Question about Sanyo DRW-500 DVD Recorder
Sanyo DVR-DX600 dvd recorder
On the above machine the remote has stopped working despite new batteries. Any suggestions please?
Remote does not work even when new battries
Posted on Dec 04, 2009
Pioneer dvd recorder dvr 310
Resetting the Recorder to Factory Settings
1. Make sure that the recorder is on
2. Press and hold the STOP button and STANDBY/ON button.
The recorder turns off with all settings reset.
Try this and let me know if it works.
Mar 27, 2008 | Pioneer DVR-3100 DVD DVD Recorder
Where can i get dvd discs for my sanyo dvr v100e
You can get them just not in stores they typically only carry the latest and greatest.
I have done some searching and found a few resources to get them fairly cheap as well.
Hope this helps, thank you for stopping by Fixya! Please leave a positive rating if this solution has helped.
Mar 16, 2009 | Sanyo DVR-120
I have a DVR-DX600 Sanyo that suddenly wont scan the television stations anymore. I think my son wrecked it somehow. It has been working fine. I can get the tv stations on the television fine, but...
Is your arial cable insert right and properly into the arial in on your DVD recorder and the out arial from DVR go into your TV or you have 2 arial for each unit
If your installation were correct you might got the problem in the tuner pack on your DVD recorder it require a Technician to repair
Or tell me exactly how are your arial cable goes from where to where
Nov 30, 2008 | Televison & Video
Sanyo DVD recorder DVR-DX600
I don't know about where you guys are but when I went on to and went into support and insturction manual searched DVD recorder it came up with english manuals for all their DVD recorders, just cick on the one you need
Jun 09, 2008 | Sanyo DRW-500 DVD Recorder
Sanyo DVR-DX600 Region Code
Could you pls try:
1. Remove DVD or video from the player.
2. Press the ‘Set-up’ button on the remote control.
3. Select the ‘System Info’ mode from the on-screen menu.
4. Using the remote control 10-key type in ‘1101′
5. ‘Region code’ should appear as an option on the ‘System Info’ menu. Initially the region code will be set to 2. Press ‘0′ on your remote control using the 10-keys to set to multi-region.
6. Press ‘OK/Enter’ on the remote control.
7. Finish by pressing the ‘Set-up’ button once more.
This was actually intended for a Sanyo DVR-V100E &HVRDX610 but I was made to understand should also work for DVR-DX600. This was originally posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 08, 2008 | Televison & Video
Cyberhome dvr1600 remot
try replacing the decoder.. i have same problem but i solved it by replacing the decoder... the new one..
Mar 13, 2008 | Cyberhome CH-DVD 300 DVD Player
Cyberhome dvr 1600 Remote
codes for this dvr are
they don't work for my new remote but everywhere says they are right
Jan 21, 2008 | Cyberhome DVR 1600 DVD Recorder
Remote control will not work?
Hi Quad, recently I also got same recorder and faced the same problem with the remote controller. today i tried to solve this. i opened it up. it turned out the battery connections are not proper. The battery connection are in the form of a spring coil which touches the outerside of the battery which is not touching properly. I bent and slight lift it with a plier and it started working. The other connection is touching front side of the battery(on backside you see label cr2025 printed) and this is alright. I hope it works for you too. with best regards
Nov 26, 2006 | Cyberhome DVR 1600 DVD Recorder
Sanyo DRW-500 DVD Recorder Logo
233 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
