Question about Sony CMT-NEZ30 Shelf System
Sony CMT-NEZ30 no sound, goes to standby
Hi, i have a Sony CMT-NEZ30, and when i turn it on, radio, of CD, there's no sound that comes out when it's playing. So i tryed putting the volume up and when it reaches around volume 19, it shuts of and goes on standbye, and nothing works. the only way to get it of standby is to unplug it and replug it, and the same problem starts again, no sound, goes on standby if you put up the volume
I tryed it pretty much all the plugs in the house, and same result. My mother sent it to tech down at her office and they said it worked just fine.
please help
thank you
  • Anonymous Jul 18, 2008
    I have the same Fail, I 'll Check the power supply Board for "cold" or poor solder I hope resolve this Issue. try to resolder the power supply module.
    Regars
    Genius:
  • Sony Master
  • 1,550 Answers
Check your speakers maybe one are about to burn out
Posted on Feb 11, 2009
My sony cmt-nex3 has the standby light flashing, but when i press the on butto, it doesn't turn on
Check the back for speaker wire shorts, next! there may be a short in the audio output chip or surrounding parts in the stereo, this is more suited for a technician to sort out.
Jul 03, 2012 | Sony CMT-NEZ3 Shelf System
I got a Sony CMT-NEZ30 from a friend and I don't
Get the manual , which a simple search engine query for "sony CMT-NEZ30 remote" would have led immediately to...
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CMTNEZ30
As far as remote failures go...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Jul 28, 2011 | Sony CMT-NEZ30 Shelf System
Hi there, I bought this device in the US in 2006 but live in Germany right now. Is there a way to change the power supply so that I can operate the device with 220V? Thanks Henrik Kraus
Hi. There normally is a switch at the back of the unit close to the power wire coming out of the unit. Normally a black switch which requires a flat tip screwdriver to adjust from 110v to 220v. Sometimes the switches are red and can be flipped by using your finger. Hope this helps.
May 31, 2011 | Sony CMT-NEZ30 Shelf System
My sony mp3 player CMT-NEZ30 has a tape casset player that is missing the tape drive wheel, I need the Wheel and instructions on how to install. Or a repir facility ion Denver Colorado that can do this...
Welcome to Fixya. It is better to bring it to a service center so that they can provide you with the right wheel for the CMT-NEZ30. For you to be able to find the nearest repair facility of Sony at Denver Colorado you can use the link below. You just need to enter the ZipCode and the Model Number.
Sony Repair Center Locator
If you have questions please let me know. Thanks for using Fixya
Mar 18, 2011 | Sony Vertical iPod micro system CMTLX20I...
Sony CD/Radio CMT-EP505: Setting fixed radio stations
Click Sony Support to download instruction manual copy of CMT-EP505 that has operation details of every thing in this system.
Jul 07, 2009 | Sony Audio Players & Recorders
CD is not playing on my SONY Home Audio CMT-EH15
HI. that grinding sound is signaling a lens assembly issue. the linkage and gear assembly seems to be jammed. this assembly must be able to move freely i order for the lens to track the CD. if the lens assembly is stripped or jammed, it will not be able to read and it will shutdown into stand by mode to prevent the motor from damaging itself. its most likely gear failure.
Unfortunately, the repair parts for this unit are only available from sony repair depots and, you will need to contact sony manufacturing in order to receive a repair ticket.
May 19, 2009 | Sony Audio Players & Recorders
Cd player not working
Hello
Replace the laser pickup unit along with its connection wire to main board. OK.
Apr 08, 2009 | Sony CMT-NE5 CD Shelf System
Sony cmt-hp7 - broken
The unit will attempt an internal reset to start from a known position. If you are hearing mechanical noises, the unit is out of sequence and must be rebuilt. These are not the most straightforward units. If any portion of hte system fails the "startup" sequence, the entire unit will stop. Unfortunately, this may need to see a servicer.
Dan
Mar 21, 2008 | Sony CMT-HP7 CD Shelf System
Sony CMT-NEZ30 Shelf System Logo
475 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
