Question about Kenwood VR-505 Receiver
Yeah...the left channel not working...
I've tried the cables, the inputs, every mode. Doesn't work despite what all I've done. A friend said it was probably the sound board. Disassembling would be the answer? Thanks for any help, sir.
Jeremy H
  • mchamm Jun 26, 2008
    Thanks for the help sir. Have a great day.
  • 624 Answers
If you know how to check electronic components, have good soldering skills, and have the proper equipment then disassembling and checking it out would be the right thing to do.
But if you have no experience with this kind of stuff you really should take it to a service center and let a professional look at it. I have seen on many occasions when people who disassemble their equipment and attempt to repair it, but have no experience at this sort of thing end up causing more problems than they started with.
It is also dangerous, you can be shocked by the electricity or cause a fire. And if you do no understand the terms it would be very difficult for you to understand what to look at.
Your friend who said it was the soundboard is wrong, there is no board in those Kenwood's called a "soundboard", so I would not be so quick to listen to him about opening it up.
Posted on Jun 26, 2008
  • Dave DeGain
    Dave DeGain Jun 26, 2008
    You are very welcome, and have a great day yourself. Thank you for the "FixYa" rating and if you ever need any help or advice on any car or home audio equipment I am more than happy to assist you.
    You can always just click the "Ask me" icon below my picture or you can email me direct by finding me thru the "Find experts" link on the home page of FixYa! under the list of the top 5 experts.
Rear and centre speakers are not working
Check the cables input, try to connect the cables on other inputs in the receiver, if it not works probably the speaker are not working, if it works the receiver inputs are damaged.
Jan 07, 2016 | Audio Players & Recorders
I can't get my Comcast cable channels to display on my Hitachi should I fix this?
A very well written question and I think you have provided your own answer.
this set uses a antenna switching assembly and they do fail. It could also be a bad tuner--note that the other owner got blu ray and such on it which are not via the coax fitting.
If your box has audio/video output jacks (like the blu ray) connect them to one of the rear audio/video inputs on rear of set and select that input on the set---box will then be used for channels but connection will not be via the coax but via that input.
If the box does not have those outputs get another--most providers do not charge for a box with those outputs on it.
If works you are just bypassing the tuner where your problem seems to be---those antenna networks are no longer available from Hitachi.
Jun 01, 2012 | Televison & Video
Dish tv 2 works but only very fuzzy on channel 56 dvr
It sounds like you may have just switched off the channel to view satellite.
The channel for satellite is based on the connection you're using. If you're using a coax connection, it should be on channel 3/4 or 62. If you're using video cables like RCA/HDMI then you'll need to switch the input. On the upper left of the remote should be a TV/Input button. Make sure you're in TV mode and press that to see if picture returns.
If the problem continues let me know and I would be happy to try some additional steps!
Tommy Faust
DISH Social Media Representative
Feb 15, 2012 | DISH Network IR Remote Control
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
Jul 08, 2011 | RCA Televison & Video
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
My Old 1997 GE 31GT660 was working just fine yesterday with a PS2. My girlfriend moved it today while cleaning and now I cannot get the PS2 to work. We have no remote but a friend used a universal to get...
Ur girl friend clean around did she unplug the tv.Replug it back later?Bet u she did,that why the tv universal codes is gone.Reprogram ur tv unverisal codes again should solved this problems.Tries push the manual control button channel up like one or two times tv will be in input video again like video 1 or 2.
Jan 13, 2011 | GE 31GT660 TV
No stereo signal out from yamaha p 2500 s
It's unclear what type of connectors are on the end of the cables(s) coming from your computer.
This amp only works with mono 1/4" TRS and XLR connectors, not standard RCA connectors.
Did you try the Right one in the Left Channel to see if the Left Channel worked?
Refer to the following manual and read up on the connectors (page 7) and the use of the Stereo/Parallel/Bridge Switch (page 8). When it is NOT in Stereo Mode the unit only uses the Right Channel controls and input.
Use this switch to select the operating mode.
• STEREO mode
Channels A and B operate independently (as with a conventional
stereo amplifier). The Channel A input goes to the Channel
A output jacks, and the Channel B input goes to the
Channel B output jacks.
The Channel A input signal is output through both the Channel
A and Channel B output jacks. The Channel B input jacks do
not function. Channel A and B volumes can be independently
• BRIDGE mode
The Channel A input signal is output from the BRIDGE output
jacks. To adjust the volume, you must use the Channel A volume
control knob.
Apr 03, 2009 | Yamaha P-2500 Amplifier
Left channel not working
The first thing I would check has already been done, the only other thing would be fuses. I am preety sure there is a protection fuse at ever channels output to protect against a dead short. I am sure you have already fixed this problem but I thought I would give it a try. Let me know what you found.
Jul 13, 2008 | Denon AVR-3802 Receiver
Kenwood VR-505 Receiver Logo
75 people viewed this question
Top Kenwood Audio Players & Recorders Experts
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
