Open files from different version of MS Publisher
I didn't think I used a different version, but maybe I did because trying to open a Publisher file brings up the message that Publisher cannot open files from a different version.
If you know a way to do it, I would be undyingly grateful to you.
Sincerely yours,
Stuart Leigh
I am suffering a lot of problems for reading pdf file so please help me to download pdf file reader
Posted on Dec 23, 2011
I have a similar problem: Files were created in Publisher 2003. Then I had to reformat the hard drive and re-install Publisher 2003. Now I can't open any of my previous files even though created by the same program because "Publisher can not open files from a different version." Very frustrating. I hope someone has a solution. Alban Johnson.
Posted on Jul 09, 2008
I have spent five days on a publisher document (2002 version) and today it is inaccessible and I'm told "MS Publisher has encountered a problem....etc." It was only a small file and I have...
If I was in your position I would do the following things:
1. Try to do a repair install for MS Office Suite/MS Publisher (if separately installed from MS Office).
Instructions on how to do this: Go to Start->Control Panel->Programs and Features->Select MS Office (or) MS Publisher from the list->Click on the top of the toolbar "Repair" button if available.
2.If the above doesn't fix the problem I would suggest to test your MS publisher file as (this) set of Microsoft's KnowledgeBase instructions suggest.
3. If the instructions above are what you have already tried, I would suggest to backup your files from MS publisher and re-install it from the beginning.
Let me know how that went.
Regards from FixYa **please dont forget to rate the helpfulness of this solution**
Mar 23, 2011 | Microsoft Computers & Internet
I have microsoft publishr on my desk top computer but I dont have the disk.I bought microsoft Publisher 1993 as I was told it would open the files I have on the memory stick I also have the microsoft 98...
...why are you still using publisher 98? Never mind. Whoever told you that 93 would open a file created with 98 was lying; the programming likely isn't compatible. At this point, you'd need to look REALLY hard for someone with the expertise AND tools to get that data for you. I definately have the expertise, but publisher 93 is almost as old as I am, so i doubt i have any of the necessary software lying around. If you use a more modern version of publisher, like publisher 2003, you might get lucky. i don't remember if 2003 is backwards compatible, but it probably is. But if anyone tells you that any computer or program from that era is forwards compatible, they are LYING. So to answer your question, try buying office 2003, and open it with publisher 2003. It might work then.
Feb 11, 2011 | Microsoft Publisher 98 Full Version for PC
I created a ms publisher file with a few objects
You changed update setting environment
Dec 16, 2009 | Microsoft Publisher
Where can i find a free copy of ms publisher 97 lost my cd, pc crashed and cannot open a brochure anymore !
to download this file : download a torrent client eg. bittorrent (from www.download.com)
now install it and open the follwing website : www.mininova.com in search type "ms publisher 97" select file with max. seeds. download it and open it with bit torrent to get the full version.
Nov 14, 2009 | Microsoft Publisher 97 Full Version for PC
Hi i am having problems opening my publisher files, it is telling me that they will not open an earlier version. the programme i have updated was office word 2003 and it seems to have stopped me opening my...
This makes no sense.
If you updated Publisher, it should read files created with the "current" version of Publisher *AND* it should read files created with the "previous" version of Publisher.
Oct 26, 2009 | Microsoft Windows XP Home Edition
How to open ms office file in different version
you need to open the file on the same version then save it again but on the version that you need, cause an older version could not open a newer, on the newest you have the option to save files at any version that you need
Jul 28, 2009 | Microsoft Computers & Internet
Photographs randomly disappear each time a document is used.
Before you open up Publisher and this document, open up task manager and note how much RAM is used as well as your paging file usage. After you open the document, take another look at your RAM and paging file usage again. If both have increased dramatically, you may want to use smaller images (via compression for JPEG files or lowering the resolution of the images first). Or you could invest in more RAM for the computer.
Jul 03, 2009 | Microsoft Office Publisher 2007 for PC
Unable to open a Publisher file a second time without rebooting PC
have you upgraded from xp to vista since you installed the microsoft publisher?
it sounds like your publisher is not closing the prior instance running. you can bring up the task manager and watch what is happening when you open and close instances in publisher. in task manager click on processes and watch what comes and goes as you work with publisher.
then if it continues, i would reinstall you publisher all together. the consensus among the gurus is it will running but it 11 yrs old and may have issues that can;t be patched for vista.
May 23, 2009 | Microsoft Publisher 97 Full Version for PC
Installed full version of publisher 2007; computer had a gliche and had to be retored; publisher was lost; now I can't reinstall because it says I've reached the total number of installs. anything I can...
yes ou can get this product activated . you have to search for opa12.dat file on your computer and delete the file and open publisher when it asks for activation select activate publisher over the telephone
before following the steps make sure you close all the office application
If that doesnot work you can call MS at 1-800-936-5700 to activate Publisher
Mar 31, 2009 | Microsoft Office Publisher 2007 for PC
Computers & Internet Logo
379 people viewed this question
David Payne
David Payne
