Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
Kenmore Model 110.49182992
Can the agitator be removed on this model
Someone at appliance repair answered my question. Thanks for your time.
Posted on Jun 26, 2008
Have a Kenmore Laundry Center (dryer top and washer on bottom) - model is 417.99160110. A towel is firmly under agitator and gave us smoke! How do I remove agitator cap and agitator itself?
Remove the caps on the top of the agitator. Next using a suitable socket, undo the retaining nut being careful not to loose and washers..
Lift the agitator enough to remove the towel. Reassemble...
Apr 15, 2017 | Kenmore Washing Machines
Owners manual for sears kenmore washing machine type 588-08 model number 110-21102011
Many Kenmore appliance manuals are available from the Sears Parts Direct site: . The manual page for the 110.21102011 washer is if you want to read it in your browser. (A PDF plugin is needed.) The direct link to the manual is if you want to read the document in your PDF reader software.
The parts diagrams may be more useful for how to remove the agitator. Those are available here: . The agitator is shown in the Basket and Tub Parts diagram: .
I hope this helps.
Jul 30, 2015 | Kenmore Washing Machines
How do you change the agitator parts on a kenmore model 20702990 top loading machine with direct drive?
Remove agitator by taking fabric dispenser off and removing cover down below, pulls up with not much effort. Remove 7/16 bolt and take out agitator from tub area. Stand on the bottom part of agitator and pull directly up holding on to the auger section. Sometimes takes some muscle but will come apart. Agitator dogs will need to be replaced. Part # 80040 from Whirlpool.
May 18, 2010 | Kenmore Washing Machines
Clothes are caught under the agitator. How can I
Remove the top part of the agitator or the cap and you should find a bolt in the center. Remove the bolt and pull up on agitator.
98702 is not the model # of the machine. you should find the model # either on top of the machine or in the dryer door area around the frame.
Jan 11, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washer won't agitate
First, see the Sears parts site for washer model # 110.22952100 which I believe is your model.!retrieve.pd?modelNumber=110.22952100+
Look at the section containing the agitator and you should see how the parts fit.
Also see the following for an illustrated description of replacing the "dogs"
Nov 17, 2009 | Kenmore Washing Machines
Kenmore washing machine Model 110.4767292, squeaky agitator
I can't seem to get the Sears Parts site for your washer model number.
Can you verify that it's correct?
First, see the Sears parts site for your washer:
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
In the interim, here is the Whirlpool Service manual for top load, direct drive washers.$FILE/L-55.pdf
Following is a procedure for removing the agitator(s) on top load washers.
If you take the agitators out, I'd make sure that any "gunk" is cleaned off and check the splines inside the agitator and on the transmission agitator shaft.
It's probably not a serious problem.
Nov 04, 2009 | Kenmore Washing Machines
I have a kenmore elite model # 20949 and the bottom of the agitator turns but not the top
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with
a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one
direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Oct 31, 2009 | Kenmore Washing Machines
Kenmore washer agitator
Remove the agitator cap and the bolt in the middle that holds the agitator. Reach underneath the sides of the agitator and pull up. Try gently rocking it around as you pull, I'm sure it's going to be stuck pretty tight.
Mar 12, 2009 | Kenmore Washing Machines
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
213 people viewed this question
Sal De
 Brian Main
Brian Main
