Question about Acer Computers & Internet
My monitor is disconected from keyboard on my acer 3620 notebook the cords are still connected it will turn on and everything but the screen turns white no pic i here sound just no pic i need to see a wire diagram or something so i can connect it again
  • 214 Answers
Hi, p;ease clrify that is it a PC desktop or a laptop.
and also please elaborate the problem little more.
monitor is not connected to the keyboard, its to the cpu. please be clear.
Posted on Jun 26, 2008
Power black screen failure hp pavillion dv2000
Normally is because the battery is empty or in an error state.
If you plug the power cord and the led still blinking, disconect everything, turn your laptop and search how to take out the battery, wait 1 minute then replug it again and try.
May 25, 2014 | HP Pavilion dv2000t Notebook
Tower turns on but screen says no signal?
Check to be sure your monitor connection needles are seated properly. Is mouse wireless or connected to back of tower?
Jan 02, 2014 | Acer Aspire X3200 PC Desktop
Will not stay on.power comes on then turns off on both battery and power lead
Did you verify the screen connection. Try lowering the monitor as close as possible to the keyboard and try to turn it on, after it is turn on bring back the monitor to the original position. If turn off automatically the connection of the monitor is loose. See a tech.
Mar 01, 2011 | Acer Aspire One Netbook 8.9" Notebook
I'm connecting to a tv with a VGA cable from my Acer netbook. My tv says No Signal. Windows makes the "ba dum" sound when I connect/disconect the cable, but under my display settings, it doesn't...
Don't forget that the TV source or input needs to be set to "PC". Once that is done turn the netbook OFF, then plug the VGA cable into the netbook and start the computer. The computer screen should automatically show up on the TV.
Nov 10, 2010 | Acer Aspire One PC Notebook
Acer Aspire One notebook model zG5, i hear the hard drive come on, but screen is blank and the keyboard does not respond.
connect the laptop to an external monitor, turn it on see if the monitor will display.
If the monitor displays, then it means your screen inverter or screen bulb is the cause of the laptop screen being blank.
Also if the monitor does not display anything, the maybe the graphic card is the cause of the problem.
This would involve you taking the laptop to a repairer
Take care.
Apr 15, 2010 | Acer Aspire One PC Notebook
I need to replace the keyboard on an Acer Aspire 3680 series laptop
Hi there.
Remove the laptop battery and the AC power supply, open the lid as far back as you can take it.
Get a small flat headed screwdriver, now, you have to take off the keyboard bezel, this is the strip of plastic above the keyboard with the power button on it, the best way to remove it is to start by the on/off button by gently prying the bezel up from the lid hinge, once you have one side out gently pull it up using your fingers, it will unclip and lift away.
Next you have to remove 2 screws from the top of the keyboard, these should be visible to you, once the screws are out carefully lift the keyboard up, you will see a ribbon cable that is connected to the motherboard, gently pull the tab up on the connector that the ribbon cable sits in and it should release it and you can now remove the keyboard and replace it.
To re-assemble just follow my direction in reverse.
Please post back with the results and for any additional advice if needed.
Good luck and thanks for using FixYa!!
May 22, 2009 | Acer Computers & Internet
Acer Aspire 3620 will not recognize external monitor.
When in windows, the 2nd monitor output needs to be turned on for it to show picture.
Right click on your wallpaper and select properties, and then settings.
You should see a page similiar to this, the number 2 would be the external display, you need to right click on it and select attach. then you can adjust its settings below and click apply.
If you don't see the 2nd display there, then it needs to be enabled in another location.
Apr 18, 2009 | Acer Aspire 3610 Notebook
Prolem with acer 3620
Try a new memory stick initially, Only 1 if the cost is high and see if it does boot up correctly. If not then you probably have had a surge or lightning damage and may need a new power supply. Just try the memory stick fist then go from there.
Apr 17, 2009 | Acer Aspire 3610 Notebook
Connection cords for Acer flat screen monitor
You would need a 15 pin HD D-Sub cable with appropriate connectors model number HD-15. Pls try here or here to view similar products.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Dec 03, 2007 | Acer AL1714 17" LCD Monitor
Computers & Internet Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
