Question about Compaq Evo N110 Notebook
Boot up problem
I have recently bought a refurbished Compaq Evo Notebook for my girlfriend. While using on auxillery power the plug fell out of the outlet creating some sort of power surge, we believe.
Now at boot up, it goes to safe mode or standard boot up DOS screen. When we choose any option on the screen it re-boots back to the same DOS screen. If a recovery disc is the answer, how do we boot up the recovery disc if we can't get off the safe mode DOS screen? Wil a windows XP start up disc provide a recovery mode?
  • 75 Answers
Well, when the dos screen prompts, it will have an option to start windows in safe mode.Just press the down arrow buttons till it is highlighted and press enter.it will start in safe mode.
If that does'nt work, put your windows xp recovery cd and restart.As soon as it restarts,it will show press f10 OR esc.press esc to enter windows boot option and recover windows by following the instructions.THIS SHOULD WORK!!!!
THANK YOU!!!
Posted on Jun 26, 2008
    Genius:
  • 1,011 Answers
Dear sir/madam,
Please try these following steps.
1.) First You Need to Check if the HDD is Working Properly Or Not, So First Turn off Your Computer Completely and U Have to Tun it Back On.
Now As Soon as U Turn it On(Before the Compaq Screen Disappears, Keep Tapping the F10 Key Immediately To Go to BIOS.
Now In Your BIOS Go to The Tools Option and Execute the HDD Self test, Both Short and Long
[If the Test Fails Call Compaq Support @ 1-800-HPINVENT For Replacement]
[If The Test Says No IDE Device Found - U Must Try to Reseat the HDD]
[To Reseat the HDD - Turn U R NB Upside down and U Will Find a Comparment That Has the Symbol of Stack of Discs or Cds, Just Unscrew the Compart Ment and Pull the HDD Out, Then Put if Back it And Screw it Back]
Dont Worry - The Steps I Quote Here, Are Compaqs Prescibed Steps and It Will Not Void U R Warranty, If Fact If U Call Technical Support, They Will Advise U to Do the Same thing!!!!
If Both the Tests Pass then The HDD is Fine(90% It Should Not Be the Problm)
2.) Again Turn Your Computer Off and Turn it Back On and Before the Compaq Screen Disappears, Tap the F11 Key Which Bring Up the Built in Recovery Partion Menu.
From then On It is All Menu Driven
Note : Select Destructive Recovery If U Don't Have Any Importat Data in U R HDD
Else Select Non Destructive Recovery
For more information Contact:
www.hp.com/support
Good luck
Thanks
"Don't Forget to rate the solution"
How do i install an operating system on a compaq SLT 386s/20
Compaq Evo N600C PIII 1.2Ghz, 20-30Gb, 128-256Mb, DVD/RW ,Sealed,Refurbished,No OS. (COMPAQEVON600C12) PC Notebook
Aug 03, 2012 | Compaq Evo N600C PIII 1.2Ghz, 20-30Gb,...
I recently disassembeled my laptop to fix the power adaptor inside it. After reassembely i cant boot my laptop. Disk read error. What can i do?
Perhaps you simply need to ensure you have the, correct HDD set and the boot device set properly in BIOS?
Make sure the HDD is working and OK, if you can use a HDD to USB "Dongle" and test the HDD on another PC, to see if it is indeed OK.
Jul 05, 2010 | Compaq Evo N610C Notebook
Evo n610c won't power up
pls connected to pc to mobile phone bluetooth connected
Mar 14, 2009 | Compaq Evo N610C Notebook
Repairing windows on evo 400c that will not boot?
you must have the os cd or the boot cd in order to repair the corrupted files it's clear that it's in the os
Jan 10, 2009 | Compaq Evo Notebook N400c
Time and date wont store
A battery would fix this but it is the battery on the motherboard that you need. How old is this computer?
Dec 30, 2008 | HP Compaq Evo Notebook N600c
How to bypass or get rid of username and password
Hey im an IT guy. I use this program on our company computers all the time. http://home.eunet.no/pnordahl/ntpasswd/ the program here u will burn to a disk and then boot from it. its pretty self explanitory and the website will explain it a bit more. but this will clear a password off of any account, even the adminisrator one.
Compaq evo-d510-boot problem
What have you recently plugged in as new hardware ? this F1 response indicates that a piece of hardware is not properly configured to run , and F1 is the offered option to go to CMOS to complete the installation.A most likely item will be a USB powered piece of hardware.
Nov 27, 2008 | Compaq Evo D500 PC Desktop
How to reset BIOS password for Compaq EVO N160 notebook
Do the following steps -
- Remove the laptop battery - Remove the CMOS battery - Leave it for idle for around 15 minutes - Put the CMOS battery in - Boot the laptop  with AC power - Then put the laptop battery in.
 - The BIOS pwd would have been reset now
- For troubleshotting the battery - Go into BIOS and run the Battery Caliberation tool
Hope this helps. Thanks, AK
Oct 27, 2008 | Compaq Evo N610C Notebook
EVO n600C NOTEBOOK battery not charging.
1. Check the socket u pluged it in
2. have the charger tested for continuity.
Mar 14, 2008 | HP Compaq Evo Notebook N600c
Boot up problem
It is possibly the RAM it may have ceased. Look at it underneath held in by two screws. Take it out and examine it then put it back. The motherboard seems ok because you said the lights are lighting up. Sometimes the ram can stop even the bios and nothing can boot up.
Oct 03, 2007 | Compaq Evo Notebook N115
Compaq Evo N110 Notebook Logo
130 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
