Question about HP Deskjet 2460 InkJet Printer
Can't feed bulk papers - reg.
Hi
we can't feed bulk papers, how to feed bulk papers
with regards,
Dhanabal.K.
IT incharge
dhanabal.kandasamy@jasmineindia.com
  • 81 Answers
Not sure what you mean by bulk papers. Printer will only accept 1 page at a time
Posted on Jan 24, 2009
Sharp calculator EL-1197P III paper feed stuck
Hi
I trust you are well.
This might be trivial however when you replace your paper roll the edge of the edge paper must be cut straight otherwise the paper will not feed correctly.
Hope this solution is as easy as that, If not open the claculator paper feed compartment and check the gear mechanism for chipped teeth or foreign objects stuck inside.
Hope this helps you
Kind regards
Aug 15, 2014 | Sharp EL-1197PIII Calculator 12-Digit...
Hi person incharge, Printer shown error 59.99 Model : HP Color LaserJet 3550
59.99 An error occurred in the secondary transfer engaging mechanism. following four possibilities are mention below with proposed action:-
1. Faulty secondary transfer engagement sensor. Replace the secondary transfer engagement sensor.
2. Faulty secondary transfer engaging solenoid. Replace the secondary transfer engaging solenoid.
3. Faulty feed motor. Replace the feed motor.
4. Faulty DC controller PCB Action: Replace the DC controller PCB.
Good Luck
do Rate if got gelp
Dec 01, 2010 | HP Color Laserjet 3550 Printer
Paper jam in 2nd feed mae z fold from tray 1 and 2
If the paper is "Z' folding at the reg. roller you may need a new reg. clutch or you may clean it. If it "Z" folding in the fuser, you may have a pick off claw that is in the wrong postion. Good Luck
Sep 02, 2010 | Ricoh Aficio 450 Copier
Epson c-88 won't feed paper
Hello sir; You may go to computer to set up; Hit print then go to preference then paper/quality then you can choice the type of the paper you want to print, good luck.
Jul 23, 2009 | Epson Stylus C88 InkJet Photo Printer
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Epson multi fuction printer will not pull the paper in when faxin
Red Light remains on, it make a noise. but nothing happens
Feb 16, 2009 | Epson Stylus CX9400 Photo Printer
Bulk feeder keeps jamming
It might be the tray Feeder not placed properly or the printer needs a service if not done in the last six months. Contact to your nearby Repair shop and Service centre.
Thanks
Scott
Feb 06, 2009 | Kyocera FS-4000DN Laser Printer
Cannon copier
Where is the machine saying the jam is located? Does the paper even start to feed? Does the paper feed to the next feed area? If the machine sounds like it is feeding ( trying to feed) and the paper is still in the tray --- clean the feed roller/ tire with rubber restorer or a high alcohol base cleaner. IF the paper is fed part way out of the tray to the long ( most of the time) black reg. roller and now farther --- clean the reg. roller. There is always the chance that you have a bad feed motor or reg. motor. Also look to see if an actuator / switch has been pulled / knocked out of position. They is is small cradles and can be snapped back into place.
REG = registration
Jan 06, 2009 | Office Equipment & Supplies
When Tray 1 (A4) is empty it is picking up Tray 2 (A4 ? letterhead) and we don?t want that to happen cause we print in bulk! When Tray 1 (A4) is empty it is picking up Tray 2 (A4 ? letterhead) and we don?t...
Hello Uncle123,
I don't have a user manual at my fingers, but you can go into "additional functions". I don't recall if it is within the"common settings" tab or "copy settings" but you can designate any paper tray to be "unique". For example you can designate tray 2 as "colored paper, or recycled paper" .In which case, if you are feeding from tray 1 and it runs out the copier now knows that tray 2 has a type of paper that is different than the current run.Even if the paper size is the same. I hope this helps. Take care. ..............................spinal.........................
Feb 22, 2008 | Canon (6981A002AA) for imagerunner 2200,...
HP Deskjet 2460 InkJet Printer Logo
62 people viewed this question
Seeker5211
Seeker5211
