We need samsung sp1654n firmware update please.....
Samsung ml 2010 firmware update, samsung ml 2010 not responding when paper end
Dear
you need not update firmware for this model. Pl. do the printer status monitor(SMART PANEL). Down load from samsung site and run inpc application. when print command given it will display the problem.
Thanks.
Dec 31, 2014 | Samsung Office Equipment & Supplies
Whicch website can i update my samsung s8000
for firmware update, go to
SAMSUNG S8000 FIRMWARE UPDATE FULL
proceed with caution because there are versions of the Samsung Jet S8000 that are incompatible with the firmware
Jan 26, 2014 | Samsung Jet S8000 Cell Phone
Update firmware
As long as Samsung does not offer a new update for the firmware, you cant' update. When you are smart enough to write your own firmware, you could flash that into the camera, but then you did not need to ask this question. For this camera Samsung did not offer an update yet.
Dec 16, 2013 | Samsung PL120 Digital Camera
Ml2010 got updated with 1610 firmware i need to update it with ml 2010 where can i get the firmware please let me now the link
Samsung don`t have firmware update for ML1020.
You can download drivers and others software
Go to
http://www.samsung.com/us/support/downloads/ML-2010
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 23, 2011 | Office Equipment & Supplies
YP-P2 FIRMWARE PROBLEMS
have u tried the reset pin on the back? give that a go.
Feb 12, 2009 | Samsung YP-P2 Digital Media Player
I had the same problem!
But I found the fix for it after much searching.
First, download the latest firmware directly to your computer's desktop from the Samsung website: http://tinyurl.com/3j4su4
The file is a Zip one so : make sure you extract the 2 files to your desktop!
-Connect your P2 to your computer and go to My Computer.
-Double click the YP2 icon.
-Copy the 2 extracted files from your desktop into the open window. (Do not put them in an already existant folder).
-Unplug the connection from your computer and restart your player.
It will do an update and shut down. Restart it a second time and it will finish the second update.
- There you go, it should work no problem.
The firmware update from having your player connected to the Samsung Media Studio 5 for some reason doesn't work properly.
By doing in manually it works just fine.
The update link I provided is for a US based player.
Just go through the Samsung site to find an update for other contries if you need too and follow the same directions I give above to solve your issues.
Hope this helps!!!
May 17, 2008 | Samsung Yepp YP-P2 Digital Media Player
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
Computers & Internet Logo
281 people viewed this question
Alun Cox
