Question about Samsung DLP HL-P5663W 56" TV
Screen is black but sound works
Everything was working fine and left and walked back into the room it appeared that the screen was flashing. I thought it was the channel but it also was on other channels. I turned it off and then back on but only the sound came back. Sometimes all three lights are lit up on the button, other times it is only the green light that says lamp. The sound is fine but can not see anything just a black screen. The remote would not do anything so I turned off the power strip, when I turned back on the tv was already on but would not respond. It stayed on a minute and turned itself off, then back on but only to a black screen. Any ideas here?
  • Anonymous Nov 10, 2008
    My 42" starting shutting itself off 2 months ago. I ordered a new lamp and by the time it arrived the problem had stopped. Yesterday it started again and we replaced the lamp.  The problem continued. Checked the lamp and it is in correctly. This morning the TV malfunctioned. I turned it off. Turned it on and it worked fine for 1/2 hour until I had to leave for work. Wondering if it could be overheating and its really a fan problem?
    Sergeant:
    Champion:
  • 375 Answers
Possible lamp is burned out,look in your manual for info.
Posted on Jul 30, 2008
JVC LT-52P789 no picture just sound
If this is an LCD TV, show a flash light on the screen from a safe distance. If you can see picture, it means the backlights have gone off and the TV might need servicing.
Aug 23, 2012 | JVC LT Televison & Video
My TV screen appears for a second then turns black, then a few seconds later appears again and the turns black again. The channel sound is perfectly fine. My Cable company tried everthing and it still...
If the tv isn't fully shutting down. but just flashing on and off then it
sounds like a backlight supply fault.
All LCD screens have what can only be described as micro flouro lights inside the screen module.
it is possible that the power supply is faulty causing them to flash on and off every now and then. or the tubes themselves are damaged.
to confirm this..
Lay the tv down flat on its back and power up in a well lit room
get down close to the screen and look across it at a acute angle
now if the black screen looks like it is still displaying an image then it's definatley your backlights!
in which case it could be a simple fault in the power supply.
so if your feeling confident in yourself i can talk you through what to look for in the supply..but try this first and get back to me.
hope this helps,ben :-)
Jan 06, 2011 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
IPhone won't charge - stuck in screen with battery and bolt
i have the same problem with my iphone 3gs 32gb have you found something that has worked? ive tried everything let me know if u find a way!! please!
Dec 29, 2009 | Apple iPhone Smartphone
Screen Works With One Computer But Not This Mine
Soundes likw interference do you have electrical high lines near that area.
Feb 13, 2009 | Gateway FPD1765 17" Flat Panel LCD Monitor
ViewSonic VG170m 19 in. flat screen monitor
plug it in at the back of the monotor.....i left my connector undone and it fell out a LITTLE bit on one side of the connection and all i got was a blank screen also.
good luck
Feb 11, 2008 | Computers & Internet
No picture but sound works.....
  • adjust brightness setting when playing tv.
  • adjust screen control located on flyback transformer.
  • hope this will help.
Oct 23, 2007 | Sony KV-36FS16 36" TV
Mitsubishi vs 5051 rear projection tv sound but no picture
No video but good audio Mitsubishi VS5051. Check R509 and R 519, 100 ohm resistors located on the main PCB near the flyback transformer. Also bad connections on any of the yokes and the vertical output IC will cause the same problem.
Sep 19, 2007 | Mitsubishi VS-5043 50" Rear Projection...
No picture on tv
probably you need to replace the picture tube or maybe theres a loosed connection in the high voltage circuit or the video circuit due to the fall. if the picture tube is the problem, you better buy a new tv coz replacing it is not practical and economical. but if it is only loosed connection just bring it to a qualified technician for sure he will not charge you too much for this problem. good luck!
Mar 09, 2007 | Sanyo AVM-1909S TV
Samsung DLP HL-P5663W 56" TV Logo
154 people viewed this question
Henry  Thomas
Henry Thomas
