Question about Samsung RS2630SH Side by Side Refrigerator
Hot Samsung Refrigerator
Can you tell me what kind of computer fan you replaced in your refrigerator? i sent an email to samsung 2 days ago and still have had no response. i've burned myself several times now and i need to get this fixed somehow.
your help is greatly appreciated.
thanks,
k
  • thedowns000 Nov 12, 2008
    My refrigerator started making a loud noise for 2 days then stopped. Now it gets extremely hot when plugged in. I ordered the new fan motor unit and need to know if anyone replaced this part themselves. If so how do you put the new motor unit in?
The outside center and out side corners are very hot. Everything else is working fine
Hot refrigerator I have a Samsung refrigerator RS2630SH ...
www.fixya.com/support/t322304-hot_refrigerator
Also the freezer side outside wall is very hot to touch. Ice maker does not work as well. Any suggestions appreciated, excluding the one "not to buy Samsung ...
Samsung RS2630WW Side by Side Refrigerator Divider hot ...
www.fixya.com > ... > Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator, divider hot related issues. ...Compressor/motor on mu Whirlpool frige is really hot. face of fridge/freezer ... centerdivider is hot to the touch, it means that the compressor is running hot. either your ...means there is inadequate air flow over the condenser coils outside the unit.
[PDF]SAM0059 Samsung Side-by-Side Refrigerator.pdf
applianceassistant.com/.../sam0059_samsung_side-by-side_refrigerator.p...
A newly developed SAMSUNG side by side refrigerator in 2004 has the .... Warranty service can only be performed by a SAMSUNG authorized service center. .... SUB-CONDENSER. Hot Pipe. Hot Pipe. Compressor. SIDE CLUSTER PIPE .... corner of the refrigerator. ... The CoolSelect ZoneTM thermistor is located outside.
Jan 25, 2016 | Samsung RS2556 Side by Side Refrigerator
Samsung Refrigerator Model# RF4287HARS/XAA Serial# 102043CB303152 J Refrigerator is cold, the freezer is 63 degrees warm.
This could be caused by several different reasons so I need you to check a few things. If you want to know right off what is causing the temperature symptoms you will need to answer my questions. Can you tell me how hot the top of compressor feels? Too hot to keep your hand there? The fan motors are they working strong without obstruction? Can you feel the copper lines/pipe that exit the compressor for one line being hot and the other cold? As for the temperature ohms reading you get when testing the thermistor you will first need use the=> RF4287HARS Fast Track Tech Sheet page 2 Answer my questions and I will assist you in finding the cause of the problem. I am here waiting for your response,Sea Breeze
RF4287HARS Parts
Dec 08, 2013 | Samsung Refrigerators
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
Ice maker stopped working and fridge is hot on outside
This could be 2 separate problems or a control board issue. First I would check that the condenser fan is running, coils are cleaned. Here is a link to check the condenser fan http://appliancehelponline.com/referhotonsides.html If the fan checks out good more likely a control board failure.
Jun 07, 2010 | Samsung 24.8 Cu. Ft. Side-by-Side...
The middle panel between the freezer and refrigerator is very HOT
Sounds like the door heater has gone bad. You will need to pull off both the fridge and the freezer door panels and see which heating element has gone bad. This heater is to make sure that your doors do not ice up. But once they go bad they can be a pain to replace and repair.
Jan 02, 2010 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Refrigerator
You have the fan problem. Full the refrigerator out and open the lower back cover you will see you fan is almost become bad. If you apply WD1040 oil you can use it about 3 more months. Then It will die out. I think you better change it now or later on you refrigerator become hot and hotter. If you are careless, you can get burn you skin. I had this problem. Frist, the fan made noise on and off. I applied oil into the motor. It was working about 3 months then I died out. The front end of refrigerator become a heater.
Go to online partstore.com and buy a fan with your fan model.
Dec 01, 2008 | Samsung RS2630SH Side by Side Refrigerator
Hot refrigerator
I had the exact same problem and got sick and tired of it. I contacted the Consumer Product Safety Commision and they came out and photographed my refrigerator and asked questions about the fridge. If everyone who is having trouble would write the commission we might be able to get the fridge recalled. Even if you repaired it already, they want to know the problem and what you did about it. the web site is: www.cpsc.gov. Everyone please help out. The more people we get to respond the better. ThanksZFH3I10
Dec 28, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
866 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
