don't feel confident taking it apart, have a qualified person do this.
May 23, 2014 | Optoma MovieTime DV10 DLP Projector
My Optoma DV10 works fine for 20 sometimes 45 minutes then freezes up. Bulb and fan stays on but movie just stops playing.
All gadgets have limits and have a tendency to malfunction if over used most of the time.
You have to give sometime for it to rest too, machines and gadgets are like humans too, needing time to rest and recharge after a hardwork. If this is not your case however, it's best if you visit your provider and have it checked if it's stops without you overusing it then this should be covered by warranty.
Jul 08, 2011 | Optoma MovieTime DV10 Multimedia Projector
It started making a loud noise and it suddenly
it's the colorwheel. part# 70.81R26GR01. you can get the part and do it yourself, or send it to a service center. either way, av solutions in ny is pretty good (www.avsolutionsny.com). they can either get you the part or replace it for you.
Oct 30, 2009 | Optoma MovieTime DV10 Multimedia Projector
Optoma DV10 randomly shuts off completly during a
check the power timer settings and put it to disable setting, Or avoid anything that cover the exhaust, fan if the problem occur get assist to the technician.
Oct 22, 2009 | Optoma MovieTime DV10 Multimedia Projector
Optoma DV10 loud vibration and odd colours
check the colour glass wheel is shattered with a piece of glass still stack to the wheel. it not even thats why it vibrates
Aug 17, 2009 | Optoma MovieTime DV10 DLP Projector
When bulb turns on it gets a loud humming noise
It's likely the fan or the color wheel as both of these spin. I've given a suggestion for another user which in part may be applicable to you. It can be found here by using the search phrase- Blue tint on projector or by clicking my name and the appropriate topic.
Jun 06, 2009 | Optoma MovieTime DV10 Multimedia Projector
Optoma DV10 Issues
change the lead that came with the system to another one, i am not sure if it was the new cable or the step down in the amp that I used, but it did the trick
Dec 10, 2008 | Optoma MovieTime DV10 Multimedia Projector
Bad color wheel on Optoma DV10
Yes, you can replace the color wheel yourself if you are handy with a screwdriver.
Jul 19, 2008 | Optoma MovieTime DV10 Multimedia Projector
Fan making noise
Are you sure its a fan, dust out the fans.
If its not the fans you may have a power supply going out and causing some induction hum in the unit. Sometimes, but rarely, through the built in speaker.
May 02, 2008 | Optoma MovieTime DV10 Multimedia Projector
Fan
To find for a fan replacement, it is always best to go back to the manufacturer of the projector
Nov 24, 2007 | Optoma MovieTime DV10 Multimedia Projector
Optoma MovieTime DV10 Multimedia Projector Logo
396 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
