Maxent Mx42HPT51 42in. plasma Problem: I have a black line that goes from top to bottom of my screen about 3 inches wide.
  • 9 more comments
  • lizmiller952 Jun 26, 2008
    what do i need to do to fix the problem
    what is power cycle
    what is a power cycle
    how do you power cycle
    what are you talking about
    i have a black line that goes up and down on my tv
  • lizmiller952 Jun 27, 2008
    I want to replace the screen on my Maxnet plasma 42" MX42HPT51 where do i goto get this item
    nn
    I have a maxent 42" plasma tv MX42HPT51 ineed to replace the screen on my tv where do i need to go to order the part
    I tried unplugging and powering down and it still has the black line from top to bottom I need to replace the screen on the tv maxent MX42HPT51 where can i buy one
    the line is there without the cable. you have a blue screen withe a black line on the tv maxnet mx42hpt51
    President:
  • 357 Answers
Hi there
There are a few possible reasons for this.
1) This could be caused by having many connections in your cable (you have joined two or more cables).
2) You could have a faulty connection at your TV or your LNB.
3) Your dish might be faulty of pointing slightly off it's target (satellite)
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 27, 2008
    Genius:
  • 2,035 Answers
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Certainly, I can help you. I would recommend going to the following link and getting the service manual so he can see first hand disassembly instructions and testing proceedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a new screen. heres the link.
http://servicemanuals.vstore.ca/
  • 75 Answers
I think it's a problem with ur satellite dish or cable u r using.Try disconnecting the cable wire and then check once.just leave a message to my email id damy.damy.bobo@gmail.com of what happened after u have finished checking. I ll be back to u with a solution.
THANK YOU!!!!
Posted on Jun 26, 2008
    Genius:
  • 1,847 Answers
Try power cycle. and reload the foctory settings.
  • Legin Varghese
    Legin Varghese Jun 26, 2008
    if that doesnt work, It's going to require a trip to the shop. It can be fixed, but the expense may be prohibitive unless it's under warranty.
    This is a serious problem. It may be a design problem or a defect in the video processing. or digital error buildup of some kind - it is not an easy one to diagnose without some hands-on observations and measurements.
    A technician will have to put on an oscilliscope and trace through the circuits and find out where the vertical bar is being introduced. These sets are grossly complicated from a circuits point of view with several IC chips that make it difficult to troubleshoot.
Best picture settings for samsung ps50a457p1d
my 50 inch samsung is 4 years old. a black line has appeared just off centre screen. the line is approx.an inch wide and runs from top to bottom. can it be repaired?
Mar 08, 2012 | Samsung PS50A457 50 in. Plasma TV
I have a single thin horizontial black line six inches from the bottom of the screen. how can it be fixed.
Hi.
The line is probably in correspondence of the low Y buffer board, located inside the TV and connected to plasma display. In that case the board must be replaced to fix the problem. One of the symptoms of a defective low buffer board is a black line that starts from the bottom of the TV.
Regards.
Ginko
Apr 25, 2011 | Maxent MX-42HPT51 42 in. Plasma TV
Black line on Plasma Tv
Hi my name is Eric,
I hope I can help you with your issue ,
Bad news is you need a new panel. that is the screen itself.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Eric
Sep 27, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Vertical black lines appear intermitently
Does the line appear on just one input(cable,hdmi,video1,video2,ect) or on all of them? The reason why I ask is it may be just an issue with one input setting on the television and you may be able to use a different input for a temporary fix of the problem. Plasma telivisions run very hot and it may be overheating. Try using a small mountable fan above the TV pointed into the back heat vents and see if keeping it cooler keeps the issue from happening. These TVs are repairable but usually cost more to repair than what it is worth due to plasma TVs are very in-expensive now.
Sep 04, 2009 | Maxent MX-42V1 42 in. Plasma Television
Black vertical line about 3 inches wide from top to bottom on rig
See if you can center the picture in the setup menu. It sounds like it's just off center.
Jan 15, 2009 | Daewoo DSP4210GM 42 in. Plasma Television
Black bar running from top to bottom in the screen.
There are horizontal and vertical relays in plazmas that go out over time and cause this to happen , You can get an estimate from a local tv repair service in some cases they can give it to you over the phone. Good luck.
Dec 30, 2008 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black band running from top to bottom of screen
this will need to go into the shop to get one of the video processing boards replaced that controls that part of the screen , this will happen when it gets to hot inside the set ,( thermal break down)
electech
Oct 31, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Electro Med Services...
