Question about LG VX9400 Cellular Phone
Phone is acting strange
When i turned on my phone i try to dial numbers when i press one number another number pops up with it and an example is when i press number 3 the number 2 comes up up with it and it does the same to my texting icant text any more since when i try to put a letter in there all kinds of them pop up and in my menu it won't let me go down only up or side to side so tell mewats going on
Yeah that happened on my fourth version of my phone. Did you drop it in water? Because when I accidentally dropped it in water (the first time), it did that and all the keys were short circuited and I couldn't do anything. I took it back up to Verizon and just said that the keys don't work anymore, and the lady didn't even try it out, she just took it and gave me a new one without doing anything.
You can't really do anything to save it at this point. Just go up to Verizon and say that the keys don't work. Maybe you'll get as lucky as I did.
Posted on Jul 26, 2008
What is my phone info using the serial number
try dialing the following code then press sent or call/dial.
*#06#
another code to try
*#*#4636#*#*
let us know how it goes
Aug 09, 2014 | Cell Phones
How do I set up speed dialing on my phone DECT1560 ?
ou can save up to 8 phone numbers in your speed dial book. The speed dial keys go from 2 to 9. When you place a call, our system prompts you to "enter the phone number you wish to dial". You just press the appropriate speed dial key followed by the pound sign (#) and your call goes through. No long numbers to enter any more!
If you set a speed dial for our access number on your phone machine, you have to press three keys only to complete a dial - as easy as "1-2#"! That's it!
For example, you can set your parents' phone number as speed dial key 2 and your friend's number as key 3. After dialing the access number from your phone, you will press 2 then # to reach your parents, or press 3# to reach your friend. Nothing could be easier!
Speed Dial set up Instructions:
Dial the access number, wait for prompt.
Enter PIN number, wait for prompt.
Dial: "#" "2" "#" [a speed dial number: 1-9] "#" [destination number] "#". The system will confirm the number.
Example: [#] [2] [#] [5] [#] [011-888-88-88-88-88] [#]
Use Speed Dial:
Dial: [speed dial key (1-9)] "#"
Hope this will help to solve the problem....
Aug 18, 2011 | Uniden Cell Phones
Why does vtech not have a speed dial? my son is
Programming Speed Dial Numbers
The handset must be OFF.
1. Press PROG. The IN USE LED will blink to indicate that you are in the programming mode.
2. Press the number of the memory location you wish to store the number in (0-9).
3. Using the dial pad, dial the number you want to store. The number can be up to 16 digits long. The number can be entered manually or by using REDIAL.
4. Press MEM to store the phone number
to the key you selected.
The phone now exits PROG mode and emits a tone.
Speed Number Dialing
1. Press PHONE to get a dial tone.
2. Press MEM and the memory location number key (0-9). For example, to dial the number you assigned to key '8', you would press PHONE, MEM, 8
May 27, 2011 | Vtech 9009111 Cordless Phone
How do I manually enter phone numbers into the "speed dial" directory of my Toshiba FD-9859 cordless telephone?
Welcome to Fixya
To program a speed dial on your phone, enter programming mode (press #9876 on your phone). The phone will display "USER PROGRAMMING MODE." Press the Spdial button, enter a speed dial number (100-119), 9 plus the phone number you wish to dialed (1-213-555-1212 for example), then press the Spdial button one more time to lock it in. To use a programmed speed dial, just press the Spdial button plus the number.
Thank you for using Fixya!
Apr 06, 2011 | Cell Phones
Speed dial
go to your phone book select the person...now go to options and add to speed dial (slots 2 thru 9)...
to speed dial..go to phone and press the number on keypad then press phone...you can also speed dial 11 thru 250...by pressing the number then #....come just for the fun of it...go to phone and the keypad (act like we making a call) now press 19# (who came up)...try 15# and so on (this also depends on how many is in you contact....if you only have a fave 5...19 & 15# will not work,,,
feel free to rate the help
Jun 16, 2009 | Dual Electronics CECT P168 Cellular Phone
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
CHANGING FEATURES? ON LUCENT PARTNER-18
from extension 10 or 11.
feature 00
pres the speed dial you want
feature 600, thype the number in.
repeat for as many as you want to modify
when done, press feature 00
Jan 22, 2008 | Lucent PARTNER18 Corded Phone
Unlock LGVX8300 passcode
Try dialing *228, then pressing 1. This reprograms the phone to factory defaults, making your security (lock) code the same as the last four digits of your phone number. For example, if your phone number is (315) 123-0101, then after following the above instructions, your passcode is now "0101". *228 is accessible EVEN when the phone has been locked. This method does NOT delete contacts or change your phone number. All of that information remains the same as before you dialed *228. Also, you do NOT need to remember your old passcode for this to work.
Nov 21, 2007 | LG VX8300 Cellular Phone
Motorola A1200
while pressing a number in dialing dont press it continuosly for more than 3 to 4 seconds otherwise it takes number as turbo dialing number.
In setup(in the dialing menu where numbers are displayed) there is facility of turbo dialing i.e. speed up dialing such that you provide phone numbers numbers between 1 to 9 for example in 1st number you provide number of your dad then when you press 1 continuously then your dad's number gets called. So, as you have not set your turbo dialing this message has appeared.
Nov 03, 2007 | Motorola Mobility A1200
Programming
MEMORY
Store as many as 12 numbers in memory for easy dialing. Three can be stored in the Emergency Quick Dial locations, and nine additional numbers can be stored in the numbered keys (1-9).
STORING A NUMBER IN MEMORY
1. Press SPEAKER (or pick up the handset).
2. Press STORE.
3. Dial the number to be stored (up to 16 digits).
4. Press STORE button.
5. Press a Memory Location (1-9 on the keypad), or an EMERGENCY QUICK DIAL button.
6. Press SPEAKER (or hang up the handset).
7. Record the phone number on the memory directory (located under the plastic cover).
ADDING A PAUSE TO THE DIALING SEQUENCE
Use the REDIAL button to insert a delay in the dialing
sequence when storing a number, for example, when you need to dial 9 to get an outside line. Press REDIAL at the point in the dialing sequence in which a pause is required.
CHANGING A STORED NUMBER
Change a stored number by replacing it with a different
number.
DIALING A NUMBER FROM MEMORY
You can dial numbers from memory when using the handset or speakerphone. When you get a dial tone, press the MEMORY DIAL button followed by the memory location (1-9) for the number you want to dial.
Apr 27, 2007 | GE 29318GE1 Corded Phone
LG VX9400 Cellular Phone Logo
48 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
