Question about Epson Stylus Photo 1280 InkJet Printer
Epson 1280 Solid red mainteance light
Hi. Just purchased this printer second hand, was apparently working before shipping. When I connected the printer the ink carriage moved 1/2" and then solid red maintenance light came on. There is nothing jammed in the printer. Now ink carriage is stuck at the far left hand side. Any suggestions?
    Genius:
  • 1,447 Answers
Hi-
Is iot on the position where you can install the ink cartridge? try turning it off and unplug it from power supply then after 10mins replug and turn it back on. keep me posted, but if it will do the same thing chances are there is something wrong with the belts on it, better have it fix or have it check. Thanks for using fixya!!
Posted on Jun 26, 2008
  • 1,218 Answers
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5005876-epson_stylus
Posted on Oct 04, 2010
I saw the solution to flashing green and red lights on my Epson 1280 was to clean the waste pads. Now I'd like to know how to do this! Thanks.
first go to this website download their software http://www.ssclg.com/epsone.shtml. after that install.
second go to counter reset improvements reset counter or go to protection counter to reset counter.try this but i no sure which oen please try this two method to see can or no
Aug 15, 2009 | Epson Stylus Photo 1280 InkJet Printer
Banding and splotching in solid color fields epson 1280
If you print with high speed, try to print without high speed. If problem remain, you need PF adjusment, use Adjusment program for 1280. Try to find at indoreset.blogspot.com
Jun 06, 2009 | Epson Stylus Photo 1280 InkJet Printer
Epson 1280 red ink low light will not go out. Have tried replacing both ink cartridges and have disassembled the unit and cleaned the waste pads. I have tried the reset sequence posted on here but it...
Epson color 777 Printer isn't working, the print light is on, but so is the red error light, ink jets are filled, had that confirmed, plenty of paper, what's the problem?
Jan 16, 2009 | Epson Stylus Photo 1280 InkJet Printer
Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson 1280 Will Not Take Paper through to print?
Follow the instructions below in an attempt to resolve the issue you are experiencing.
1) Turn off the printer and remove all paper from the paper tray.
2) With the printer off, check for any obstructions such as torn paper or foreign objects.
3) Place 20-30 sheets of paper in the printer, ensuring none of the paper is torn or creased.
4) Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
5) Attempt printing.
Apr 19, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson 1280 -alternating green red flashing lights
you could use it for a table top computer archeological relic. the flashing lights will attract peoples attention, and start conversations at parties.
Mar 23, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson 1280 Printer breakdown
it is the wasted ink pad, they are full.
to have your printer work again
turn off the printer.
press and hold the ink and paper button while turning on the printer, wait for 5 seconds then release the button and press the paper button for at least 10 sec.
if done correctly , you will see the carriage start moving
Jan 20, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson 1280 red lines on photo
One of the best possible solution that we can suggest is to run a cleaning cycle for three times. Just to make sure that cleaning is effective please try the step below:
1. Using your computer go to printer utility.
2. Click on Maintenance then select Head Cleaning. Head cleaning usually took 1 minute.
3. Once the Head Cleaning is done Print a nozzle pattern to check whether the head cleaning is effective or not.
Repeat those steps for 3 times. If the nozzle pattern after 3 cleaning cycles still bad. Reseat ink cartridge if possible replace the ink cartridges.
After all those steps and issue still present printer needs to be in service.
Aug 05, 2006 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus Photo 1280 InkJet Printer Logo
267 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
