Question about Tappan TGF320 Gas Kitchen Range
Oven does not heat
When I turn the oven on it does not heat. back a couple of months ago if I open the oven door rapidly and slam it a few times it would click on and start heating. Now nothing happens. I can see the pilot is lit and it warms up to about 70-80 degrees if I had to guess (probably from the pilot.) Any ideas for trouble shooting? The last time i did the door slamming trick I smelled a faint odor of gas but still nothing happend. Any ideas???
  • neogeo2308 Jul 06, 2008
    I have the exactly the same problem. When I turn the oven on, there is no smell of gas, no sound of gas hissing, nothing. Just the heating element coming on and that's all. I know it is not a problem with the gas line, because the top burners will turn on just fine.
    I wish I knew a fix for this, because tonight we were going to have a steak dinner with baked beans. Now we have no way of making those beans. :(
Ignitor, good luck getting the old one out. That is why I'm here.
Posted on Jul 17, 2008
Noisy fan and no heat
Kitchen aid is made by Whirlpool. There is a very good chance the then thermal fuse on the back of the oven has tripped. Whirlpools are very prone to this fuse tripping after a clean cycle. The noisy fan is just that a noisy fan it will probably need replacing. I have replace a couple of them over the years. When you pull the oven out to replace the thermal fuse replace the fan motor at the same tiome.
May 06, 2014 | KitchenAid KEBC207 Electric Double Oven
We have had this microwave for 7 years. Not had any problems until about six months ago when the volume went way down when you push the buttons and timer, but still heated. Then all of a suddon it does...
Remove the cabinet ... check the door safety interlock switches for proper operation. Most of the time, no heat problems can be traced to the oven thinking the door is open. These switches tell the oven if it is open or closed. If they are faulty ... well ... the oven thinks the door is open and will not turn on the heat.
Make sense?
Thanks for your question today.
Feb 06, 2011 | Whirlpool MH1150XMQ Microwave Oven
I have an 1100 watt Aurora. It has power the display lights up but it doesn't heat up. It was purchased from Home Depot about 5 months ago
Five months ago ... it may still be in warranty. If so .. take it back ... dont open it up ... you will jeopardze your warranty standing.
Do you ever open the door while the machine is running? If you do ... the door satery interlock switches may have failed. If there is no warranty issue, you may want to remove the cabinet and check these little switches.
What happens is this ... when you close the door, the switches report to the oven that the door is closed and it is OK to turn on the heat. If the switches are burned, the contacts don't close and the oven thinks the door is open and will not turn on the heat.
Thanks for your interest in FixYa.com
Jul 08, 2010 | Microwave Ovens
OVEN LOOSES HEAT ONCE DOOR IS OPENED
check the t-stat may need to change if it works then doesn't you have a damage t-stat replace.
Jan 06, 2010 | Smeg Ovens
It wont heat anymore and the tray stopped turning a few months ago
Im sorry to hear you are having this trouble.
I believe you have a faulty door safety interlock switch. Please remove the cover and check the small micro switches with your ohm meter.
What frequently happens is this: because of opening the door during oven operation, the small points inside the switches arc and burn. Once they cannot make contact, they are not able to tell the oven the door is closed and when the door is not closed (forget what YOU think the door is doing) the oven will not turn on the magnatron. No magnatron, no heat.
Please let me know what happens
Thank you for posting your question on FixYa.com
a
Nov 08, 2009 | GE JVM1630 Microwave Oven
Stove flashed F11 and then locked the oven door
HI, this is control failure. the logic chip set is damaged. this is causing these erratic commands and the unauthorized locking of the oven door. you will need ot replace the control in this case.(EOC/clock)
May 29, 2009 | Frigidaire FEB27S5A Electric Single Oven
Microwave GE MD JVM140K Spacemaker yr= 1994 NOHEAT, DISP/TIMER OK
Call GE answer center 1-800-626-2000
ask for tech help
Have you model # off your data plate ready.
May 10, 2009 | GE Profile Spacemaker Over-the-Range...
I have a gas oven whirlpool sf3020ekq2 buners work but oven won't
Sounding like your hot surface ignitor is getting bad. What I would like for you to do is open the oven and take the bottom panel off. This is so you can see the hot surface ignitor. Turn the oven on and look at the hot surface ignitor it is down on the bottom right next to the burner assembly. Does it start to glow and turn cherry red? This ignitor isn't too hard to replace couple of small screws and two wires. Will have to cut the wires so disconnect the unit from the 120 volt plug. Now if it starts to glow and get cherry red hot then the gas valve is sticking and it is the one going bad. That is a little tougher to replace. Turn the gas off at the source and get your wrenches unscrew the gas valve small space so if you want remove the door by just pulling it off the hinges.
If unit is old and you don't like it anyway maybe santa would be good to you and replace the stove oven. The gas valve is about 60 bucks or so and hot surface is about 20 bucks. let me know how it turns out.. ken
Dec 16, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Fan Oven cooks at high temp when on any setting
Sounds like main oven stat is faulty.
Is the stat sensor fixed properly inside the oven?
Could have been disturbed when element fitted
Please leave feed back.
Thanks
Nov 25, 2008 | Jenn-Air JJW8530C Expressions Collection...
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
Tappan TGF320 Gas Kitchen Range Logo
124 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
