Question about Microsoft Xbox 360 Console
Samsung MS28 drive wont spin disks
You seem to be wuite knowlegable about 360 repairs. Can you offer advice on the following.
I bought a 360 with the RROD and fixed it with the XClamp mod. Green lights now. However the rom drive would not open even though it tried. When i managed to get a disk in it would say 'reading', no noises just reading..Pulled it all apart, checked the belt. Although its a cheap rubber band it does not not slip as I turned the cogs. Checked the white sliding piece, made some fine adjustments to its returned position. Seemed to do the trick...here is the real problem.
When I insert a disk it wont spin. If I assist it will fire up and the laser only moves a short distance but it still is not 'actually' reading the disk.
Now i noted that the drive was quite dirty - Samsung ms28 (man 2005), which i have cleaned where i can.
Can you suggest what to do next?
Thanks alot for any advice you can offer...
  • 1 more comment
  • Lv-426 Jul 06, 2008
    Turns out the problem was two things...the motors both for the turning of the disk and drive tray. The laser is fine
    Works like a charm now......
  • Anonymous Jul 06, 2008
    My son has an XBOX 360 with the Samsung DVD internal drive, which for no apparent reason has stopped working. It will not eject or close, and if you manually insert a disc and push the tray in - the screen just keeps saying closing or opening, and the game won't start.
    To return it to Microsoft will cost me £65 as it's 5 weeks outside it's 12 months - so if I'm about to throw money away please help me.
    Thanks
  • teuhond Dec 05, 2008
    hi i have the same problem i try to clean all the dust in the driver, when i turn on the 360 the cd spin but the laser only move a bit, now how do you fix the motor problem?
Sounds like a couple of possible problems. First of all, you will need to know how to use a multimeter. From the sounds of it you probably do. so...
1) check the back of the motor for where it is soldered to the circuit board. make sure that they are not cracked or broken. If so resolder them, if not then lets move on...
2) check the lens and clean it with denatured alcohol. Do not use rubbing alcohol as it will leave a film that will cause you trouble. if this does not work then ...
3)Next find the back side of the laser. There will be two small metal potentiometers. take the multimeter (on resistance reading) go across two of the leads on the pot (there are three) two of them will read 0 ohms, you do not want these. read from any one of these to the other lead, you should read around 1.4K ohms (actally 800 ohms to 2K ohms is typical) write this down!! take a small screw driver and make a minor adjustment to the pot. making the reading smaller. Note! the pot is real touchy, a very and I mean very small amount of movement will make a large reading. You do not want to go below 600 ohms as you can damage the laser. a small adjustment should get things going. Once the laser is working the unit should work fine. in a rare few occasions you may have to place a small amount of tape over the magnet to help it actually release, but this will only be a issue if and when every thing is spinning as it should and it still does not open. Also clean the belt with rubber conditioner. If you do not have this you can use the denatured alcohol but note that this will cause the belt to dry out and crack if you do it too often. Hope this helps. If not write me again with more details!!
Talk to you later!!
Posted on Jun 30, 2008
Dropped the hard drive, won't detect. How do I retrieve the files (mostly pictures)?
Bring it to a computer repair store, they have additional tools that will extract the files in most cases.
Jun 29, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
Wont play my games... ??? why does my 360 always say play dvd , when its a game....
All repair guides are a rip off . Every
thing contained in them is available on
line for FREE ( youtube) so take the
money that you would have wasted on
the ( guide) and goto youtube type
"replacing 360 drive " follow the
tutorial find out what drive you have
ie Ben-q , samsung , Hitachi..
goto ebay buy the same make model
drive for 30.00-50.00 and simply
swap your old drives P.C. board to
the new drive and it's FIXED.
If you need more info just ask.
Rob
Jan 21, 2011 | Microsoft Xbox 360 Console
Hi guys I found out why the disk wont read in my system anyway
Interesting. Not all Xbox 360s use the same type DVD drive. There are at least 3 different brands - Benq, Samsung, and Hatachi. There are various ways of determining this, besides opening the Xbox 360. Based on the drive type, there are different versions of firmware(the software on the drive that communicates with the Xbox 360). Some firmware modifications Microsoft doesn't want consumers to know because it allows the playing of cloned dvds.
Mar 28, 2010 | Microsoft Xbox 360 Console
I have the board for my old samsung ms28 but no case is the DVD
The dvd board is located at the back of the drive, it is connected to the motor and things by white strip wires, if you are removing the board pull the wire from the motor not the board,but the others from the board not the dvd drive.
Let us know if this solution works for you.
Jan 12, 2010 | Microsoft Xbox 360 Console
360 dvd drive won't read games and it won't open
buy a new dvd drive online. it is the only way this video might help you how to install it
http://www.youtube.com/watch?v=Bo2dl2vlwis
Jan 03, 2009 | Microsoft Xbox 360 Console
Xbox 360 disk reading probs
We currently have some secondhand dvd drives in stock, Samsung MS28's and Hitatchi 78fk. Both working ok and taken out of working machines that had 3rrod. We also stock all other parts www.fixmyconsole.co.uk
Good luck setting up a business m8, the best advice is to do some research and learn every fault and repair to the point where you know it by hand.
Dec 29, 2008 | Microsoft Xbox 360 Console
Disc wont spin
Sounds like the unit overheated and locked up the processor. This is a comon problem with the 360. Two things. 1) there is a lawsuit in process on the 360. google xbox lawsuit and see if you qualify to get in on this. If not then look for a repair kit. I am not sure if I can refer a specific place or not. But if you google 360 ring of death fix you should find a few quality sites that sell the fix for it. Keep in mind that the fix repair should be no more than $15.00 if it is more they are taking you for a ride. It is an easy fix. Screws and washers is about all it takes. You will also have to do a lot of tear down and play with the heating of the processor a little but if you follow the directions that come with the kit you should have no problems. I repair these things as part of my electronics repair business. (I do not take mail in's though, so I am not trying to solicit business!) But I say that to say that it is not a hard repair. I would suggest a excellent site but I don't think I can by fixit rules. Sorry!!!
Jul 18, 2008 | Microsoft Xbox 360 Console
Open tray with every disk on 360
this happens when the dvd drive/laser is worn out. i offer a dvd drive replacement repair. email me at blue_dragon45801@yahoo.com
Jun 19, 2008 | Microsoft Xbox 360 Console
Console doesn't "read disks"
Where did you get the console from and where are you located?
Cheers
Jun 04, 2008 | Microsoft Xbox 360 Console
My xbox 360 is always freezing up and it also leaves a scratchs on my games. its already trashed 3 games. The scraches are to deep to repair and they are in the same place for all my games.
Never say Never, If you want your 360 Games Repaired.
I Can Offer You a service to resurface Them.
If your in The UK, you can send them To Me.
If in USA Theres usually good Disk-repair services In DVD Rental Stores, where they,ll repair your disk for $3-$5.
I also offer a full And Comprehensive D.I.Y repair Kit, With full Instructions, And Materials Required. This Is £5.00 Or $10.00.
Your Actual problem is That Your DVD Drive, Or Laser Head, is Hitting The Disks, whether this is due to a calibration fault, or it,s been knocked over dropped, at any time. Which may have Damaged The Disk-Spindle, et,c.
Hope this helps.
Mike @ compurepair.
Posted @ 20.41 GMT. :)
Mar 02, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
1,281 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
